Old Mar 14, 2011, 11:31 PM
carguy1994ca is online now
Find More Posts by carguy1994ca
I tell her RC is cheap !
carguy1994ca's Avatar
Quebec, Canada
Joined Sep 2006
LC filter, battery, motor for Stryker ordered ! All this will set back my hobby cash reserve a bit...
I'll tell ya I'll be cautious with the next FPV plane, this one will fly close for a while and be tested thorouly !
carguy1994ca is online now Find More Posts by carguy1994ca
Old Mar 15, 2011, 11:45 AM
Art Newland is offline
Find More Posts by Art Newland
CD-ROM Junkie
Art Newland's Avatar
United States, WA, Bellingham
Joined Apr 2001
I think that this is very important, small steps, getting more and more experianced flying FPV and testing your equipments capabilities as you go. I've had a couple of flights that didn't go as expected, if I had been a long way out, I would have probably lost or crashed the plane. FPV takes a lot of concentration, anything that takes your attention away from flying can bring lots of trouble... getting lost, etc.
Art Newland is offline Find More Posts by Art Newland
Old Mar 15, 2011, 12:33 PM
rcmonster99 is offline
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
Spot on commander
OK so I talk a lot but don't show much so here is a little fun and games for you from the UK , hope you enjoy
FPV fun, the beauty and the beast (6 min 25 sec)
rcmonster99 is offline Find More Posts by rcmonster99
Old Mar 15, 2011, 12:58 PM
Quebec, Canada
Joined Sep 2006
I think all my steps were fine until I tried fleying at a new location. I should have done the following:
- Inspect the video system connectors and antennas (since i lost video signal, it may have something to so with the problem)
- Fly LOS with a flycam to see the view of the field and recognize the landmarks (what you did at the beginning Art, as well as I at my club field since I had flown there with flycams for 2 years)
- wait for a calmer day to try the new place.
- Fly LOS while recording video signal to see if there was interference at that location.
Hope this will help others avoid the mistakes I made and will help them keep their plane.
Old Mar 15, 2011, 02:16 PM
CD-ROM Junkie
Joined Apr 2001
Very nice RCM, thanks for the entertainment. Looks like you have a wonderful place to fly.
I always have Chuck, or anyone handy watch the monitor while I fly around LOS if I'm trying something new, quipment, placement, etc. If the video link looks OK I do some FPV. Sounds like you were using your monitor, not the goggles, that's a good idea so you can look to the sky in a hurry if you have to. It's still very difficult to find the plane without a spotter. Sounds like a lot of guys use google earth to get a good veiw from the air before trying to fly in new areas. I did this before taking the slow stick out on the mission over the ponds. Not sure how much that helped as was too windy to fly much FPV anyway, and I'm pretty familiar with the area anyway. I do have a few flying sites lined up for future missions with permission from the owners for when the weather gets better.
Old Mar 15, 2011, 03:27 PM
Quebec, Canada
Joined Sep 2006
I looked at the monitor yes and tought it was safe enough. But as soon as you fly FPV you go farther than LOS and then there is wind and the cloudy sky with the white plane and....
Google must help but I found that when flying there (the new spot), I thought I was over a football field when in fact I was before the field, because the camera looks horizontally and therefore if you are over something, you don't see it, you see beyond it, so you always have to think where the plane is relative to you and it becomes hard after only several seconds of flying FPV in a unkown place. So it can be tough to find out.
BTW, thinking of a very flashy paint job on the Stryker...
Old Mar 15, 2011, 05:34 PM
Houba ! Houba !!
Joined Sep 2003
I personally think the looking around in googlemaps or earth is a total waste of time,
1) google imaging is fairly old, so some landmarks have changed since the last time the area has been snapped
2) the maps are not seasonal. what looks evergreen permanently green fields could be yellow rapeseed in spring which becomes black in automn, so, again..no real landmarks
3)the maps are always oriented so North is at the top of the screen...the plane doesn't do that ....
4) there are many other reasons i guess
the fact is you go up there with a recorded image in your head of the airspace around you and... BAM you find yourself in a totally different Universe
the best way is to do what Art did at the beginning, that is , take aerial shots from your plane whaile flying LOS and then use a spotter to guide you .
