Old Aug 17, 2010, 07:45 PM
ridgewalker is offline
Find More Posts by ridgewalker
The lunatic is on the grass
ridgewalker's Avatar
Joined Aug 2008
Blade 120 SR tips and mods i have done .....post yours
I will continue to add mods as i do them,be sure to check back!
The 120 sr in a Jet Ranger body
Two stock batteries for longer flight time
1000 mah battery from an SR 3S battery pack
Lighted Blade Tip
Landing skid servo gear saver mod
Ziptie/wire mod
O ring skid mod
Tail motor bearing keeper mod
Well with only one battery to fly with it gives me time to think
The tail motor has a small bearing on the motor shaft between the motor can and the tail rotor.
It is there to help save the tail motor in a crash by preventing the tail rotor from pushing the motor shaft out the back and it looks like it will also help keep the motor shaft from getting bent in a crash.
Good idea,but it is tiny.....and it always comes flying off in a crash.In the house you may be able to find it,but forget it if your outside....that tiny bearing is gone!
Good thing is...you don't need it.The heli will fly fine without it....but you loose the protection that it provides.
I came up with an easy solution.
I call it the "tail motor bearing keeper"
It is just a thin strip of plastic bent at a 90* angle.It tucks between the motor can and the motor mount.There is a hole in the center to provide space for the tail rotor....binding would definitely cause the tail motor to over work and die.So there is ample space for the tail rotor.
I had to try it...and that ment an intentional crash so i aimed for the couch .I flew right into the back of it...plop....zing there goes the tail rotor,but the bearing keeper did its job and held the bearing on the motor shaft .
The pictures will explain better than i can..lol
I also made some O rings for the skids.I cut some narrow slices of nitro fuel tube i had.They fit great.
And they prevent the heli from sliding around on lift off....or when you want to land.
They also help prevent the skids from doing a split on a hard landing,saving your skids a bit longer.
Again the pics are more interesting than my ramble..lol
ridgewalker is offline Find More Posts by ridgewalker
Old Aug 23, 2010, 03:47 PM
Joined Aug 2008
Just an update for thse who might be wondering if the mod is holding up.
Still flying great.
I have not lost the tail motor bearing......not once and i have had a few crashes!
Without the bearing keeper i would have lost the tiny bearing long ago.
Ridgewalker
Old Aug 23, 2010, 04:23 PM
Technica is offline
Find More Posts by Technica
Joined Apr 2010
Nice, but I think I'll just keep my 120SR the way it is.
Technica is offline Find More Posts by Technica
Old Aug 23, 2010, 04:28 PM
beevous80002 is offline
Find More Posts by beevous80002
Oops!
beevous80002's Avatar
United States, CO, Florence
Joined Apr 2010
Things like this is where waiting is a good thing. I just hope the sr"120" does soo good that the msr "80" gets less expensive. (@80 mm from bolt hole to edge of blade). It seems to becoming a #'s game.
beevous80002 is offline Find More Posts by beevous80002
Old Aug 24, 2010, 02:13 PM
Joined Aug 2008
Landing Skid Mod to save your servo gear.
Save your servo!
Noticed today that the landing skid mount on the rear left in a hard crash will cause contact between the big servo gear and the landing gear at the frame.
Hold the heli firmly and press the skid up on the rear left side....notice how the little nub/mounting post from the landing gear sticking up through the chassis can contact the servo gear ...The skid will break the servo gear in a hard crash...not good
The easy fix is to trim the rear left skid where it mounts to the chassis/frame.
Remove the skid from the heli.
You only need to trim just a small slice.....Use a dremel or some other tool that will cut through the tiny steel rod that is inside the skid mount at the chassis/frame.
Cut it so that when the skid is installed the skid mounting post is flush with the chassis/frame...By doing that you will save you left servo from getting ruined on a hard landing/crash.
On to the pics
Old Aug 24, 2010, 10:41 PM
Kris... is offline
Find More Posts by Kris...
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
Nice find RW and a worthy mod its the one thing that really bugs me when a servo starts get the jitters or gets smashed up ! keep up the good work
Kris... is offline Find More Posts by Kris...
Old Aug 25, 2010, 12:51 AM
heli-yeah is offline
Find More Posts by heli-yeah
Flying Monkey
heli-yeah's Avatar
Lexington, KY
Joined Aug 2010
Tail motor protective sleeve MOD
So here's what I got so far. Good Luck.
120 SR MOD (tail motor protective sleeve tether) (3 min 22 sec)
heli-yeah is offline Find More Posts by heli-yeah
Old Aug 25, 2010, 01:22 AM
Joined Aug 2008
Can you also post some pics please.Some of us are technologically challenged and can't veiw vid due to.......well an old slow pc on dial up...lol
I would like to see what you did,do have any pics?
Thanks,Ridgewalker
Old Aug 25, 2010, 01:31 AM
Kris... is offline
Registered Addict
Kris...'s Avatar
Joined Jul 2010
Originally Posted by heli-yeah View Post
So here's what I got so far. Good Luck.http://www.youtube.com/watch?v=9LX429nQAlw
Those mini drill pieces looks nice are they for use with a dremel also you made your own skids on the mSR ?
Old Aug 25, 2010, 07:16 AM
Flying Monkey
heli-yeah's Avatar
Lexington, KY
Joined Aug 2010
I'm pretty sure they are made for hand use only. Some have broken with just the slightest twist. Great tool to have though, I have done tiny scale MODs on my mSR that would not have been possible without them.
Old Aug 25, 2010, 08:12 AM
Flying Monkey
heli-yeah's Avatar
Lexington, KY
Joined Aug 2010
Originally Posted by ridgewalker View Post
Can you also post some pics please.Some of us are and can't veiw vid due to.......well an old slow pc on dial up...lol
Thanks,Ridgewalker
Here are a few, sorry about the zoom, my camera is "technologically challenged" also.
Old Aug 25, 2010, 01:43 PM
Joined Aug 2008
Wow!
That is some pretty tiny drilling you have done!
I have not seen such small drill bits before...where do you get such small drill bits?
In the past i have chucked a very thin sewing needle in my dremel with the point going into the chuck and the eye being the end used to drill with.
It worked well on plastic....but some tiny drill bits would work better.
Nice work!
Ridgewalker
Old Aug 25, 2010, 02:45 PM
Technica is offline
Joined Apr 2010
I use the "leave it as it is" mod and it works great.
Old Aug 25, 2010, 05:07 PM
Flying Monkey
heli-yeah's Avatar
Lexington, KY
Joined Aug 2010
You probably mean the don't crash MOD. Because if you fly outside much, and you crash down at all, sooner than later your gonna lose this $3.50 part. Just trying to save myself and maybe some of these other guys the dough. MONEY MAKES THE ROTOR GO AROUND.
Old Aug 25, 2010, 05:15 PM
Flying Monkey
heli-yeah's Avatar
Lexington, KY
Joined Aug 2010
Anyone planning any body, fuse MODs?
Careful! Blade SR 120 mod to do before you fly... ridgewalker Micro Helis 18 Oct 12, 2014 09:22 PM
Discussion Blade SR Mod that everyone who has one should do. Wiskey Beginner Training Area (Heli-Electric) 0 Jul 26, 2010 08:40 PM
Discussion Two tail motor scares in one day...SR McKrackin Micro Helis 4 Mar 27, 2010 05:51 PM
Discussion I've got a bike, you can ride it if you like... Sprydle Life, The Universe, and Politics 17 Nov 03, 2009 05:43 PM
