Old Jun 27, 2003, 07:41 PM
asennad is offline
Find More Posts by asennad
asennad's Avatar
Joined Jun 2003
How do you use Polycrylic to glass a plane?
What technique do you use? How do you hold the glass down? What size glass? What tools/brush do you use? Do you attach it with 3M77 before hand? Can you cover open areas with it?What do you paint over it?
asennad is offline Find More Posts by asennad
Old Jun 27, 2003, 09:28 PM
Pierre Audette is offline
Find More Posts by Pierre Audette
RPV builder & operator
Pierre Audette's Avatar
Canada, QC, Gatineau
Joined Jan 2001
http://rcgroups.com/links/index.php?...at=202&id=4018
Pierre Audette is offline Find More Posts by Pierre Audette
Old Jun 28, 2003, 03:07 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
I've tried both polyacrylic and water based polyurethane with fiberglass. In my opinion, the water based polyurethane provides a smoother and stronger bond to the foam. You can use water based acrylic craft paints (available at walmart craft dept) for painting.
hoppy
hoppy is offline Find More Posts by hoppy
Old Jul 02, 2003, 11:10 PM
asennad is offline
asennad's Avatar
Joined Jun 2003
What exactly is the difference between the polyacrylic and water based polyurethane? What's best for raw balsa?
(I can find the polyurethane in small cans. The polyacrylic I see only in large cans.)
Old Jul 26, 2003, 12:55 PM
hweird is offline
Find More Posts by hweird
WORK!
hweird's Avatar
Joined Jul 2002
Originally posted by hoppy
Here is an instruction for the process.
http://webhome.idirect.com/~manuel/
hoppy
hoppy,
This link is no longer working. Ken moved his site to: http://www.seriouslyfunmodels.com/. In searching the new site, I was unable to find the link to this covering article. It was very good and I am trying to find it again. Do you know where I could find it? I will also send Ken an e-mail.
Howard
hweird is offline Find More Posts by hweird
Old Jul 27, 2003, 03:28 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
You are right, the link is gone. OK, here is how I do it. Sand the foam lightly and blow the dust off with an air gun or rinse with water and let dry well. Cut the 0.5 to 0.75oz fiberglass cloth slightly oversize to cover both sides of wing (body/wharever). Place cloth over surface and liberally brush on the water based polyurethane varnish. Have a piece of waxpaper underneath to collect the excess WBPU. After the surfaces are well soaked with the varnish, take a credit card and lightly squeegy the cloth to remove the excess varnish. Do this on both sides and then place the part on several needles or nail points till dry. At this time cut off the excess material with a very sharp exacto knife or scissors.
hoppy
Old Jul 28, 2003, 09:06 AM
mkirsch1 is offline
Find More Posts by mkirsch1
United States, NY, Spencerport
Joined Oct 2001
Minwax Polycrylic IS water based polyurethane.
Make sure it's WATER based polyurethane, if you're glassing over foam.
mkirsch1 is offline Find More Posts by mkirsch1
Old Jul 28, 2003, 12:54 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
No, polycrylic is not water based polyurethane, it's polyacrylic. Two completely different chemicals.
Minwax® Water-Based Polyurethane for Floors
A professional formula that combines the superior durability and warm richness of traditional polyurethane with the ultra-fast dry time, low odor and easy water cleanup of water-based finishes.
Minwax® Polycrylic® Protective Finish
A tough, crystal clear finish that is ultra fast-drying. Its low odor formula is water-based for easy cleanup. Ideal for use over white, light and custom-color water-based stains.
hoppy
Old Jul 28, 2003, 02:49 PM
mkirsch1 is offline
Joined Oct 2001
I was told by so-called "paint experts" that acrylic simply means water-based.
Old Jul 28, 2003, 03:32 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
"Paint experts" steered you wrong on that one.... tho probably most acrylics we use are water based. So in a way they are right.
Here's a page on acrylic paints.
http://www.rexart.com/whatacry.html
They, the chemists, can modify these polymers to get many different end product properties. House paints, varnishes, etc.
hoppy
I Give Up. How Do You Use the Bloody Things! stuka Micro Helis 2 Nov 17, 2003 10:08 PM
I Give Up. How Do You Use the Bloody Things! stuka Micro Helis 0 Nov 17, 2003 05:51 PM
How do you use your OWN TX with G2 kushal_22 Simulators 20 Aug 18, 2003 05:36 PM
How do you use your Feather Cut? gobigdale Foamies (Kits) 0 Aug 16, 2002 03:16 PM
How do you ship a anready Built Plane? mrebman Parkflyers 5 Dec 05, 2001 11:01 AM
