Old Aug 15, 2010, 11:06 AM
Xnaron is offline
Find More Posts by Xnaron
Xnaron's Avatar
Joined Feb 2003
The trouble with deans (maybe knockoffs)
I was just connecting a battery to an esc to bind a receiver and noticed a problem...I think these are real deans connectors and not knockoffs as this battery pack was bought before I started buying those cheapo deans connectors. I was kind of shocked to see this happening when the connectors were fully mated. You only needed to slightly move the connector to have it break connection. It happened on multiple battery packs. I think the problem connector was the esc side deans. I think I am going to move to some other style of connector. Any suggestions?
deans connectors (0 min 22 sec)
Xnaron is offline Find More Posts by Xnaron
Old Aug 15, 2010, 11:10 AM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Yeap, I have experienced the same. There are some cheap knockoffs out there that have a very thin piece of material that keeps the contacts from connecting. I am done with deans.
rimshotcopter is online now Find More Posts by rimshotcopter
Old Aug 15, 2010, 12:10 PM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
I think if you bend any connector that far it will fail.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Aug 15, 2010, 12:49 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Obviously someone did not solder the connectors properly. A couple of my deans did that right after soldering, so I went back and re-soldered them and the problem vanished instantly. Bad solder joint. Make sure they're getting enough heat (but not too much) to make sure the leads are fused to the connector well enough.
Don't assume it's the connectors fault for not working properly. It's like saying that your car crashed, so it must be the manufacturers fault.
Xpress.. is offline Find More Posts by Xpress..
Old Aug 15, 2010, 12:53 PM
Xnaron is offline
Xnaron's Avatar
Joined Feb 2003
Glen
I'm not sure what your seeing in the video but I am not bending anything.
Old Aug 15, 2010, 12:54 PM
Xnaron is offline
Xnaron's Avatar
Joined Feb 2003
Solder joints are fine...I redid them...this is a connector issue...Just something to be aware of. I didn't say all deans were crap. I just wanted to point out an issue I had...luckily I found it on the bench and not in the air.
Old Aug 15, 2010, 01:07 PM
Joined Aug 2009
In my situation, at the time when this happened, I did not have a camera system that would take close-up. My deans did have a piece of the housing preventing the contacts from connecting.
Discussion trouble with hobby zone drop module ford f47 Electric Plane Talk 9 Sep 02, 2010 05:14 PM
Discussion Trouble with new Turnigy Brushless ESC 85A w Dr. Seltsam Power Systems 5 Aug 02, 2010 05:53 AM
Discussion Trouble with Props! ForeverFlying Parkflyers 2 Jul 30, 2010 02:37 AM
Sold 4 Venom 7.2v 5000mah With Deans Plug jetfighter2008 Cars - Cars and Parts (FS/W) 0 Jul 24, 2010 12:01 PM
Discussion Deans and clones = trouble? roidspop Batteries and Chargers 7 Nov 02, 2007 11:34 AM
