This thread is privately moderated by jj604, who may elect to delete unwanted replies.
Old Aug 15, 2010, 07:08 PM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Data
How to convert Server Power Supplies
Thought it might be useful to gather this in the one place.
The practice of converting computer SERVER power supplies to make a very high quality high power supply at low cost is attractive. It doesn’t normally require any modification to the supply but the hard part is figuring out how to trick them into turning on. Far and away the best way is to find someone who has already done it. I have put down a few references I know about and welcome additions.
This is about SERVER supplies which often have large 12V capacity and not much else; it is NOT about converting normal PC power supplies. (The ‘ground the green wire and add a load resistor’ stuff). That is covered extensively elsewhere.
UPDATE There are now available supplies for PCs that have substantial 12V rails and large (850-1200 Watt) capacity that work without any electrical conversion. If you have used one of these, suggest you start a separate thread.
Please, please. This is a REFERENCE thread. Just post a link (with comments) to other posts that show how to do it if you know of one that isn’t here.
IF YOU HAVE AN OPINION OR JUST WANT TO COMMENT OR HAVE A QUESTION ABOUT CONVERTING A PARTICULAR SUPPLY please do it somewhere else (like the original threads for example or PM me). Obviously info on sources of supply for these devices is welcome though – please post that if you know it, as well as any errors that need correcting.
Bottom Line: If you have an unknown supply you need help with, try a post in the original 12v 100A supply thread (link 2 below) which seems to have a good range of posters - or start a new one with a specific title that includes your question. That thread now has some good info on how to solve an unknown supply as well. See the first few posts. When/if you ever get it to work, then post the link to that info here to make it easier for others to find.
If you have an unknown supply and can't find the information from someone who has already solved it then this post contains the best information/links on how to establish which pins might turn it on and control the output voltage.
http://www.rcgroups.com/forums/showp...87&postcount=7
UPDATE: This one contains additional information that is more useful.
http://www.rcgroups.com/forums/showp...&postcount=570
Hope this proves useful.
John
Best post on how to deal with an unknown supply
http://www.rcgroups.com/forums/showpost.php?p=18002964&postcount=570
Various threads containing information on converting different supplies.
1) The original IBM Series 235 Supply which started it all.
http://www.rcgroups.com/forums/showp...33&postcount=3
2) A simple high quality 12Volt 100Amp Power Supply thread starts here
http://www.rcgroups.com/forums/showp...97&postcount=1
This is my thread on the HP PROLIANT DL580/ML570G3 which is a 12V 1300Watt supply. It's still my favourite for quality, power, small size and having a proper plug for the power cord BUT it's extremely noisy because of the two small high speed cooling fans. Most people will find its vacuum cleaner impression a PIA. Note that you have to take care to identify exactly which supply by the part number. There is a range of DL580 computers with different supplies.
3) The Compaq HP ESP114 Series 12V 55A Power Supply thread starts here
http://www.rcgroups.com/forums/showp...73&postcount=1
This is earlb's thread on converting these. Was popular popular and remains a good solution. Decent power but much quieter because they are bigger. Easier to obtain and cheaper as well
The attached picture shows the HP 1300 Watt and ESP114 side by side (thanks earlb). The SMALLER one is the more powerful 1300W supply.
4) Dell A570P-00 570W
http://www.rcgroups.com/forums/showp...postcount=3354
5) Compaq Proliant 169286-002 750W
http://www.rcgroups.com/forums/showp...&postcount=128 plus
http://www.rcgroups.com/forums/showp...&postcount=141
6) Sony APS-111 12V 33.3A (Used in CISCO gear). Also known as Ascom Energy Systems Galaxy D0009237
http://www.rcgroups.com/forums/showthread.php?t=800379
7) HP Power Supply DPS-600PB/700CB
http://www.rcgroups.com/forums/showp...&postcount=253
8) hp PS-3381-1C1 PSU
http://www.rcgroups.com/forums/showt...=358340&page=2
9) My current recommendation is the HP model DPS-600PB series ESP135 PS that is used in ProLiant DL380 G4 Rack Servers. It is rated at 575W, or 47A at 12V. It is compact, quiet and powerful and is easily modified to slow the fan down and isolate the DC out to make a 24V supply from two of them (see below under using two supplies). There is a detailed how-to on T Jin Tech's page here https://sites.google.com/site/tjingu...projects/HP47A and feathermerchant has them as single or dual (24V) supplies. Akshu's thread (#11 below) on a kit to convert two supplies to 24V uses these ones. They are in the bottom left hand picture below.
