Old Sep 01, 2010, 11:44 PM
Lithonion is offline
Find More Posts by Lithonion
Have you seen my nut?
Lithonion's Avatar
Omaha, Nebraska
Joined Mar 2006
Originally Posted by AIR SALLY View Post
as soon as we get done flying sat i'll start on the new nose and duct
That means it will be done Saturday night knowing how you work. Oh wait, it does have to set up doesn't it...lol
Lithonion is offline Find More Posts by Lithonion
Old Sep 02, 2010, 02:28 AM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i will hurry as im getting tired of the hole in the nose ,for some reason the huff 86's the hole looks bigger .i think the red paint on the DR plane makes it look smaller .
AIR SALLY is online now Find More Posts by AIR SALLY
Old Sep 02, 2010, 11:19 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i got my replacement parts yesterday from Venom ..thanks Venom ....great service and good communacation E-mails were answered quickly .as customers that is great
Old Sep 02, 2010, 11:20 AM
Rockin G is offline
Find More Posts by Rockin G
If It Aint Broke,I'll Break It
Rockin G's Avatar
United States, TX, Lockhart
Joined Dec 2008
you got your struts?
Rockin G is offline Find More Posts by Rockin G
Old Sep 02, 2010, 01:51 PM
Lithonion's Avatar
Omaha, Nebraska
Joined Mar 2006
Hope mine get here before the weekend. I still have no nose gear so waiting to get the right wire. They never emailed me back so not sure they got my info. Guess time will tell.
Old Sep 02, 2010, 06:05 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
no ihad a leaking fill valve and retract valve ...they sent repalcments i just made my own main gear wires from !/8" piano wire. the nose gear i use a better 3mm wire and ground my own slot for the set screw i only grind about 160 degrees as i dont need it to turn much more than that.i retaped my struts and put 6-32 screws in and that help some with the play in the struts.
Old Sep 02, 2010, 11:30 PM
Lithonion's Avatar
Omaha, Nebraska
Joined Mar 2006
my fill valve leaks. But whats funny, if I pump the tank to 120psi it will take about 5 hours to leak with gear retracted. 100psi and it leaks down right away. I should pull mine apart and clean it up and pull the spring open more.
Old Sep 03, 2010, 12:13 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
yes .it is just a piece of silicon ,if there is fod in there it will leak ,clean it and open the spring a little and i sure that will fix it .
Old Sep 03, 2010, 05:18 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
C/N came over and we tweeked the nose gear a bit and now we have it rotating almost 90 degrees as per full scale.
Old Sep 04, 2010, 06:57 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
we got 5 flights in today 3 with 2350 batt (short flight) i was'nt impressed with the wemo ,not sure the esc to set up for this motor combo so im going for the HET and same motor next .it was fun doing full flap speed brake landings and then popping a wheelie after setting down on the mains ...some time it would pop back up . it was really hot today too .plane is fun and relaxing to fly ..it's going in for "rihnoplast" if a few minutestime to nip tuck & duct
Old Sep 06, 2010, 03:48 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
heres a peak at what we are going for.
Old Sep 06, 2010, 09:20 PM
keith b is offline
Find More Posts by keith b
Oneonta Alabama
Joined Aug 2010
Hello Roger your inlet looks really nice.Got a guestion for you or bruce,Im running new airlines and I was wondering with all the problems you guys have had should I give the stock fill valve and actuator or change it now.I have a new set of HET available anyone feel free to comment please.
keith b is offline Find More Posts by keith b
Old Sep 06, 2010, 10:15 PM
Rockin G is offline
Rockin G's Avatar
Joined Dec 2008
Keith I gave up on my control valve. I ordered the Robart. My fill valve seems okay. Man, I hope so anyways.
Old Sep 06, 2010, 10:16 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
will i have had no proplems with the stock hose . the fill valve is fine now .it just had a piece of the thread stuck in the flapper valve. if your going to change it use a robart. it is close to the same shape and size and fits right to the plane. i have not found the HET valve to be all that great either.
Old Sep 06, 2010, 10:31 PM
keith b is offline
Oneonta Alabama
Joined Aug 2010
Thanks for the input,Im shocked the HET isnt that good.
Build Log EJF.COM FLY FLY F-4 build...twin 70mm...CN style BABY! corsair nut Foamy EDFs 131 Jun 15, 2011 04:31 PM
Article Venom 70mm F-86 EDF ARF Bajora Foamy EDFs 58 Jan 18, 2011 09:28 PM
New Product Venom F-86 Sabre 70mm 7CH EDF Venom Group Foamy EDFs 826 Nov 22, 2010 06:39 PM
