Old Aug 15, 2010, 06:26 PM
RedStarArmy is offline
Find More Posts by RedStarArmy
RedStarArmy's Avatar
United States, NJ, Middlesex
Joined Feb 2008
Enya .25 & to .50 xcn
Hey, I just got the enya .25 and .50 engines from a friend of a friend who doesn't fly anymore. The .50 is NIB and never taken out and the .25 was mounted in an old great planes super sportster kit but never ran (i got the plane too). I currently only have an evo .46 and os 55ax engines and all my experience comes from them. Anything I should be aware of with these? do the carbs work the same as on the evo or os? Do i tune them the same..etc etc. The .25 box says .25 xtv, and the .50 is xcn I believe.
Also, what are the best props from either of them.
And I'll be using omega 15% fuel, whats the best plug for them. Is it the enya #3 or #4 and where is a good place to buy them.
RedStarArmy is offline Find More Posts by RedStarArmy
Old Aug 15, 2010, 06:50 PM
Broken Wings is online now
Find More Posts by Broken Wings
Broken Wings's Avatar
United States, FL, Cocoa
Joined Jan 2006
Nice Score!
It sure is a good looking engine.
Broken Wings is online now Find More Posts by Broken Wings
Old Aug 15, 2010, 06:51 PM
Joined Jan 2006
Enya Engine 50CX ABC Two Stroke
An extremely powerful 50 sized two stroke.
The choice of many experts show flyers. Both Paul Heckles and Simon Clayton used this engine for display flying. The ENYA 50CX is brilliant for 3 D or patternship aerobatics because of its excellent throttling characteristics. As usual with Enya - It is hard wearing and very relaible With TN carb and silencer included. We recommend 5 to 10 percent Nitro and an enya Number 3 or number 4 plug.
Try the Bolly Clubman 11.5 x 7 or 12.5 x 6 on this engine for sport flying.
Wot 4's, Acro Wot's, Limbo Dancers, Tai Ji's, Groovy 50's love this engine !
Displacement 8.33 cc
Bore 22.8 mm
Stroke20.4 mm
Weight 380 g
Useful RPM 2,500 to 16,000 rpm
Power : 1.4 HP *
Recommed Use :Sport, trainer, scale and aerobatic aeroplanes
Note : Factory 'Useful' power figures quoted. Without exception when tested in various magazine and independent engine reviews * Enya Engines always have a higher HP than qouted in tested factory figures
Old Aug 15, 2010, 09:11 PM
buzzard bait is offline
Find More Posts by buzzard bait
United States, NY, Ithaca
Joined Sep 2007
That's a good strong 25. Only issue could be that the muffler isn't that good, so may be noisy. Great engine...worth getting a Macs strap muffler for it, which is quieter with no weight gain.
Jim
buzzard bait is offline Find More Posts by buzzard bait
Old Aug 16, 2010, 12:18 AM
downunder is offline
Find More Posts by downunder
downunder's Avatar
Adelaide, South Australia
Joined Sep 2003
The 25 sounds as though it's the earlier 25X which would look similar to my 19X below. I'm not totally certain but I think the 25X uses a cast iron piston the same as the 19X. If it has the iron piston then don't use that Omega fuel without adding quite a bit of castor or you'll kill it. The Omega has some castor but no where near enough and the total oil is only 17% anyway. Add enough castor to bring the total up to 20% at the very least, preferably closer to 25%, and you'll never wear it out. As it's a new engine, and if a cast iron piston, then it needs quite a bit of careful running in starting as rich as you can get it for the first few runs and very slowly leaning it out for at least an hour.
The 50CX is ABC so should survive OK on the Omega, just don't let it go lean.
downunder is offline Find More Posts by downunder
Old Aug 16, 2010, 03:54 AM
Boomerang1 is offline
Find More Posts by Boomerang1
You made that out of trees?