Using two supplies in series to get 15 or 24V at high power.
Two of the DL580/ML570G3 supplies for example will supply 2600W at 24V on a 240V supply! Here’s the thread I started on the practice of connecting two supplies in series to get 24 Volts at high current. Becoming more relevant with the growth of 1000Watt chargers.
http://www.rcgroups.com/forums/showthread.php?t=1170241
Feathermerchant on the forums sells these already made up if you don't feel you have the knowledge to do it yourself.
WARNING
These supplies were never designed to be run in series. Here's a quote from someone who knows what he is talking about. Now we know much more about the internals of these supplies, the DC isolation method (see below) is preferable if you know what you are doing.
I must admit, I am more than a little concerned these days about folks connecting different power supplies in series without a full understanding of the dangers. High powered chargers demand more power, and to get it many people having heard of this practice are haphazardly connecting power supplies in configurations for which they were not designed for and have not been tested or CE certified.
All we can do is fight the good fight and continue to educate people. Every week now I get a call or two with a story about series connecting two random, disparate power supplies in an attempt to get more power - with varying success. I sincerely hope the chances of disaster are infinitesimally small and that most all modern supplies have adequate protection built in to avoid anything catastrophic. My concern is for the people playing around modified industrial or hobby grade equipment who don't understand the physics involved and that their actions may be potentially dangerous.
10) Using two power supplies for higher voltage/capacity chargers: safety issues
http://www.rcgroups.com/forums/showpost.php?p=13992510&postcount=1
See post 183 in particular for conclusions.
An alternative approach that is intrinsically safer
11) And here is discussion of an alternative approach which floats the OUTPUTS rather than modify the inputs.
It has developed into a nice solution with a kit of parts available to make a twin 24V 47A system. Thanks akshu
http://www.rcgroups.com/forums/showthread.php?t=1369612
racerxky has photos of how to isolate the OUTPUT of my original HP PROLIANT DL580/ML570G3 (12V 1300Watt) supply in Post #2 above here:
http://www.rcgroups.com/forums/showp...&postcount=678
Here's a thread on using two Dell PE6800 supplies - they are the JD200 model
http://www.rcgroups.com/forums/showthread.php?t=1452524
This is an intrinsically safer solution but does require significant disassembly and work on the supply. You can use the opportunity to add a resistor to the fans though and quieten them down a bit!
jj604 is online now Find More Posts by jj604
Old Aug 15, 2010, 08:18 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Reserved for updates and additions
I'll move the URL's from stuff that people add or more that I find into this post for easy reference from time to time. Only the stuff that isn't already on this first page so check the first 10 posts at least.
UPDATE: This thread is staying pretty focussed and to the point (thanks guys) so it is no big hassle to scan right through it. I won't move any more posts into this one for now.
1) Compaq Model DPS-450BB ( Delta Model number DPS-450BP)
Series ESP104
P/N: 401401-001
Spare/N: 101902-001
http://www.rcgroups.com/forums/showthread.php?t=1076321
2) Some additional info on the ground pins on the = HP Power Supply DPS-600PB
http://www.rcgroups.com/forums/showp...&postcount=312
3) Someone posted a useful link on the 100A supply thread.
It is an article, Modifying Hewlett Packard Server Power Supplies for Ham Radio Use which documents the modification of 2 types of Hewlett Packard switching power supplies to enable
their use as power sources for ham radio equipment. The article is intended to provide experimenters with the information necessary to modify successfully the following
types of power supply:
Hewlett Packard HP-194989 (400W, 32A max. on the 12v line)
Hewlett Packard HP-280127 (325W, 26A max. on the 12v line)
It contains some useful info on figuring out how to make them operate logically rather than by trial and error.
http://www.qsl.net/w8zpf/Files/Powersup.pdf
UPDATE: The link above no longer works but I have added the 3 page article to this post.
UPDATE: Here is a link which does work
http://ohiopacket.org/files/docs/Powersup.pdf
Thanks wbefield.