Old Mar 15, 2011, 05:51 PM
Glenstr is offline
Find More Posts by Glenstr
Glenstr's Avatar
Canada, AB, Lac La Biche
Joined Aug 2010
I ordered some cheap led strings from HK, thinking about running a different color down each side of the bottom of the fuse and/or wing. Also ordered this little strobe from flytron
Glenstr is offline Find More Posts by Glenstr
Old Mar 15, 2011, 06:08 PM
balsabuster2004 is offline
Find More Posts by balsabuster2004
balsabuster2004's Avatar
Washougal, Washington, United States
Joined Jan 2004
Google must help but I found that when flying there (the new spot), I thought I was over a football field when in fact I was before the field, because the camera looks horizontally and therefore if you are over something, you don't see it, you see beyond it.
You need a 2nd camera looking down, and a video switcher. Here's a video with a "looking down" camera. Unfortunately, If you fly at our field where your're supposed to (avoid flying over buildings, parking lot, pit area) there aren't many recogizable landmarks.
Yeah, I know the altimeter isn't right - not sure why.
Feb 21 down.MOV (4 min 5 sec)
balsabuster2004 is offline Find More Posts by balsabuster2004
Old Mar 15, 2011, 06:27 PM
Joined Jan 2004
Strobe
We need a full report on how the strobe works out.
Old Mar 15, 2011, 06:51 PM
CD-ROM Junkie
Joined Apr 2001
Would really like your feedback on the Flytron LED strobes, I'll by some if you can really see them like they say.
Old Mar 15, 2011, 07:36 PM
Glenstr is offline
Glenstr's Avatar
Joined Aug 2010
Will do, not sure how this new plane will be as it's a lot bigger than my super cub, which I find farily easy to lose orientation with when it gets way out there, given though, that a lot of that is because I'm not that experienced at this.
Anyway, for the price I figured it was worthwhile for me to try, can't hurt anyway.
Old Mar 15, 2011, 10:13 PM
CD-ROM Junkie
Joined Apr 2001
On a side note, I can be off topic... it's my thread! This info is FWIW.
After playing with my buddies new charger, I was impressed enough with it I bought one of the single output versions. Still capable of 550 watts (most chargers are lucky to do 80) and charging up to 14S in 7 cell packs connected in series. I really think it's wise to balance charge when possible, especially if you are charging at high current. On 12 volt input it is only capable of about 220 watts (can handle 29 v in), but that's still a 5000 mA 12S pack at 1C. I experimented a bit tonight while installing the tail on the senorita, charged 2 4S-4900 packs in series (8S) at 4.9 amps. The charger was pulling 17.5 amps off of my old converted PC power supply. I'm amazed the PS could continue to deliever that kind of current for any length of time, it's rated for 9 amps on the 12 volt output. With only 18 gauge wire on the PS output, it got a little warm. I've been reading the 12v 100 amp PS thread and decided to pick up a more powerful server PS. I bought one of these off ebay;
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
Good for 72 amps, and what I read is they are series-able (madeup word), could hook two of them together for 24 v output. No conversion needed.
http://www.rcgroups.com/forums/showp...&postcount=457
Old Mar 16, 2011, 12:18 AM
Quebec, Canada
Joined Sep 2006
You'll soon hook up directly on the utility pole
Old Mar 16, 2011, 12:19 AM
Quebec, Canada
Joined Sep 2006
They usually blink....
sorry, I'm tired I guess...
Stryker is painted lemon yellow. It will not blink but it will be visible !
Discussion My training diary rballz Beginner Training Area (Heli-Electric) 50 Nov 26, 2010 02:49 PM
Discussion 3D noobie ??? mtnpilot 3D Foamies 17 Aug 19, 2010 08:23 PM
Discussion NOOBIE looking for good FPV setup. bmwNick FPV Talk 4 Sep 15, 2009 01:11 PM
Joke Dog diary vs Cat diary Tonystott Humor 5 May 17, 2007 03:42 AM