Boomerang1's Avatar
Sydney Australia
Joined Mar 2005
Is the Enya 50 CX ABC or AAC?
I had a pair of the 45 CX engines & they were AAC. Great engines, powerful & easy to handle.
I used them in sport class pylon racers & with the required 10 x 6 prop they used to scream. - John.
Boomerang1 is offline Find More Posts by Boomerang1
Old Aug 16, 2010, 09:23 AM
Joined Feb 2008
The 50cx is abc, i know that for sure.
How do I go about finding out for sure if my .25x has a cast iron piston? I can't seem to find anything online about it. The engine was bought new some time on the late 90s...if that helps.
Old Aug 16, 2010, 05:29 PM
Joined Jan 2006
A magnet should tell you.
Old Aug 16, 2010, 08:50 PM
downunder's Avatar
Joined Sep 2003
Yep, either a strip off a rubber fridge magnet slipped through the exhaust port onto the top of the piston or one of those really strong magnets like they use in a computer hard drive laid against the cylinder fins will soon let you know.
Old Aug 16, 2010, 10:37 PM
Joined Feb 2008
hmm..interesting. I assume if it sticks, it can only be iron?
Old Aug 17, 2010, 12:09 PM
jbryan80 is offline
Find More Posts by jbryan80
Joined Jul 2010
Magnetism, at least for purposes of this discussion, is a property that is peculiar to iron and a very few other metals. If a magnet sticks to a metal, then the metal is not copper or aluminum. This particular type of magnetism is called "ferromagnetism", from the Latin word for iron (ferrum, symbol Fe).
Other elements that are ferromagnetic at room temperature are nickel, cobalt and gadolinium, according to Wikipedia, for what it's worth.
jbryan80 is offline Find More Posts by jbryan80
Old Aug 17, 2010, 04:05 PM
iluv2fli is offline
Find More Posts by iluv2fli
Joined May 2010
Nickel and Cobalt are classified as ferromagnetic according to all my College chemistry books.
Those powerful magnets will attract a nickel plated liner. The magnets from a microwave oven magnetron are a lot more powerful.
iluv2fli is offline Find More Posts by iluv2fli
Old Aug 17, 2010, 06:08 PM
downunder's Avatar
Joined Sep 2003
No they won't because I just tried it on a spare OS liner.
Old Aug 17, 2010, 07:50 PM
Artisan is offline
Find More Posts by Artisan
NM2K
Ringgold, GA, USA
Joined Jan 2006
Jim
It is easy to forget that the more power an engine generates, the more noise it will generate too. That muffler on another, less powerful engine, might be surprisingly quiet.
Ed Cregger
Artisan is offline Find More Posts by Artisan
Old Aug 17, 2010, 11:43 PM
the pope is offline
Find More Posts by the pope
Australia, SA, Adelaide
Joined Sep 2007
Howdy there Downunder, does that mean u have a few OS`s lurking in the cupboard? I didnt know u were that way inclined. Cheers the pope PS I have recently joined NMAS so were almost neigbours
the pope is offline Find More Posts by the pope
Reply With Quote  (Disabled)
Discussion Ken Enya of Enya Engines sarg96 Vendor Talk 2 Jul 24, 2010 11:20 AM
Sold Enya 50 great cond. craigbalex Aircraft - Fuel - Engines and Accessories (FS/W) 3 Jul 15, 2010 11:22 AM
Sold enya .25 bth9318 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Feb 03, 2010 06:15 PM
For Sale Hanger 9 Cessna 182 ARF Red/white Enya 50 cx RTF heli123 Aircraft - Fuel - Airplanes (FS/W) 1 Jan 29, 2010 02:01 PM
For Sale MUFFLERS: ST 25, K&B 40, OS 50 60 61 FSR, ENYA 60 X, FOX 60 EAGLE, & .120 TWIN Daveairway Aircraft - Fuel - Engines and Accessories (FS/W) 1 Feb 25, 2009 06:30 PM