4) Dell NPS-730AB 12V 60A supply
http://www.rcgroups.com/forums/showp...&postcount=375
4) HP/Compaq Proliant DL380 G4 575w Power Supply, 406393-001
Series ESP135 Model No PS-3601-1C GPN:367238-501 PartNo:366982-501 Spares No:406393-001
http://www.rcgroups.com/forums/showp...&postcount=385
5) TJinTech has a "how to" on the HP model DPS-600PB series ESP135 PS and also using two to get 24V with detailed instructions on his web site at
https://sites.google.com/site/tjingu...arging-how-tos
6) Dell Server PSU - Model NPS330BB A
http://www.rcgroups.com/forums/showt...light=nps330bb
7) How To for Dell NPS-730AB A REV A01
taken from Dell Power Edge 2600
max 13,5 Volt 60 Amps
http://www.rcgroups.com/forums/showt...b#post17197180
8) Dell PowerEdge 2850 power supply, 12V 57A (700W)
Model #: Dell NPS-700AB
http://www.rcgroups.com/forums/showp...&postcount=408
9) HP ESP-115 (30 amps)
http://www.rcgroups.com/forums/showp...&postcount=379
10) Fujitsu-Siemens Primepower 450 server ps
http://www.rcgroups.com/forums/showthread.php?t=1263123
11) Dell 7000814-0000 700W PSU
http://www.rcgroups.com/forums/showp...&postcount=154
12) Hp PS3381-1C1 PSU
http://www.rcgroups.com/forums/showp...92&postcount=7
13) HP 511777-001 460W 12V PSU
http://www.rcgroups.com/forums/showp...&postcount=167
14) Dell ASTN 7000245 Poweredge 6650 PS for 72 amps at 12v.
http://www.rcgroups.com/forums/showp...&postcount=457
15) Esp 108 (DPS-450cb) PSU full pinout
http://www.rcgroups.com/forums/showthread.php?t=1005309
Original post at
http://www.rcgroups.com/forums/showp...3&postcount=13
16) Dell Poweredge 6650(7000245) PS - Voltage Adjust
http://www.rcgroups.com/forums/showp...&postcount=654
17) Dell Power Edge 4600 Server PS
See two posts 601 and 602 here
18) Dell DPS-500CB A
http://www.rcgroups.com/forums/showp...&postcount=811
19) Delta DPS800GB-A
Posts 880 and 881
Old Sep 28, 2010, 03:08 PM View Post
lmlisak
A moderator felt this post violated the following rule: Off Topic Advertisement. It is temporarily hidden while lmlisak edits it. Show it to me anyway.
Old Dec 29, 2010, 05:01 AM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
People looking for info on particular supplies
Don't forget to post back a link when you get it to work.
Then I can delete it from here.
Old Feb 15, 2011, 09:40 PM
tjinguy is offline
Find More Posts by tjinguy
TJin(Guy + Tech)
tjinguy's Avatar
United States, NM, Socorro
Joined Jun 2008
I have added the Dell model AA23300 550W unit to my page.
http://www.tjinguytech.com/my-projects/server-ps
It has the same hot-swap connector wiring as the NPS-700AB, which is also on the page.
tjinguy is offline Find More Posts by tjinguy
Old Feb 20, 2011, 06:53 PM
KiloOne is offline
Find More Posts by KiloOne
Dale Kramer
KiloOne's Avatar
United States, NY, Hammondsport
Joined Jul 2004
NPS-700AB Dell 2850 fan switch
I think the below picture shows how to add a fan switch to go from 'JET' speed to 'OK' speed.
http://www.rcgroups.com/forums/showp...&postcount=444
KiloOne is offline Find More Posts by KiloOne
Old Feb 21, 2011, 06:08 PM
KiloOne is offline
Dale Kramer
KiloOne's Avatar
Joined Jul 2004
Automatic fan speed solution for DELL 2850 series
http://www.rcgroups.com/forums/showp...&postcount=450
Old Apr 12, 2011, 08:26 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Some big ones
Poweredge 6800 Full Pinout DPS-1570AB
Poweredge 6850 Full Pinout
Poweredge R900 Full Pinout
http://www.rcgroups.com/forums/showt...9#post17954027 Posts 548 - 550
These are fairly large 120-140A supplies (some only work on 220V) with adjustable output voltage to 13.8 - 14V with NO FANS so they are quiet.
xandrios is posting some great info on supplies in the thread
A simple high quality 12Volt 100Amp Power Supply- Part1
(use the link above).
