Old Aug 16, 2010, 10:58 AM
Roger Lombard is offline
Find More Posts by Roger Lombard
Confused? Who, me?
Roger Lombard's Avatar
United Kingdom, England, North York
Joined Jan 2005
New lasercut kit - classic sailplane - input invited
About three years ago I got involved in a project working with Vintage1 and Replikit that resulted in a 100" Minimoa. That project has been reported in my thread "1.8-2.5m Minimoa" and the full kit is commercially available for just under 130 in the UK. The thread includes links to pictures and a youtube video of the prototype and pictures of another, production, kit built by v1 fan http://www.rcgroups.com/forums/member.php?u=323814
We have recently started a discussion about a successor and although we're getting input I was worried that some people able to offer input, or maybe interested in a new sailplane kit, weren't realising that the Minimoa thread had drifted away from its origins.
That's why I'm starting this thread.
In no particular order design/concept considerations are:
The original 2.5m wingspan of the Minimoa was driven by a wish to differentiate from the typically larger wooden kits which cost more and which not everyone has the time/building expertise/funding/storage/transport space to tackle. The idea was it would bridge a gap between the very expensive glass kits that are almost ARTF, and scratch building. However it is already clear that another model could go to 3m-ish (3.2 max) while staying with the original design parameters and not bumping into the 3.75/4m upwards heavy brigade.
The Minimoa proved that there is a market, albeit not huge, but sufficient for Vintage1 and Replikit to be ready to tackle another.
The Minimoa also proved that the design/manufacturing sources were capable of producing an excellent design that maximised the opportunities presented by their laser cutting facilities. The kit, as close as dammit is to swearing, "clicked" together in a way that simultaneously delighted both the inexperienced modeller (me, for starters) and the experienced builder who wanted a minor project that would bring quick results and a fine flying model.
It would be nice, but not essential, to go with a gull wing to use the production joiner system of the Minimoa and there is a minor argument that something that was fairly slab sided (so probably not gull winged) would be slightly easier (so quicker) to do. However I quote from an email to me from Vintage1:
"What I think is ideal therefore is something that is relatively easy to *BUILD* and finish to a high standard, I don't care if it's awkward to design, however. That gets done once only."
and
"Gull wings or not, I have no great worries either way. To do a pukka job is about (I've deleted his forecast so he's not toasted for it) days work whichever way you look at it. Likewise I am not hugely interested, and I don't think the target market is either, in shaving a fiver off and getting a sh*t model."
A sentiment I'm quite sure we'd all share.
If you haven't already seen the suggestions made thus far you only need to read the last two or three pages of the other thread. However please note that the kit must be wood - no glass moulding - and that makes the likely original model from which the kit is drawn to have been a wood/wood/fabric design. Although we've included the Blanik L-13 because one or two of us have a soft spot for it.
If you have a suggestion to make please bear in mind Vintage1 will need supporting documentation essentially including a decent set of 3 views. Also some recognition that whatever we choose needs to have a good airfoil because translating some of the older designs might resul in something that's not particularly penetrative. It must be capable of slope soaring although if it has thermal performance too so much the better
Sort of top of the pile at the moment are, again in no particular order,
Slingsby King Kite
Schleicher Ka-8
Scheibe Bergfalke IV
But that doesn't mean another might not yet be the choice.
Can those of you who have been kindly inputting to the old Minimoa thread on this topic now please switch to this one? And anyone else is welcome. Please bear in mind Replikit/Green Air Designs may be a UK company but it does have a US importer.
Roger Lombard is offline Find More Posts by Roger Lombard
Old Aug 16, 2010, 11:37 AM
shinck is offline
Find More Posts by shinck
Utah, USA
Joined Jun 2007
EON Olympia 2b - fuselage similar in construction to Minimoa, much simpler wing, 1/5 scale would be 3m
My second choice would be a 1/5 scale K8b, also 3m; balsa fill-in for nose instead of glass
Scott
shinck is offline Find More Posts by shinck
Old Aug 16, 2010, 11:53 AM
Woodstock 1 is offline
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
Sperber Junior? Nice gull wing, no fancy canopy needed! My favourite silhouette at the moment..
Slingsby Petrel is the other..
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Aug 16, 2010, 12:00 PM
shinck is offline
Utah, USA
Joined Jun 2007
Wing problems & 3-view question
I like gull wings, and have (unbuilt) kits of both the Fafnir and Petrel. The problem is that these are highly tapered wings and 19m/17.3m respectively in full size, which makes the tips really narrow when trying to keep the span below 3/3.2m.
Question:
You requested good 3-views. You want them posted here?
the Olympia has a 1/4 scale plan by Cliff Charlesworth, plus his book "Scale Model Gliders" uses the Olympia for a demo construction project. 3-views also available in Martin Simon's series of books.
Old Aug 16, 2010, 12:04 PM
GeeW is offline
Find More Posts by GeeW
SB-28 UK Display Pilot
GeeW's Avatar
ENGLAND
Joined Jul 2001
Which version of the Bergfalke IV? They had 2 completely different fuselages. One was typical B'falke and the other looked like a K-13.
