Old Feb 23, 2011, 12:14 PM
rcmonster99 is online now
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
That is really interesting. I wonder why nO one has clocked on this
rcmonster99 is online now Find More Posts by rcmonster99
Old Feb 23, 2011, 12:20 PM
Coyote64 is offline
Find More Posts by Coyote64
Praying for better weather
Coyote64's Avatar
Joined Dec 2007
But what is the output of the transmitter at the 2S voltage level. It might take less current, generate less heat but also only be producing half the power
Coyote64 is offline Find More Posts by Coyote64
Old Feb 23, 2011, 12:27 PM
balsabuster2004 is offline
Find More Posts by balsabuster2004
balsabuster2004's Avatar
Washougal, Washington, United States
Joined Jan 2004
Originally Posted by Art Newland View Post
Like this?
Art,
Had I know you'd be bending piano wire landing gear, you could have used my famous Skip Hatheway landing gear bending tools.
balsabuster2004 is offline Find More Posts by balsabuster2004
Old Feb 23, 2011, 12:32 PM
Wearyman is offline
Find More Posts by Wearyman
Just dog tired.
Wearyman's Avatar
USA, NY, Buffalo
Joined Dec 2010
If my understanding of some of IBCrazy's posts is correct, even reducing the power by 1/2 will only reduce the range by 1/4. Using a 2 cell LiPo rated at similar MWh shouldn't cause any significant reduction.
Think about it this way: If the trade-off for a marginally smaller range is crystal clear video and less drop-outs or risk of control loss and you aren't going for long range flights, then I'd say it's probably worth it.
Although with testing, I'd think that a proper voltage regulator would be a better solution. Keeping the volts in the proper range while not giving up any capacity is the ideal.
Wearyman is offline Find More Posts by Wearyman
Old Feb 23, 2011, 12:39 PM
carguy1994ca is offline
Find More Posts by carguy1994ca
I tell her RC is cheap !
carguy1994ca's Avatar
Quebec, Canada
Joined Sep 2006
I saw a lot of posts where people use the main power battery (motor battery) and use 5v equipment with a voltage reg and filter. Less weight, less possibility of failure.
I'm quite happy with the 12v equipment I have right now. I used it on the rc truck in the house and although the VTx becomes hot, no problem with it yet. When the truck is moving it does give some airflow to reduce heating but it is still a bit hotter than on the plane. all my system is rated 12v, don't know if I can reduce the voltage and still keep it working ? I am afraid that if I lower the voltage, the margin I may have may be reduced if the 2S battery losses a bit of power ?
carguy1994ca is offline Find More Posts by carguy1994ca
Old Feb 23, 2011, 12:45 PM
Art Newland is online now
Find More Posts by Art Newland
CD-ROM Junkie
Art Newland's Avatar
United States, WA, Bellingham
Joined Apr 2001
Would really like to see someone measure the transmitter output on both voltages, if it is all really running on 5v, it might be the same.
Art Newland is online now Find More Posts by Art Newland
Old Feb 23, 2011, 12:47 PM
CD-ROM Junkie
Joined Apr 2001
Originally Posted by balsabuster2004 View Post
Art,
I'll keep it in mind for the future, was kinda fun smashing on it with a big hammer though...
Old Feb 23, 2011, 01:04 PM
Joined Jan 2004
I know a guy who probably has an RF wattmeter that works up in that frequency.
Old Feb 23, 2011, 02:37 PM
CD-ROM Junkie
Joined Apr 2001
Well, get to it man! Inquiring minds want to know.
Give you something to do durng the blizzard...
Old Feb 23, 2011, 02:51 PM
CD-ROM Junkie
Joined Apr 2001
mmm... dunno...this is the review that got me hooked. srcoll down to see the video.
http://www.giantcod.co.uk/frsky-v8ft...-p-405313.html
http://www.himodel.com/manual/frsky_..._telemetry.pdf
Look under "function of two way communication".
Old Feb 23, 2011, 02:53 PM
CD-ROM Junkie
Joined Apr 2001
http://www.flytron.com/rc-electronic...rssivolts.html
Old Feb 23, 2011, 03:02 PM
madmike8 is offline
Find More Posts by madmike8
madmike8's Avatar
USA, TN, Fayetteville
Joined Dec 2004
Yup, If it's feeding a voltage regulator that knocks it down to 5v then it shouldn't hurt the signal along as it can feed the regulator correctly... If it's not... Then signal loss...
I'm not sure all these VTX's are made the same... It might work on one and not another... so probably would have to experiment between different brands...
madmike8 is offline Find More Posts by madmike8
Old Feb 24, 2011, 01:13 PM
CD-ROM Junkie
Joined Apr 2001
Hey you Canadians!
You are letting some of your snow drift over into Washington!
Old Feb 24, 2011, 02:54 PM
Quebec, Canada
Joined Sep 2006
Hey you Canadians!
I think we are shoveling it too hard, sorry... or we have MIGHTY snoblowers !!
Old Feb 24, 2011, 03:31 PM
CD-ROM Junkie
Joined Apr 2001
It's OK... it's all gone now.
Discussion My training diary rballz Beginner Training Area (Heli-Electric) 50 Nov 26, 2010 03:49 PM
Discussion 3D noobie ??? mtnpilot 3D Foamies 17 Aug 19, 2010 09:23 PM
Discussion NOOBIE looking for good FPV setup. bmwNick FPV Talk 4 Sep 15, 2009 02:11 PM
Joke Dog diary vs Cat diary Tonystott Humor 5 May 17, 2007 04:42 AM
