Old Aug 12, 2010, 06:42 PM
deadduck is offline
Find More Posts by deadduck
Manila Ninoy Intl, Philippines
Joined Nov 2001
New Product
Nine Eagles Sky Runner
Got one yesterday.
Specs are:
EPO Airframe
2.4GHZ Radio - 3 Channel
Wingspan : 703mm (which is why I didn't post in the Micro RTF forum)
Length : 514mm
Flying Weight : 85g
Motor: Brushed N20 motor
Battery: 7.4v 250mah LiPo
deadduck is offline Find More Posts by deadduck
Old Aug 12, 2010, 06:45 PM
deadduck is offline
Joined Nov 2001
2.4 transmitter
Proprietary Nine Eagles, airplane version.
You cannot use a Spektrum, Futaba, Hitec , etc...
You cannot use the Nine Eagles transmitters for heli.
They won't bind to the Nine Eagles Airplane receivers.
Old Aug 28, 2010, 06:43 AM
jba55ett is offline
Find More Posts by jba55ett
jba55ett's Avatar
Yeovil, UK
Joined Apr 2005
It would be nice to know how it flies?
Regards
___ __ _ Jan
jba55ett is offline Find More Posts by jba55ett
Old Aug 28, 2010, 09:03 AM
Chairwolf is offline
Find More Posts by Chairwolf
I think it'll work this time!!
Chairwolf's Avatar
399 feet above Roanoke, VA
Joined Jan 2007
Neat little plane. Mini Easy Star. Do you have a link to the supplier?
Bob
Chairwolf is offline Find More Posts by Chairwolf
Old Aug 28, 2010, 10:46 AM
Greywing is offline
Find More Posts by Greywing
USA, CA, Pismo Beach
Joined Oct 2007
Suppliers website: http://www.nineeagle.com/en/p.asp?pid=71
Unfortunately, it doesn't show pricing or who distributes.
Greywing is offline Find More Posts by Greywing
Old Aug 28, 2010, 10:57 AM
squid275 is offline
Find More Posts by squid275
hele lekkere Kaas
Joined Jun 2008
where did you buy it?
squid275 is offline Find More Posts by squid275
Old Aug 28, 2010, 12:12 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Hobby People carries some 9Eagles stuff, but I don't see this plane on their web site...yet. It is cute.
Vantasstic is offline Find More Posts by Vantasstic
Old Aug 28, 2010, 12:39 PM
lovespicyfood is offline
Find More Posts by lovespicyfood
USA, CA, Westlake Village
Joined Sep 2004
Yea, that does look cool...a mini EZ* for sure. Very interested in how it flies...
lovespicyfood is offline Find More Posts by lovespicyfood
Old Aug 28, 2010, 08:25 PM
t-turley is offline
Find More Posts by t-turley
Joined Mar 2001
I've been looking for something like this, but don't need the electronics. Curious if the EPO parts will be available from HK.
Tony
t-turley is offline Find More Posts by t-turley
Old Aug 28, 2010, 08:57 PM
Chairwolf's Avatar
Joined Jan 2007
Tony
Yeah, me too. I'm just interested in the airframe.
Old Aug 29, 2010, 07:52 PM
deadduck is offline
Joined Nov 2001
Maiden Report
Finally got out to the field to try it.
The good news: The prop doesn't pop off in flight. Well it shouldn't since it's pushing into the holder.
Flies nicely but some minor set up issues:
1)When you power up, it tends to dip the nose first, before climbing. My friend thinks the down thrust is off, I'm not so sure.
2) Had to put in a few clicks of down elevator, otherwise it porpoises badly, which may imply an issue with the tailplane incidence? BTW the tailplane is glued in the factory.
3) Still haven't got CG right, which may have contributed to the porpoising.
2 and 3 are related so it's a question of finding the right battery position which will give a good power off glide angle with (hopefully) neutral trims.
Will try some glide tests with different battery positions before flying it again. (This brings back memories of setting up Firebird type pushers.)
Much nicer to fly than the Cessna (which has to be flown fast).
Old Aug 29, 2010, 08:08 PM
deadduck is offline
Joined Nov 2001
Sky Runner Spare Part numbers
Here are the part numbers for body parts:
NE401772004A - Removable Steel Wire 2 (= Pushrod set)
NE4770012 - Removable Rod Adjustment set 2 (= horns, clevises etc)
NE401772003A Wing set ( includes carbon spar)
NE401772006A Vertical Tail & Horizontal Tail set
NE401772002A Body Set (fuselage and canopy)
Not yet showing up on google, but they will.
BTW NE4770012 - Removable Rod Adjustment set 2 is the same part set as for the Cessna
Also uses the same receiver set as the cessna (NE4615001)
The prop is a pusher 100mm diameter.
Old Aug 29, 2010, 08:13 PM
deadduck is offline
Joined Nov 2001
DSM2 modification
If you can get the body parts, it should be possible to stick in a dsm2 receiver/servo block + esc and do the BL mod done with the PZ sukhois and run it off your Spektrum radio.
A 1 cell BL mod and then run a 500mah single cell for long flight times.
Old Aug 30, 2010, 02:09 AM
jba55ett is offline
jba55ett's Avatar
Yeovil, UK
Joined Apr 2005
I've experienced this before with high thrust line models. The main issue is that the motor down thrust acts as soon as the motor is throttled up, but the elevator authority doesn't change until models speed increases. If you adjust the motor thrust line, to prevent the pitch down on throttle up, the plane will tend to over rotate nose up when the airspeed increases. Some fine tuning of the thrust line and tailplane incidence may help, but total removal of the effect is not likely.
I find that gentle motor acceleration or pulling back slightly on the elevator when rapidly increasing the throttle helps.
___ __ _ Jan
Old Aug 31, 2010, 10:50 AM
t-turley is offline
Joined Mar 2001
Here is a link in German. Is that price in Euros? That would be what, about $125 USD?
Tony
Build Log Xtreme Nine Eagles Solo Pro and Mods Thread Razors edge 29 Micro Helis 1259 Mar 30, 2013 12:11 AM
New Product Nine Eagles Twingoo "Tandem" PicooMan Coaxial Helicopters 38 Dec 02, 2010 03:52 PM
Discussion Mod-X : Fastest forward flight ever achieved on a Nine Eagles Solo Pro EQMOD Micro Helis 17 Oct 08, 2010 07:27 PM
Discussion Nine Eagles Solo Pro beating the Stock MSR Outdoors EQMOD Micro Helis 11 Jul 29, 2010 09:43 PM
Discussion Nine Eagles Battery Issues SoloProFan Micro Helis 1 Jul 26, 2010 04:48 PM
