Old Aug 14, 2010, 04:03 AM
domll is offline
Find More Posts by domll
domll's Avatar
Norwich.uk.
Joined Oct 2007
Question
Outer wing attachment.
Currently i'm building a twin engine aircraft. the center section of the wing will be part off the fuselage, from the outside edge of nacelles too wing tip i intend to have this section as a plugin.
Question: What would be the best way of attaching these, securely, allowing for easy removal when transporting
domll is offline Find More Posts by domll
Old Aug 14, 2010, 04:52 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
I have a B-25 with detachable outer panels, a B-17 with each complete wing panel detachable at the fuselage side, and a Sunderland with the outer panels detachable.
All electric powered and 93" span, 100" span, and 90" span.
On all of them I use a pin going through the joining spar for retention. The sketch explains it better.
I normally use hardwood dowel for the joining spar, rolled paper tubes for the alignment tubes, (the Sunderland uses fiberglass tubes).
The pin is usually a piece of push rod off-cut, and the pin aligning tube a piece of snake outer, and is a good friction fit through the dowel.
Yes, I do tend to do things on the cheap, , but they work. Haven't lost a wing so far, but then niether do I do aerobatics with scale(ish) models that never did either.
eflightray is offline Find More Posts by eflightray
Old Aug 14, 2010, 05:57 AM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
Thanks eflightray, i'm working on a bristol Beaufighter so no aerobatics for me
As this works for 93" span, 100" span, and 90" span, 51" will be not problem.
Old Aug 14, 2010, 09:21 AM
rotccapt is offline
Find More Posts by rotccapt
that tree ate my plane
rotccapt's Avatar
oklahoma city oklahoma
Joined Apr 2004
if you were worried about loosing the pin you could replace it with a screw and a blind nut
rotccapt is offline Find More Posts by rotccapt
Discussion Wing attachment: Magnets or Velcro? philipa_240sx Foamies (Scratchbuilt) 16 Jul 14, 2010 08:09 AM
Discussion T-28 Trojan Wing Attachment Post Crash griff3 Parkflyers 2 Apr 16, 2010 05:38 AM
Help! wing attachment & hinges uncle mac Foamies (Scratchbuilt) 2 Mar 09, 2010 06:43 PM
Wanted Piper XL Outer Wing Panel liftchaser Aircraft - Sailplanes (FS/W) 2 Sep 15, 2009 09:17 AM
