Old Aug 15, 2010, 05:52 PM
MrE
United States, WA, Gig Harbor
Joined Aug 2007
Wrong cell count on Phoenix HV140
Ive got a new Phoenix HV 140 and just up-dated the firmware and powered it up for the first time for a bench test.
On a 1/2 charged (19 volts) 5S pack Im getting 10 beeps for the cell count.
Ive tried 3.24 and 3.20 with the same results.
Cut off is set to auto lipo 3.2 volts per cell.
I'll try some other pack sizes and settings but I was wondering if anyone else has seen this issue or if its just me.
Thanks.
MrE is offline Find More Posts by MrE
Old Aug 15, 2010, 06:29 PM
MrE
Joined Aug 2007
Ive tried a variety of different settings and they all behave the same way.
With a 5S pack I get 10 beeps.
With a 7S pack I get 3 beeps.
With a 10S pack I get 6 beeps.
Must be something wrong with this controller which is a bummer.
It seems to start and run the motor ok with no load. Havent tried it with a prop. Where there is one problem there may be others so I guess I'll send it back.
Old Aug 15, 2010, 06:36 PM
A man with too many toys
United States
Joined Feb 2001
I don’t think that the cell counter was intended to be used with 1/2 charged packs. Using a HV ESC with such a low voltage may be causing the auto cell counter a problem.
I always use the Castle Link to manually set the exact cutoff voltage that way I know it will always be correct. When you manually set the cutoff voltage it turns off the auto-count feature and you won’t get the cell count tones.
RC Man is offline Find More Posts by RC Man
Old Aug 15, 2010, 06:47 PM
MrE
Joined Aug 2007
Normally I do like you and set the voltage myself but Im playing with different setups on the bench.
I'll try it again with fully charged packs and see if thats the problem. You could be correct on that - although how it decides a 5S is 10 beeps and a 7S is 3 beeps makes me wonder
Old Aug 15, 2010, 09:13 PM
MrE
Joined Aug 2007
Fully charging the packs didnt fix it but it did change the count.
Fully charged 5S gives 11 beeps and fully charged 10S gives 8 beeps.
Its broke.
Old Aug 16, 2010, 04:44 AM
United States
Joined Feb 2001
Maybe you could try downloading the software again and reloading the firmware. Maybe the firmware got scrambled or you got a bad download.
Old Aug 16, 2010, 09:00 AM
Patrick del Castillo's Avatar
Olathe,KS,USA
Joined Oct 2000
Yes -- sounds broken...
Try reloading the software like RC Man suggested, and if that doesn't help, contact us for a replacement.
Thanx!
Patrick
Patrick del Castillo is offline Find More Posts by Patrick del Castillo
Old Aug 20, 2010, 11:29 PM
MrE
Joined Aug 2007
I tried re-loading the firmware with no change. Called support and they sent me a replacement ASAP along with a return envelope to send the bad one back.
1st class service - as usual
Question cell count for easy star with stock 400 motor pgls421 Foamies (Kits) 4 Aug 06, 2010 05:37 AM
Help! Turnigy Accucel 6 wrong cell count for 3s jeff77789 Batteries and Chargers 22 Jun 07, 2010 04:13 PM
Discussion Astro 109 and wrong cell count CPing Batteries and Chargers 27 Mar 23, 2006 11:08 AM
6-330d wrong cell count simon109 Batteries and Chargers 0 Mar 27, 2004 05:23 AM
Wrong cell count causes fire. hoppy Batteries and Chargers 15 Jan 25, 2004 10:16 PM
