| Thread Tools |
| This thread is privately moderated by boredom.is.me, who may elect to delete unwanted replies. |
Pop-pop outboard runabout
Will be moving soon and found that old experiment while cleaning the hobby room. Ran it about 7 years ago, it was slow but moved around while the fuel was burning. At the time I was using a regular size servo and Rx+500mA Rx pack but still had to add weight in the front! Its about 12" long and made out of carved pink foam and was using solid pellet fuel from Willesco.
![]() http://en.wikipedia.org/wiki/Pop_pop_boat |
Los Angeles
Foam outrigger
My first post in boat. Just 1/8" short of 15" from tip to tip. Body is 12" long. Foam with 1 layer 3/4 oz glass. 15gram motor from HK re-round. Stock Magic Cat prop. Homemade hardware. Tried different filed down props from Magic Cat prop but stock seam to be best. Big smiles after running it every time.
AUW is a tag under 5 oz with Rhino 460 3S. Video:
Converted the toy boat Elias.
Length 18cm, Width 10cm, Displacement: 217 grams. Used a HXT 5010 servo as motor and ESC.
Not easy to sail a boat and filming at the same time. |
| Thread Tools | |
| Discussion closed | Gray | Aerial Photography | 145 | Aug 14, 2010 02:35 AM |
| Found advice on "How do you post pictures of your items?" | ralfharry | Aircraft - Electric - Airplanes (FS/W) | 2 | Mar 05, 2010 09:22 PM |
| Discussion Post your parkzone t28 trojan pictures | hbsurfer | Your Plane Photos | 1 | Dec 06, 2009 05:13 PM |
| Gallery Post your full size autogyro pictures, for model building and flying inspiration. | rotorheid | Auto Gyros | 10 | Sep 29, 2009 05:34 PM |
| Gallery Post your method and pictures on how to make your heli colorful and bright =) | crxef9 | Micro Helis | 13 | Feb 14, 2007 08:45 PM |