Old Apr 22, 2011, 07:58 AM
xandrios is offline
Find More Posts by xandrios
Steven
xandrios's Avatar
United States, CT, East Hartford
Joined May 2010
DPS-600pb ESP135 PSU voltage and fan control.
http://www.rcgroups.com/forums/showp...&postcount=586
xandrios is offline Find More Posts by xandrios
Old May 02, 2011, 04:49 AM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
IBM Bladecenter 39Y7352 2000w PSU DPS-200BB A Pinout
Pinout for the IBM Bladecenter 39Y7352 2000w 200v-240v only PS.
All of the important pins are included.
Maximum output current is 164A at 12.2v. Voltage is adjustable up to 14.6v.
Since this PS doesn't have an internal fan, you MUST mount one externally.
NOTE
xandrios advises "It seems that only revisions S8M and lower go to 14.6v.
Higher revision numbers can only reach 13v."
http://www.rcgroups.com/forums/showp...&postcount=611
Old May 15, 2011, 03:50 AM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
More from xandrios
ColdWatt 650w CWA2-0650-IT01 and Intel SR1550 PS Full Pinout
Full Pinout for Delta DPS-830AB PS.
Full Pinout for Delta DPS-650QB PS.
Dell Poweredge T710 R910 PS Full Pinout
DPS-500EB PS Full Pinout
Delta DPS-750EB PS Full Pinout
Delta DPS-450GB Full Pinout
Delta DPS-850FB PS Full Pinout
Delta DPS-730AB PS Full Pinout
Delta DPS-350PB Full Pinout
Posts 679-710 here
http://www.rcgroups.com/forums/showt...9#post18238944
Delta DPS-520BB Full Pinout. Post 730
Delta DPS-600DB Full Pinout. Same as Delta DPS-450CB. Post 729
Full Pinouts for several 3Y Server PSUs.
Pinouts for 3Y YM-2102ABR/AAR, YM-2102BBR, YM-2721ABR, YM-2821ABR, YM-2651BAR/CAR/CBR and YM-2451DAR/DBR PSUs.
Post 899
Last edited by jj604; Aug 28, 2011 at 05:16 PM. Reason: xandrios keeps adding new supplies!
Old Jul 22, 2011, 08:28 AM
DonA is online now
Find More Posts by DonA
DonA's Avatar
United States, CA, Placerville
Joined Feb 2006
See post #365 for information on increasing the voltage output of the Compaq HP DL580 Proliant Server Power.
http://www.rcgroups.com/forums/showthread.php?t=1170784
Don
DonA is online now Find More Posts by DonA
Old Jul 30, 2011, 03:36 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
OVP disable and Fan speed control modifications for several power supplies
Delta DPS-700EB PS OVP disable modification.
http://www.rcgroups.com/forums/showp...&postcount=844
Poweredge 6800 KD175 PS OVP Disable modification
http://www.rcgroups.com/forums/showp...&postcount=606
Poweredge 6800 PSU KD175 Fan Speed Control mod
http://www.rcgroups.com/forums/showp...&postcount=610
Poweredge 6800 JD200 PS OVP Disable modification
http://www.rcgroups.com/forums/showp...&postcount=939
Poweredge 6800 PSU JD200 Fan Speed Control mod
http://www.rcgroups.com/forums/showp...&postcount=940
Old Aug 08, 2011, 10:02 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
A neat case solution for twin supplies
Slightly OT but here's a solution I thought was very neat for people building twin 24V supplies. A lot simpler and quicker than starting from scratch.
http://www.rcgroups.com/forums/showp...&postcount=225
Old Aug 21, 2011, 01:14 PM
jointer is offline
Find More Posts by jointer
Czech Republic, Hlavní město Praha, Prague
Joined Oct 2010
HP fanless units.
All these versions have the same connection layout.
Models:
ESP128, 280127-001, 305447-001, 26 Amp (325W)
DPS-460BB B, 361392-001, 325718-001, 36 Amp
DPS-525EB A, 389997-001, 384232-001, 42 Amp
http://www.rcgroups.com/forums/showthread.php?t=1465371
It is difficult to effectively cool them, if anyone is looking here for list of "known" PS, i would recommend something with integrated fans.
These might be good if the plan is to build them inside a custom case.
jointer is offline Find More Posts by jointer
How to make own Power supply at home? convert from PC power supply? HumbleBoss Batteries and Chargers 16 May 01, 2016 02:13 PM
Discussion Convert Server Power Supply mt_100 DIY Electronics 28 Aug 19, 2010 01:03 PM
Discussion Help how to convert to Electric PT-20 Great Planes anteka Glow to Electric Conversions 1 Jul 25, 2010 11:07 AM
