Old Aug 18, 2010, 07:17 AM
dmajchrzak is offline
Find More Posts by dmajchrzak
dmajchrzak's Avatar
USA, NH, East Merrimack
Joined Feb 2006
Where to get GMS / Tower engine parts?
Our club trainer has a Tower .46. It's blown a head gasket and needs a $2 gasket kit. Does anybody know where to find parts?
MECOA has dropped the GMS line (makers of Tower's engines), and Tower Hobbies hasn't had GMS or Tower parts of many months now.
I'm hoping somebody out there has a LHS that has some left over stock for GMS engines. Maybe you guys know a website with some stock?
Dave
dmajchrzak is offline Find More Posts by dmajchrzak
Old Aug 18, 2010, 12:11 PM
Chip01 is offline
Find More Posts by Chip01
United States, TX, Weatherford
Joined Dec 2006
MECOA might still have a few parts around. I would call them and ask. Head gaskets are pretty common.
I have heard that the Chinese are "striking" or whatever and there is no production going on. So all mainland Chinese stuff seems to be drying up.
Chip
Chip01 is offline Find More Posts by Chip01
Old Aug 18, 2010, 07:11 PM
JollyPopper200 is online now
Find More Posts by JollyPopper200
JollyPopper200's Avatar
Mountain Home, Ar.
Joined Dec 2009
A head gasket is keeping the engine from running? A head gasket is normally just a thin aluminum washer that sits in the groove in the head that the liner fits into. They are not really head gaskets but more a shim that lowers compression a bit. It would be very difficult to "blow" one. And most engines will run just fine without them anyway. Engines just have a bit more compression without them which may require a little finer tuning.
JollyPopper200 is online now Find More Posts by JollyPopper200
Old Aug 18, 2010, 08:07 PM
JohnsPop is offline
Find More Posts by JohnsPop
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
Maybe just put a layer of red RTV silicone around the top, put the head back on and let it cure overnight....
JohnsPop is offline Find More Posts by JohnsPop
Old Aug 18, 2010, 08:49 PM
proptop is offline
Find More Posts by proptop
Airplane Gearhead
Central N.Y.
Joined Jan 2005
You could make one out of a piece of soda or beer can?
Or, just try running it w/o the shim/gasket...if it leaks, try lapping the head to the sleeve flange. (that worked quite well on an Enya .50SS of mine)
proptop is offline Find More Posts by proptop
Old Aug 19, 2010, 02:49 AM
Mountain Home, Ar.
Joined Dec 2009
Somewhere in the late 90s I bought a Tower .46 for the price. When I tried to break it in, it would not run very well. It would hardly run at all. I tried all the simple stuff to no avail, so I took the engine apart. I discovered the liner was not in the case correctly, the exhaust port not aligned with the opening in the case. I turned it and it has been a real work horse since. It ran so well, in fact, that when the purple on the head began to fade, I bought a new head. The new head came with two shims/gaskets. As I recall, the instructions said the engine could be run with none, one or both of them. I'm running mine with none. So I still have two new, unused head shims/gaskets. If it will fix your engine, I will send you one with my compliments. If it does not fix your engine, I would like it back. It's a pay it forward thing. Somewhere down the road, someone at your field will need a prop or glo plug or something that will get him in the air and you will have one to loan or give him.
Old Sep 06, 2010, 01:29 PM
dmajchrzak's Avatar
Joined Feb 2006
Thanks for the info everyone. Jolly - people like you are why this hobby is so great.
I ended up using JB Weld to seal the head. Hope it works!
Old Sep 07, 2010, 07:14 AM
TimBle is offline
Find More Posts by TimBle
South Africa, WC, Cape Town
Joined Dec 2009
must be a USA problem, the rest of teh world seems to have plenty spares of GMS engines. I just rebuilt mine a couple of weeks ago. Gaskets, bearings the lot, all replaced with genuine GMS parts.
TimBle is offline Find More Posts by TimBle
Old Sep 07, 2010, 08:31 AM
Chip01 is offline
Joined Dec 2006
I am sure there is a container full of stuff being shipped from China to the US of A. But where that container is in the stack of containers on the container ship, and the progress of the ship have a lot to do with parts availability. Consumption rates in the US of A also has a bearing on parts availability.
But the problem is indeed there and effects both the GMS and Tower Hobbies engines (which are as most know almost identical except for coloring).
Chip
Old Feb 19, 2012, 07:54 PM
perpetualrepair is offline
Find More Posts by perpetualrepair
perpetualrepair's Avatar
Victoria BC CANADA
Joined Dec 2003
Parts
Are there any spares anywhere for these GMS motors?. I need at least a ring for a 76 possibly a liner and piston.
Or does any one know if there are other parts for other motors that will fit?
Hate to use it as a fisshing weight as itonly has a few hours on it.
perpetualrepair is offline Find More Posts by perpetualrepair
Old Feb 21, 2012, 08:55 AM
earlwb is online now
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Frank Bowman makes piston rings for most anything. He likely already has some.
He makes the best rings by far, even in comparison to many of the engine companies.
Frank Bowman
1211 N Allen Ave
Farmington
NM 87401-3568
USA
Phone: (505) 327-0696
ringmaster46@msn.com
here in the USA GMS was imported by Great Plains (aka Tower Hobbies), they had taken over the GMS line from MECOA. I suspect they killed it off in the USA and aren't importing it anymore. GMS too, may have discontinued production of model engines as their primary business is car parts such as for brake systems. So they may be too busy to make model engines now.
earlwb is online now Find More Posts by earlwb
Old Feb 22, 2012, 12:25 PM
Victoria BC CANADA
Joined Dec 2003
thanks
Thanks for the link earlwb, have a couple of rings on the way, great guy to deal with.
Wonder if we will ever be able to get parts again though,
For Sale For sale brand new never used gp reactor 60'' span w/ .76 gms engine all electronic neweramarketin Aircraft - Fuel - Airplanes (FS/W) 1 Jul 28, 2010 07:09 PM
Question GMS .61 , GMS .61 , Tower Hobbies .61, Tower Hobbies .75 on www.towerhobbies.com master g Engines 7 Mar 03, 2008 08:26 PM
Question Where to get Cen Engine parts? Helicopterkid Off-road Cars 4 May 14, 2007 01:09 PM
Discussion What do you think of Tower Hobbies gms .76 engine? Starguard Engines 3 May 08, 2006 09:40 PM
