Old Jun 04, 2012, 09:08 AM
Glenstr is offline
Find More Posts by Glenstr
Glenstr's Avatar
Canada, AB, Lac La Biche
Joined Aug 2010
Originally Posted by carguy1994ca View Post
I really like my fatsharks, but they are the base edition and IIRC you have the new version (predator or dominator). The first thing that struck me when I tried these is that i tought the image would be bigger. But the immersive feeling is the best for FPV. With a monitor I always feel less comfortable, less confidence and more easily distracted.
I think you will find flying FPV is easier with goggles, you can forget more easily about what surrounds you and concentrate more on the flying.
Yes I think you are correct, I just have to get used to the distortion from the FPV cam and compensate for objects being closer than they look. Even with the 540 fpv cam I have to keep that in mind a lot, and it's FOV is a lot narrower than the GoPro. I will make sure I have a spotter though, it's hard enough finding the plane looking up from a screen, even when I know where it is! Finding the plane (or quad) after taking goggles off would be a real challenge, especially with having to put glasses back on too.
Glenstr is offline Find More Posts by Glenstr
Old Jun 04, 2012, 09:24 AM
carguy1994ca is offline
Find More Posts by carguy1994ca
I tell her RC is cheap !
carguy1994ca's Avatar
Quebec, Canada
Joined Sep 2006
You can't remove goggles and find a plane, too dark in the goggles, too bright outside. If I may, I would suggest bringing your quad to a soccer field or similar and trying it out in the open. With a multi you can make small hops and put it down without breaking anything, this will help you adjust to the FOV and the flying qualities of the machine. Also, make sure you are ALONE. Having someone with you won't help. If you are scared of the FOV, make small hops, land, remove goggles and check where it is.
Your big slow plane would be good too if you have acces to a field large enough to stay over, but a plane goes higher/farther and easily lost. Personnally, I think the large FOV is an advantage because you feel you are far and go fast but in reality the machine is not going that far/that fast. As long as you don't go too high with the multi, you won't fear losing it (I find they are tought to get back down while keeping good control).
I think you best improvement would be to keep you away from looking at the monitor and the plane. You should, IMO, fly fully FPV or fully LOS. Not both, too much distraction trying to go from one reality to the other, too much stress. Goggles will help you achieve that.
Hope this helps
carguy1994ca is offline Find More Posts by carguy1994ca
Old Jun 04, 2012, 09:26 AM
Shadrack is offline
Find More Posts by Shadrack
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
Originally Posted by Glenstr View Post
On another note, tried the fat sharks with the #2 diopter last night and they looked quite a bit clearer, but I was in my garage, not outside, but I am still hopeful they will be good enough. Not 100% impressed with them though, the video plug needs to be pulled out a tad or there is no signal and it's a known issue. For the price of them one would think QC would be a little higher..
I glued a small o ring (or small plastic spacer like you get with apc props) over the plug that goes into the fatsharks and it works perfectly. Stops you from pushing in the plug all the way.
Shadrack is offline Find More Posts by Shadrack
Old Jun 04, 2012, 09:45 AM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
I used to have that problem. Now with the FY31 when I run RTH, it circles overhead when it gets home. Having a tracking station, I just look at where the barrel of the helical antenna is pointing and there is my plane.
Hated going from dark to light.
Old Jun 04, 2012, 09:48 AM
Quebec, Canada
Joined Sep 2006
Nice solution. But on the video tread, one had its GPS freeze, GS antenna stop tracking, brown pants moment ! I prefer to keep it simple, for me a tracker would be source for stress. They are amazing to see at work though.
Old Jun 04, 2012, 12:56 PM
Quebec, Canada
Joined Sep 2006
Hey Glen, if you really want to fly with a screen, do it the right way
http://www.rcgroups.com/forums/showp...postcount=9045
Old Jun 04, 2012, 12:59 PM
pkfoamer is offline
Find More Posts by pkfoamer
United States, CA, Huntington Beach
Joined Nov 2004
LOS vs FPV
Hope this helps
Sometimes i trim my plane while flying FPV by looking out of the haier to the area where i know where the plane is and easily find the plane....HOWEVER....I am very familiar with my flying area and have no trouble finding it. The haier permits this switch since it is not totally dark in there and the eye accomodation is fast. For most people, it is best to go totally LOS or totally FPV to avoid trying to switch out of yhe box. Dont have goggles, buy i imagine it would be very difficult to switch out of the goggs...
pkfoamer is offline Find More Posts by pkfoamer
Old Jun 04, 2012, 01:28 PM
Glenstr is offline
Glenstr's Avatar
Joined Aug 2010
I don't use a shade box around my haier, usually just stick the 7" on my GS in the shade of my truck and, and the 10" I'll put on the tailgate or just inside the box, which is also shaded because I have a canopy on it. That allows me to walk around a bit and watch screens while more or less keeping the plane in front of me. Still though, when it's 1500+ feet out it's hard to see, even when I know pretty well exactly where it is, but I should put some monokote or some paint on the wings at least, the flytron strobe really lets you know where it is usually though, when I turn it on.
I do want start flying fully immersed via goggles though, especially the heli. Starting in a big field like CG says sounds like the way to go, around my yard there is too many trees and it's too easy to hit them even when there is clear flying in front of you.
CG - I've often thought about that, using my 50" plasma for fpv would be awesome, but I don't think my wife would appreciate me moving it to the garage..
Old Jun 04, 2012, 01:58 PM
Art Newland is offline
Find More Posts by Art Newland
CD-ROM Junkie
Art Newland's Avatar
United States, WA, Bellingham
Joined Apr 2001
That is pretty darn cool. If I had more room around my place I'd have to give it a try.
By the looks of the antenna, he must be using a LRS. But the transmitter looks like a $30 FlySky.
Art Newland is offline Find More Posts by Art Newland
Quebec, Canada
Joined Sep 2006
...but I don't think my wife would appreciate me moving it to the garage..
You have to understand her, she must fear a parking accident
Old Jun 04, 2012, 01:59 PM
CD-ROM Junkie
Joined Apr 2001
Just buy a 60 inch TV to replace it with.
Old Jun 04, 2012, 02:01 PM
CD-ROM Junkie
Joined Apr 2001
Hey Glen, how about contact lens'? I contemplated them before I got the Ski goggle mod.
Old Jun 04, 2012, 02:18 PM
CD-ROM Junkie
Joined Apr 2001
My 5.8G transmitter. Arrived, time to make another. Antenna.
Old Jun 04, 2012, 02:35 PM
Quebec, Canada
Joined Sep 2006
Looks as small as my 200 mW 900 mHz Vtx. What power does it have, and what distance you think it can do ? Also, how is your experience with fying near/behind objects like tress with this ?
Old Jun 04, 2012, 02:40 PM
CD-ROM Junkie
Joined Apr 2001
It is a 200 mW, as for the other questions... TBA.
BTW, your last video was really good. You TRI appears to be flying very well and picture looks great.
Discussion My training diary rballz Beginner Training Area (Heli-Electric) 50 Nov 26, 2010 02:49 PM
Discussion 3D noobie ??? mtnpilot 3D Foamies 17 Aug 19, 2010 08:23 PM
Discussion NOOBIE looking for good FPV setup. bmwNick FPV Talk 4 Sep 15, 2009 01:11 PM
Joke Dog diary vs Cat diary Tonystott Humor 5 May 17, 2007 03:42 AM
