United States, FL, Orlando
Joined Aug 2012
I flew stock.motor on 100 esc, 6s and Omg fast and confident, until the the puff, the pop, and uneventfull glide back to the landing strip. I can't wait to put in the 12 blade I just ordered. 2.45 kg static thrust at 70 ish amps.
Whoa!! 6s with the stock motor. Now that is some kahunas.
If you really want a rocket ride on 6s get this motor. I have it both my Cougar and the F-105. Both are 6 lb planes and will hover on 6s. ![]() The big, big, big, I mean big half Cuban 8's are impressive. |
Yes, indeed.
It is, as Boogie notes, a "rocket ride" on 6s. These are awesome motors, capable of incredible power. Bought one, put it in a Skyworld alloy housing and dropped it into an FMS F4 - big enuf for 6s 2600's. Plane takes off in about 10' and is a bullet; but flight time is 2 minutes. Now looking for a new home to drop it into.
Battery choice
United States, OH, Hamilton
Joined May 2011
Put zippy 4000 in mine and hoffman fan with 150 amp esc. Only get 3 to 3.5 min but plenty of thrust. I did have to cut out some foam infront of battery tray. Made it so thin you could see through it. Glassed the tray and had to add alittle weight to the tail. But it had so much power that it forced the thrust tube 2 inches out the back of the plane. Flew it two in 20 mph winds and at landing a gust stopped it 4 feet above the runway. Minor gear damage again but it was a cool landing.
It also makes a ton of power on 5s. In fact, I usually fly the Thud and Coug' on 5s and only use 6s when I want to show off. ...so about every other flight. ![]() Needs some good batteries. I'm runnin' 5000mAh 40C packs (3s+2s or 3s+3s) But a fan upgrade would be needed too. I'm sure it would blow up the stock rotor. Use an HET or WeMo. And a beast like this will need to be properly installed. On my high power set-ups I make small washers out of circuit board to use as a spacer between the motor and fan housing. Keeps heat away from the plastic. ...yes I've melted a fan housing with it. Needs slotted tape supporting the motor at the back edge of the fan housing. Remove any stickers that may be on the motors and make sure the cooling ring is nice and tight. I still don't think even this Arc 28-58-1 would make this jet fast. But it would leap off the ground and have some very impressive vertical performance. |
Battery choice
I just bought these and they fit under the canopy just fine and the weight difference btwn these and the 3300 4s 40c Sky's that I've been using is only 22g, so should be negligable effects on the CG. I'll let you know how they work out as far as punch and time of flight. |
Thamks
Will be watching to see how you like them. Regards Meanwhile, will be lookin to the US Warehouse of HK to see what may work...any further tips fellas? Paul Paul |
New to this thread
Not sure if this is the right thread or not. Just ordered the F-86 Skyblazers from HK. I see they use electric retracts instead of pnuematic with this version. Hopefully it has better retracts than the Vampy came with. I'll probably fly stock for a while before considering borrowing my good CS-10 setup out of my Vampire.
*update* scratch that. Decided to go with the FMS P-38 from BH instead. Got enough jets for a while including the 35 and the 50mm versions and a Panther I still need to play with. (didn't really want to k-ball my Vampire anyway.) |
| Thread Tools | |
| Build Log EJF.COM FLY FLY F-4 build...twin 70mm...CN style BABY! | corsair nut | Foamy EDFs | 131 | Jun 15, 2011 04:31 PM |
| Article Venom 70mm F-86 EDF ARF | Bajora | Foamy EDFs | 58 | Jan 18, 2011 09:28 PM |
| New Product Venom F-86 Sabre 70mm 7CH EDF | Venom Group | Foamy EDFs | 826 | Nov 22, 2010 06:39 PM |