Instead if the oft modelled K-8 why not a Scheibe Zugvogel IV, SF-26 or even a SF-27 (either straight or the M/ MC version) similar but different? There's a couple of full size ones in the UK to go look at.
I think you are right about the need for a scaley glider at a manageable size. Would love one myself.
Cliff Charlesworth also thought that something like this was needed many years ago when he came up with the Senior.
EDIT I meant the Zugvogel IIIa not IV, thanks Skylark3f
GeeW is offline Find More Posts by GeeW
Old Aug 16, 2010, 12:25 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
The very best 3 view is this one
VERY unusual subject but I reckon a very good flyer might result. The wing looks 'right' to me.
Old Aug 16, 2010, 12:27 PM
skylark3f is offline
Find More Posts by skylark3f
..full opposite rudder..
Cranfield Uni, Beds, UK
Joined Nov 2004
Zugvogel IIIA
How about a Zugvogel IIIA?
It's got the same construction as a K8 and has the same performance in flight as a K18. Certainly not an overmodelled glider!
See the attached photo.
skylark3f is offline Find More Posts by skylark3f
Old Aug 16, 2010, 12:41 PM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
very good plans on the Weihe as well.
Really, good 3 views or plans for free without copyright are the main thing. Its hard to 'guess' at a correct fuselage shape.. for example.
Old Aug 16, 2010, 12:48 PM
Joined Nov 2004
There's a nice 3-view of the Zugvogel in the same Martin Simons book as the Skylark 2 "Merlyn" I can get all the detailed photos of the Zugvogel you'd need too!
Merlyn would make a nice model too though.
Old Aug 16, 2010, 12:51 PM
GeeW is offline
GeeW's Avatar
ENGLAND
Joined Jul 2001
Another suggestion Scheibe B-Spatz
Some one is doing a BIG version on retroplane
Old Aug 16, 2010, 01:57 PM
The SKY MAN is offline
Find More Posts by The SKY MAN
The SKY MAN's Avatar
uk/england
Joined Jun 2008
What about the standard austria?
The SKY MAN is offline Find More Posts by The SKY MAN
Old Aug 16, 2010, 01:58 PM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
looks good as well.
Old Aug 16, 2010, 02:15 PM
flamehead is offline
Find More Posts by flamehead
Gary P
Joined Aug 2007
A beautiful gull wing such as DFS Reiher or Slingsby Petrel (they look very similar).
Preferably 3 - 3.5 metres or so, rather than smaller (since those graceful narrow-tipped wings fly better if not too small, and also, the current Reiher and Petrel kits are huge, 5-7m, so anything up to 4m would be small and novel).
You know those beautiful gull wings would sell the best, it makes business sense.
flamehead is offline Find More Posts by flamehead
Old Aug 16, 2010, 02:23 PM
Confused? Who, me?
Joined Jan 2005
Watching a youtube video of the Eon Olympia, very pretty and nice clean lines btw, I came upon this http://www.youtube.com/watch?v=FJ1JK...eature=related
Lovely cross wind landing in a glider that has significance for me - first one I went up in, at Great Hucklow/Camphill a VERY long time ago.
What's also interesting is that although we're all familiar with "rats deserting the sinking ship" - watch VERY carefully at 2:23 and you'll see a gliderborne rat deciding this was one landing he wanted nothing to do with. Either that or it's one of the occupants cacking themselves.
Old Aug 16, 2010, 02:24 PM
PeteSchug is offline
Find More Posts by PeteSchug
PeteSchug's Avatar
Elmhurst, NY (Queens in NYC)
Joined Apr 2004
I'm very partial to the Olympia even though the fuse would be more work than a Ka-8.
For its day it was a very modern looking sailplane and I have always regarded it as a classic design.
Many years ago there was a plan for a Wolf glider in Model Airplane News. It was Wolf Hirth's glider and he demonstrated and taught soaring all over the USA with it. I build a fuse but never got any further. That's another sailplane I would love to build. Hmm... Time to look in Simons. Yes, it's there! Not all that common, I know of only one plan for it and it was a nice looking sailplane even for its time.
Pete
PeteSchug is offline Find More Posts by PeteSchug
New Product Lasercut CNC conversion kit for the Proxxon MF70 KJMDES CAD/CAM 3 Sep 19, 2011 11:57 AM
Wanted Chrysalis 2M Electric sailplane kit (with the three piece wing kit) bfraser Aircraft - Sailplanes (FS/W) 0 Aug 14, 2010 02:01 AM
For Sale Classic* Midwest Pitts Special 48" semi-kit moneybags Aircraft - Fuel - Airplanes (FS/W) 0 Aug 10, 2010 01:16 AM
Sold ARES kit by Classic Air Models *NIB* wfortney99 Aircraft - Fuel - Airplanes (FS/W) 1 Aug 09, 2010 08:23 AM
Article Stevens Aero Groove Aerobatic Park Flyer Lasercut Kit Review Christine Electric Plane Talk 9 Sep 25, 2009 05:35 PM
