This thread is privately moderated by boredom.is.me, who may elect to delete unwanted replies.
Old Aug 11, 2010, 08:35 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Post Your Micro Boat Pictures
Let's all post pictures of our boats. To start off here are some of mine.
7.3" Micro-Bat Rigger
1015 11000kv BL
120mah 25c 1s Hyperion
AR6400
Kyosho Mini-Z prop
6 Series Stealth Cat (coming soon as a kit)
ABS formed hull
custom laser cut Hardware
Kyosho Mini-Z prop
6 Series Rudder/Drive Proto
1.5mm and 1mm Interlocking Balsa
Bolts on to transom with two bolts
Adjustable strut angle
max prop diameter: can't remember right now
Breeze 4" Sail Boat
AR6400
Carbon Fiber Mast and Boom
Depron hull
Balsa Hardware
No motor
5 Star Airboat
AR6400
6mm pager and AeroAce prop
5 Star Notebook plastic and depron hull
Ya, it is a mess.
7" Micro Skipper Airboat
AR6400
7mm pager and AeroAce prop
120mah Eflite
Depron Hull and Gear
5.3" Nano-Bat Rigger
to be continued
Intended for Plantraco Gear
Kyosho Mini-Z prop
Kyosho Mini-Z Cat
total bust...
1220 10300kv BL
TGY 6A Plush ESC
Rhino 360mah 2s lipo
EM 3.7g servo
8.5" Shameless Micro-Bat Rigger
1015 11000kv BL
XP-3A ESC
AR6300
AS2000 1.5g servo
Hyperion 1s 120mah 25c Lipo
boredom.is.me is offline Find More Posts by boredom.is.me
Old Aug 11, 2010, 08:42 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
well, i havent been at it for too long, but i'l put up a few pics
derk is offline Find More Posts by derk
Old Aug 12, 2010, 02:22 AM
CornelP is offline
Find More Posts by CornelP
CornelP's Avatar
Bucharest, RO
Joined May 2009
These are mine (for now):
10" hydro on a 18mm outrunner, 3S
10" cat on a 1230 inrunner, watercooled, 2S
CornelP is offline Find More Posts by CornelP
Old Aug 12, 2010, 07:28 AM
cineas is offline
Find More Posts by cineas
cineas's Avatar
Fortaleza - ceara - Brazil
Joined Sep 2007
My mini cat by hobby king ! very nice boat
http://cineastv.forumeiros.com/barco...-2010-t985.htm
cineas
cineas is offline Find More Posts by cineas
Old Aug 12, 2010, 12:45 PM
ropanach is offline
Find More Posts by ropanach
Dragon Slayer
ropanach's Avatar
Shelton,WA
Joined Nov 2004
Scrach built Tiny-Tim
This is my scrach bult Tiny-Tim,
I am still learning about Micro electronic set ups, how to fit them in to keep the CG so it looks and acts like a big boat.
ropanach is offline Find More Posts by ropanach
Old Aug 12, 2010, 04:43 PM
csr101 is offline
Find More Posts by csr101
edmonds, wa.
Joined Aug 2003
12 inch "Tally craft" cracker box.
csr101 is offline Find More Posts by csr101
Old Aug 18, 2010, 06:56 PM
Grayco is offline
Find More Posts by Grayco
Joined Apr 2010
My micro is fun but not nearly as fancy as some of these.
My son and i have dubbed it the Puddle Pod becauce it is basically a 1/6th scale Peapod hull.
Grayco is offline Find More Posts by Grayco
Old Aug 20, 2010, 10:44 AM
meatbomber is offline
Find More Posts by meatbomber
Square-rigger
meatbomber's Avatar
Klatovy, Czech Republic
Joined Mar 2004
Here's my 2
HMAV Bounty
St.Helena HEIC Packet
meatbomber is offline Find More Posts by meatbomber
Old Aug 20, 2010, 11:27 AM
Subdave is offline
Find More Posts by Subdave
Semi-Official Tinkerer
Subdave's Avatar
Rochester NY
Joined Mar 2005
Here are a few of my 1/48 nano hydro. Dave.
Subdave is offline Find More Posts by Subdave
Old Aug 22, 2010, 08:14 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
8 inch USCGC
my 8 inch United States Coast Guard Cutter.
8 inches, length, 1.25 beam
130 mah lipo, ar6400. rudder throttle.
small brushed Dc motor out of walmart cheap rc car.
nemoskull is offline Find More Posts by nemoskull
Old Sep 13, 2010, 11:40 AM
getmeoutofiraq is offline
Find More Posts by getmeoutofiraq
USA, CA, Turlock
Joined Apr 2009
Arizona aluminum boat
aluminum boat from Arizona tea can just a one day project. slow and liked to turn right or go streight...but it was made with electrics from a airhogs plane and my props were aluminum from a can too that i just bent. shafts are from a can of air tube.
getmeoutofiraq is offline Find More Posts by getmeoutofiraq
Old Sep 16, 2010, 06:38 PM
zoltansgarage is offline
Find More Posts by zoltansgarage
zoltansgarage's Avatar
California
Joined Dec 2009
Photo of Mona Lisa
Here are some photos of Mona Lisa. She is just over 2 sticks (13 inches). The motor is from a large scale servo, as is the speed control. The birds, and skipper are sculpted from plastic spure, from old model car kits, using a hot soldering iron, small files etc. The skippers clothes are made from the same plastic, melted down in liquid plastic cement, then brushed over bits of paper towel and positioned. All the pulleys, cabin and other fittings were cut from plastic sheet.
The roof is made from fine sandpapper, painted to look like roofing matrial.
zoltansgarage is offline Find More Posts by zoltansgarage
Old Sep 26, 2010, 05:33 PM
zue is offline
zue
Find More Posts by zue
zue
Romania
Joined Oct 2008
My collection, all boats have a length below 300 mm
zue is offline Find More Posts by zue
Old Sep 28, 2010, 04:18 PM
GILL RC is offline
Find More Posts by GILL RC
GILL
GILL RC's Avatar
United States, NJ, Hopatcong
Joined Aug 2005
I have a NS Savanh 14", A Smitt Houston 14", Miami Vice Sarabb 14", A U538 18", Lindberg shrimp boat 14", Lobster boat 14", 12" PT, 12"sport fisherman, 12" pilot boat, several micro subs, The billings John Alden sail boat 14", The Uss New Jersey 22" and I am working on a 1:125 Calypso. Pictures are on my site at: www.jsgill.net
Just a few of the pic's
GILL RC is offline Find More Posts by GILL RC
Discussion closed Gray Aerial Photography 145 Aug 14, 2010 02:35 AM
Found advice on "How do you post pictures of your items?" ralfharry Aircraft - Electric - Airplanes (FS/W) 2 Mar 05, 2010 09:22 PM
Discussion Post your parkzone t28 trojan pictures hbsurfer Your Plane Photos 1 Dec 06, 2009 05:13 PM
Gallery Post your full size autogyro pictures, for model building and flying inspiration. rotorheid Auto Gyros 10 Sep 29, 2009 05:34 PM
Gallery Post your method and pictures on how to make your heli colorful and bright =) crxef9 Micro Helis 13 Feb 14, 2007 08:45 PM
