Old Aug 03, 2011, 11:02 PM
rowdyjoe is offline
Find More Posts by rowdyjoe
rowdyjoe's Avatar
Arlington, TX
Joined Jul 2009
I have not been able to find the programming instructions for the stock "Topfire" ESC and my programing card won't read it. When trying to determine which programming sequence it uses I get nothing ...no beeps at all with throttle all the way up. Maybe it's not programmable?
I did manage to set the throttle though. It took two tries but, the motor now starts up right off the bottom instead of 1/4 stick up.
Hyperion will likely list the programming instructions on their web site so searching that should get you where you want to be.
Higher timing will give you higher RPM/kv but, on occasion, there's a point of diminishing return (depends on your system). Sometimes on "high" timing it will draw more amps than you get in return for shorter battery life. When that's the case, I usually drop it down to "mid" or sometimes "low". It all depends on what your watt meter tells you when you run it up.
Also watch your battery temp. I lowered the timing on my Mig 15 because the 30C batteries I was using were getting way to hot.. I puffed one pretty good and probably ruined it. Most of the EDF "experts" I know recommend at least 35C batteries for EDFs. I've been getting away with the cheaper 30C batteries ...until now.
My Mig 15 needs at least 40C for high timing as I'm running a Hobbywing 80amp ESC and a Cyclone 3700kv motor with a SAPAC 70mm fan. That system really makes the bird move out well but, it also draws a lot of juice doing it. I'm showing 70amps and 1050 watts at WOT on 4S 3600mah 30C.
When my larger capacity batteries come in I'll set the timing back to high.
RJ
rowdyjoe is offline Find More Posts by rowdyjoe
Old Aug 08, 2011, 02:05 AM
rowdyjoe is offline
rowdyjoe's Avatar
Arlington, TX
Joined Jul 2009
Shipped !!!!!
Finally got confirmation of shipment for my F86. I placed the order on 8/2/2011.
It's being shipped via EMS and, according to the message, it will take about 4 to 5 days to arrive at my house. I should be able to track it tomorrow (I hope).
This is the newest version that comes with e-tracts (instead of the leaky air retracts) but, from what I can tell via pictures, ti's the same bird as the Venom. I have an unassembled "kit" (airframe only) of the Venom so I'll be able to compare the airframe parts for differences. It will also come in handy for spare parts if needed.
I've installed a Cyclone 3300kv motor in a 5 blade fan unit along with a 60amp ESC and external switching BEC and I'm debating whether to replace the stock unit right away or wait to see the stock performance. Stock equipment looked very good in the video so, I'm leaning toward stock right now. I may replace the ESC right away, especially if it doesn't come stock with an external BEC ....and if I do that, I might as well swap the fan and motor too. Decisions, decisions. I'll have to make up my mind when it gets here.
RJ
Old Aug 08, 2011, 03:47 AM
acky is offline
Find More Posts by acky
addicted rc'er
acky's Avatar
Adelaide, Australia
Joined Dec 2009
mines on its way to "EMS" it left hongkong on sat and is still in the air according to the tracking, man i hope its here by friday!!!!
batteries arrived today tho - big!! hope they fit!
acky is offline Find More Posts by acky
Old Aug 08, 2011, 08:16 AM
rowdyjoe is offline
rowdyjoe's Avatar
Arlington, TX
Joined Jul 2009
Great. Hope ours arrive at the same time. We can compare notes on assembly and the first flights. I hope your batteries fit too.
RJ
Old Aug 08, 2011, 08:55 PM
acky is offline
addicted rc'er
acky's Avatar
Adelaide, Australia
Joined Dec 2009
i got a surprise today, no the plane has not arrived yet but i think it may be literally 40mins away!! hense the surprise!!
tracking on the hong kong mail site shows it as in transit from hk to final destanation and has done since the 6th - i was thinkin where the heck is this plane going? australia via london???
theres a drop down list on the page to check the destanation countries postal service, so i looked and surprise! its listed as with driver en route to final destination - YAH!!
so check the drop down list!!
Old Aug 08, 2011, 10:00 PM
rowdyjoe is offline
rowdyjoe's Avatar
Arlington, TX
Joined Jul 2009
Great news. Hope she's there before sundown.
