Old Aug 10, 2010, 11:31 PM
haogodent2 is offline
Find More Posts by haogodent2
haogodent2's Avatar
Oakland, CA
Joined Jul 2009
Build Log
dollar tree 60in aero glider
Inspired by EPP eraser 60 and driven by my jealousy of my fellow flying friends' 1.5m flat wing aileron EPP planes at my local flying spot, I decided to build a dollar tree foam based 1.5 meter wing span flat wing aileron/elevator glider. Though it's not really designed for combat purposes (not EPP), it was designed and built with simplicity(mostly straight cuts)/performance(maneuverability)/budget(under 10 bucks for airframe?) in mind. I took it out for a maiden flight last weekend and it is delightful in the air. Very floaty and maneuverable. Perhaps I will reinforce a few critical spots with some Popsicle sticks and join the fight anyway. It's only 3-5 dollars worth of building material and 2 days worth of building time after all.
p.s. I was going to put a motor in the front, but decided not to since it flew well without one. It can be easily modded to take a motor in the front.
youtube vid. the camera work was a bit unsteady, sorry about that.
dollar tree foam 60" aero glider soaring (6 min 20 sec)
building materials:
2 sticks of spruce/Popsicle sticks for main spar: $5
2-3 sheets of foam( used some scraps, not sure if 2 new sheets would be sufficient) $2-3
color tape 2 bucks a roll
chopstick + useless credit card for accessories
3 servos (2 mystery 9gram, 1 hxt 900 9gram)
used AA batteries for nose weight
haogodent2 is offline Find More Posts by haogodent2
Old Aug 11, 2010, 02:24 AM
Sonex128 is offline
Find More Posts by Sonex128
R/C Junkie
Sonex128's Avatar
Claremore, OK, USA
Joined Feb 2004
Looks good. How did you make the wing. Looks like and airfoil.
Brian
Sonex128 is offline Find More Posts by Sonex128
Old Aug 11, 2010, 11:31 AM
haogodent2's Avatar
Oakland, CA
Joined Jul 2009
The wing is built by:
first gluing 2 sheets of 30" by 14" sheets together to get a 60" piece,
then glue two pieces of spruce lengthwise at 1/3 of 7 " and a strip of foam at 5" mark,
then simply fold the foam over @ 7" and glue it down.
Alert Dollar Tree Foam Board Alert kansascloud Foamies (Scratchbuilt) 120 Feb 17, 2011 05:10 PM
Discussion Slope Soarer from Dollar Tree Foam AirmanAirhead Flying Wings 1 Mar 11, 2010 08:48 AM
Discussion Building a jet pusher with Dollar Tree Foam? hoverflyhehe Pusher Prop Jet Models 26 Feb 25, 2010 08:43 AM
Discussion Dollar Tree Foam Board Soccer ball/Shoe freefl2 Foamies (Scratchbuilt) 6 Dec 16, 2009 05:41 PM
