Old Dec 07, 2011, 11:32 PM
Team Park Pilot - Airborne
OzparkPilot's Avatar
Australia, NSW, Sydney
Joined Nov 2006
Got one for $99 !
OzparkPilot is offline Find More Posts by OzparkPilot
Old Dec 08, 2011, 12:05 AM
addicted rc'er
acky's Avatar
Adelaide, Australia
Joined Dec 2009
you lucky bugger! i saw that add bummer it was pick up only in sydney!! oh well....
acky is offline Find More Posts by acky
Old Dec 08, 2011, 12:34 AM
Joined Nov 2006
I bought 3 ! Sold one still got one for sale.... Can ship ;-)
Old Dec 08, 2011, 03:39 PM
addicted rc'er
acky's Avatar
Adelaide, Australia
Joined Dec 2009
for $99????
Old Dec 08, 2011, 04:21 PM
Gorilla Glue Expert
PikeStaff's Avatar
United States, PA, Doylestown
Joined Sep 2010
Got 'em!
Thank you, Air Sally! These are gonna make sweet improvement to the frontend of this rig. Nice work!
PikeStaff is online now Find More Posts by PikeStaff
Old Dec 08, 2011, 05:43 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
all ready ..that was fast shipping for this time of year
AIR SALLY is online now Find More Posts by AIR SALLY
Old Dec 09, 2011, 01:24 AM
Joined Nov 2006
Whats the build time on these ? Looks like 2-3 hours work ? Have you all used Foam Safe CA or some Epoxy ?
Old Dec 09, 2011, 01:36 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
yes foam safe ...or the flex CA. and epoxy ....also Gorilla glue works for some areas too.
Old Dec 09, 2011, 03:24 AM
Joined Nov 2006
im done ! 3 hours build including putting carbon fibre rods in the wing join area !
Old Dec 09, 2011, 08:27 AM
Cottonwood Arizona
Joined Aug 2003
6s, 4000mah with no tray or hatch mod
I am putting the finishing touches on my battery install. I am going with the HK servoless retracts so I removed the Air System, though there was room to keep as an option with a little adjustment. 2, 4000mah 3s packs lay flat and in line to one another so I did not have to lower the tray or butcher the hatch. Balances pretty well, have to add a small extra weight up in the nose but not enough to worry about. Only mod to the hatch was to remove a little foam from the backside of the "tongue" so my front battery can move forward towards the hatch edge. Will post photos later today when the sun comes up.
The 6s is running a Cyclone Motor (2500kv), turning an E-Flight Delta Fan. (I have this on my Lander Cougar and it performs great) My buddy John has done extensive tests on several different fan/motor combos using a data logger and the Cyclone/Delta fan was a winner. Good speed, great thrust and max Amp draw around 50-54, cruise Amp draws in the upper 20s - and long flight times. Sure you can pump all kinds of Amps into a fan but we were looking for a good balance of performance, economy and run time. John used a Dynam Meteor as a test bed for ease of fan exchange. Data Chart Attached if your interested.
Will post photos later today when the sun comes up of the battery area.
That's my .02¢! Have a good one.
topher39 is offline Find More Posts by topher39
Old Dec 09, 2011, 12:37 PM
Look out below
mcnowhere's Avatar
United States, OR, McMinnville
Joined Aug 2011
Programing
DX7
Trying to find info on ailerons and flap setup of my Huff. So far they only work together not as 2 separate systems.
mcnowhere is offline Find More Posts by mcnowhere
Old Dec 09, 2011, 02:05 PM
Cottonwood Arizona
Joined Aug 2003
You must have set them up on a Y by mistake!
Old Dec 09, 2011, 05:43 PM
Look out below
mcnowhere's Avatar
Joined Aug 2011
I just followed the poor instructions in the book, it said connect ch1 to aileron servo and ch2 to the servo. (thinking they meant flap servo?)
Old Dec 09, 2011, 07:15 PM
Look out below
mcnowhere's Avatar
Joined Aug 2011
Originally Posted by AIR SALLY View Post
what i really like about the kit is the custom made "Y" harnesses for the alierons and flaps. it's just plug and play.
Yep it looked like a y harness when I put it together following the instruction booklet. But I am not getting them to work independently.
Sorry for my lack of knowledge- still a noob.
Old Dec 09, 2011, 08:17 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
do they both work ? could be they did not put a reversed servo on one side ???the red servos are reversed.if only one works could be bad "Y" harness.and make sure the flap Yharness is plugged into your flap ch on the rx.
Build Log EJF.COM FLY FLY F-4 build...twin 70mm...CN style BABY! corsair nut Foamy EDFs 131 Jun 15, 2011 04:31 PM
Article Venom 70mm F-86 EDF ARF Bajora Foamy EDFs 58 Jan 18, 2011 09:28 PM
New Product Venom F-86 Sabre 70mm 7CH EDF Venom Group Foamy EDFs 826 Nov 22, 2010 06:39 PM