I'm afraid mine isn't even registering in the system yet. The tracking system tells me there's no record of that number ....check back later. I've checked the China postal system and the EMS tracking system with no luck.
RJ
RJ
Old Aug 08, 2011, 10:20 PM
acky is offline
addicted rc'er
acky's Avatar
Adelaide, Australia
Joined Dec 2009
its arrived now i cant play with it untill late tonight
retracts look fairly robust!
Old Aug 08, 2011, 10:53 PM
i12flyrc is online now
Find More Posts by i12flyrc
i12flyrc's Avatar
Columbus, Ohio, United States
Joined Jul 2003
Ordered electric retracts from Hobby King, they are shipped and on their way. Going to replace the air retracts with these. Thanks for the advice.
i12flyrc is online now Find More Posts by i12flyrc
Old Aug 09, 2011, 12:58 AM
rowdyjoe is offline
rowdyjoe's Avatar
Arlington, TX
Joined Jul 2009
As we say in Texas ....YEEEEEEEE HAAAAWWWWWWWWW !!!!
Old Aug 09, 2011, 07:28 AM
acky is offline
addicted rc'er
acky's Avatar
Adelaide, Australia
Joined Dec 2009
well here it is all spread out! instructions are rubbish! but everything seems to be there, even hinges for the movable surfaces!
all the wiring is numbered but there is no reference to the wiring at all in the instructions?
battery looks like it might fit?
this is my first non parkzone foamy and i must say the foam seems harder but the level of finish is way lower - paint seems thin and the decals are split in places, ah well cant really complain for the price
Old Aug 09, 2011, 07:34 AM
i12flyrc's Avatar
Joined Jul 2003
RJ, is there a stock number for the electric retracts in the F86 you just got from Hobby City and if so what are they? I tried to look up the parts on their website for that F86 since it looks identical to the Venom one but couldn't get at a parts list. The ones I ordered were STTE 03 and STTE 02 a nose wheel and mains, they didn't come as a set but are made to go with each other. These look like they have the right dimensions. They also look pink/purple ish in the picture.
Old Aug 09, 2011, 09:35 AM
rowdyjoe is offline
rowdyjoe's Avatar
Arlington, TX
Joined Jul 2009
Sorry, can't help you with that one. I have no idea.
I know that HK sells electric retracts but, don't know if any of those are the same as those that come with the plane.
I have a "kit" version of this bird that came with air retracts so, I ordered the NP Exceed retracts (for the Exceed Mig 15) to replace the air. The wing pockets require a bit of modification for them to fit but, it's minimal really. They're good retracts and no more expensive than other sets and they'll ship from the US (if in stock).
RJ
Old Aug 09, 2011, 09:38 AM
rowdyjoe is offline
rowdyjoe's Avatar
Arlington, TX
Joined Jul 2009
Hey, great. Thanks for the pictures.
Everything looks easily accessible and that's a good thing. Did the thrust tube come installed you do you have to do that yourself?
The nose wheel looks small in that large opening but, I think the opening is meant to double as a cheater hole. Otherwise, why make it so big? I think it will look scale when you put her on the ground. If not, wheels are plentiful and cheap.
RJ
Old Aug 09, 2011, 06:12 PM
acky is offline
addicted rc'er
acky's Avatar
Adelaide, Australia
Joined Dec 2009
thrust tube was already in place.
Wheels are a bit small for grass i think and its def a cheater hole!
i will try and see if i can get a part number off the retracts tonight
wings glued so tonight i plan to do the hinges etc and all going well have it ready for a maiden friday!
Old Aug 09, 2011, 06:38 PM
J3 guy is offline
Find More Posts by J3 guy
Broken Arrow, Okla
Joined Oct 2010
STTE 02 & 03 from HK is what I am installing. They look solid, but next time will buy the version 2 from X flight RC.
They are the metal trunions version.
J3 guy is offline Find More Posts by J3 guy
Build Log EJF.COM FLY FLY F-4 build...twin 70mm...CN style BABY! corsair nut Foamy EDFs 131 Jun 15, 2011 04:31 PM
Article Venom 70mm F-86 EDF ARF Bajora Foamy EDFs 58 Jan 18, 2011 09:28 PM
New Product Venom F-86 Sabre 70mm 7CH EDF Venom Group Foamy EDFs 826 Nov 22, 2010 06:39 PM
