Initial impression of the HK450 V2 kit - I like it! I realize that it is not a high performance kit but for $30 I didn't expect it to be. If this kind of kit wasn't available at this price I wouldn't be able to fly 450's!
- more alloy components (on head, motor mount, canopy mounts, etc.)
- clean look of frame with silver screw washers
- appear to be better quality screws (or it could just be that I am using a good quality driver now!
- I like the look of the black fins, main gear and landing gear better than the white on the V1
- motor mount holes look like they will actually line up with my motor holes (V1 I had to make the mount holes wider and longer to fit properly)
- tail guides for servo rod are tight on the boom
Dislikes:
- plastic of tail assembly and blade grips appears to be poorer quality than the V1, could just be the color (grey vs black)...only time will tell
- holes in frame don't perfectly line up with holes in bottom tray of frame
- ball links don't look as high quality (lots of plastic pieces that need trimmed) and a few need to be reamed out (to be expected I suppose - better than too loose)
- HXT 900 servos won't fit into the slots in the frame from the back (have to put the end that holds the arm through the hole). Haven't tried the HD 1900's yet.
So far I have assembled the tail, set servos in (not mounted yet) and installed the frame base (it takes a while when you can only work on it from 5:30-6:15am and after 9pm...especially if I want to spend any time with my wife!)
