Old Aug 17, 2010, 12:56 PM
Dukesy is offline
Find More Posts by Dukesy
Joined Aug 2010
Phase 3 f16 spray help!!
Hi all
I am from the UK and have just got a phase 3 f16. We got some paint from a model shop but it started to melt the foam. Please can you tell me what paint will work and where i can get it from. Also my dad had a multiplex twista that he sprayed and that worked fine but we cant remember what paint we used and if we gave it a coat with a protector first.
Thanks for your help
Happy flying
Dukesy is offline Find More Posts by Dukesy
Old Aug 18, 2010, 02:19 PM
chalmrast is offline
Find More Posts by chalmrast
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
You need to go to your local hobbyshop and find spray paint that is foam safe. Testor's Model Master is one brand that hobbyshops here carry.
Always test on a scrap piece of foam.
Non-foam safe paints can be used but you have to hold the can 12-18" away and do very light coats. By doing this, you are allowing the propellant (the ingredient that eats the foam) to evaporate before it hits the foam. It is a slow / messy process but it can be done.
Your multi-plex twister is probably a different type of "foam"... more like EPP, not the EPS your F-16 is made of. EPP is more like a plastic than a styrene foam and is more resistant to the propellant in spray paints.
You can also get some polycrylic at your local home improvement store and paint your entire airframe with a brush. It is water based and will not affect the foam. It will form a protective barrier so that you can use any spray paint... but you still have to be very cautious and do not assume that the foam is totally protected...
Here is my EPS foam FlyFly F-86 Sabre painted with Testor's Model Master spray paint...
chalmrast is offline Find More Posts by chalmrast
Old Aug 23, 2010, 03:37 PM
Dukesy is offline
Joined Aug 2010
Hi Chalmrast
Thanks for your reply. i have found this paint which i can get in the uk
http://www.sussex-model-centre.co.uk...xd.asp?id=5135 i have ordered it but not recieved this yet. I will still test it on scrap foam first but hopefully it will work. Very nice plane BTW
Happy flying
Old Aug 24, 2010, 07:28 AM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
I have been using water based paints designe dof RC car bodies to paint foam planes. Works well on EPS (like the Phase 3) and otehrs, like the Elpor used on MultiPlex airframes.
Pinecone is offline Find More Posts by Pinecone
Old Aug 31, 2010, 05:32 PM
Dukesy is offline
Joined Aug 2010
Hi All
I used the paint i posted in the other link, thanks for all your help. her she is very happy!! Cant wait to test fly it, i will let you know how it goes. Im so happy with it though i dont want to throw it lol
Never put pics on before so i hope they work
Happy flying
Old Aug 31, 2010, 08:03 PM
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
Originally Posted by Dukesy View Post
Hi All
Happy flying
Hey, looks great... for a red F-16 that is....not sure I've ever seen one of those but who cares right?
I know those Phase 3's are good flyers... many guys in my club have/had them...
Old Sep 01, 2010, 01:27 PM
Dukesy is offline
Joined Aug 2010
Hi Mate
Thanks for your reply, yeah i like red to be diffrent but the first flight didnt go to well. I didnt want to do it grey incase i couldnt see it and id previously had a HET thudnerbird f16 which didnt fly. Just this second got back from the Phase 3 maiden and it was really nice to fly but as it came back across the ball link on one of the tail fins came off and it went straight in on the nose, total wright off! do you know if any guys at your club use diffrent linkages cause i am thinking about getting another one
Old Sep 10, 2010, 07:44 AM
jdhughen is offline
Find More Posts by jdhughen
Columbia, SC
Joined Jun 2008
you can go to your hardware store and get some spray clear shellac. This is alcohol based and will seal the foam and serve as a base for your regular spray paint. spray 2 even, through but not heavy, coats. While it is "clear" it does have a slight "yellowing" quality to it so mask off areas that you don't intend to paint. Drys in min. I do this all the time with foamies.
Joel
jdhughen is offline Find More Posts by jdhughen
Old Sep 11, 2010, 01:03 AM
headlessagain is online now
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
Does anybody know if the hot water trick will work on this model? I had what appears to be a brown out on my maiden flight of 6 secs. The front is all intact but now looks like a court jesters shoe without the bell on the tip!
Head
headlessagain is online now Find More Posts by headlessagain
Wanted Phase 3 F16 Airframe Only Phazewun Aircraft - Electric - Jets (FS/W) 3 Sep 04, 2010 01:26 AM
Discussion Phase 3 f16 help !! Phazewun Electric Ducted Fan Jet Talk 4 Oct 17, 2009 03:31 PM
For Sale Stock Phase 3 F16 power set up vq35721 Aircraft - Electric - Power Systems (FS/W) 0 Oct 06, 2009 11:22 PM
Cool Eflight f16 and Phase 3 f16 dhpreist Foamy EDFs 2 Jan 19, 2009 09:54 PM
