Old Aug 10, 2010, 09:49 AM
J Morgan is offline
Find More Posts by J Morgan
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Build Log
Dornier DO-335 Co-Build for Stacker & Morgan
Having completed Stacker's wonderful B-24, I talked him into a co-build with me on the last and fastest German WW II fighter, the Pfeil.
Dave is doing the plans, cowls, motor mounts, retracts, and whatever else I can talk him into.
I'm doing the fuse in fiberglass and the wings, hot wired and sheeted.
OK, so he's doing most of the work, I'm a lucky guy.
Size will be 1/11th scale, ws of about 50".
Don't know about Dave but I'm leaning toward the A Model version vs the B2 which had the huge cannon in the wings.
I used the hot wire to cut out sections from his plans for the fuse, glued together and then various sections added to round it out.
I'm doing this FG fuse as I usually do, in reverse order than others do it.
I make a plug and then glass over it, cut it off the plug and then glue the seam back together. This method basically transfers all the work on the tail end in that you have to sand a lot and finish the outside unlike making molds that would come out with a final finish. I like instant gratification and this gets me there quicker.
After the plug is shaped I harden it with epoxy, two coats. It doesn't have to be perfect because the glass will be laying over it and the finish is on the outside.
That's is where I am now, one coat of epoxy curing. Will sand later and add the second coat.
J
J Morgan is offline Find More Posts by J Morgan
Old Aug 10, 2010, 10:01 AM
warhead_71 is online now
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Subscribing...
I need to get on the hot-wire band-wagon instead of building-up everything from FFF.
warhead_71 is online now Find More Posts by warhead_71
Old Aug 10, 2010, 12:07 PM
MPP is offline
MPP
Find More Posts by MPP
MPP
In Unusual Attitude Recovery
MPP's Avatar
Danbury CT (DXR)
Joined Oct 2005
J and Stack,
This is going to be great. No choice on retracts so you better get lot's of practice on the B-24 . This is a great size. couple of Vario props might help with the push pull set up. Looking forward to watching this build.
Subbed in,
Mark
MPP is offline Find More Posts by MPP
Old Aug 10, 2010, 02:05 PM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Warhead,
Try it, always good to expand your horizons.
Mark,
Yep, have to case on the retracts here. Stacker is also doing the power system workup and I think we're using the Parkzone 3 bladers from their Me-109G. The motors are BC-3536/9 910kv from RC Timer. Dave can correct me if I'm wrong.
I got an early start on you guys, started about a week ago. My lovely assistant( read that also as wife) and I cut the wing cores the other day and I've just finished trimming and sanding the wings after sheeting. They came out nice. She is really getting the hang of it! I put 3 degrees of washout in them, nothing like washout to tame the savage beast.
My process in skinning is a little different than most. I get new sheets in, don't trim for straight edges( use the factory edge) tape them together tightly and use Gorrilla Glue( skim coat) to adhere them. I don't sand the balsa skins or the hot wire cut cores. I feel the slightly rougher surfaces help the glue adhere the skins.Fast and easy. Don't try this with regular masking tape, it can stick too hard and actually tear the balsa when you take it off. And yes I know because I've done it. I like the 3M low tack blue painter's tape. It's the real smooth tape, not the blue with the lizard like skin on the outside.
Here's how I did it. The wings are sheeted with 1/16" contest balsa and will sand beautifully before I glass them.
J
Old Aug 10, 2010, 07:37 PM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
I'm In!! This is gona be a great build! Yes John, you have the jump on it again... I am going to move to either your way of doing the fuse or to the bulkhead and skin method, the current build I'm on I think will be the last box build unless I want something quick and dirty. PINK FOAM!!!! very cool!!!!! I can't get that down here, it is all just the boring blue here,,, guess not enough folks around that like pink to warrent carrying it in stock! w.
Waltjg is offline Find More Posts by Waltjg
Old Aug 10, 2010, 07:42 PM
turbonut is online now
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Jumpin in with this one...Love the Arrow!...
turbonut is online now Find More Posts by turbonut
Old Aug 10, 2010, 08:03 PM
GeoffinIN is offline
Find More Posts by GeoffinIN
Two left thumbs
Muncie, IN
Joined Sep 2006
While not much of a warbird fan, I'll sign on to learn some building techniques - and I must admit, the Pfeil IS a neat bird!
BTW, I hope you don't have any loose dogs out marking territory while your spackle dries. ;-)
Geoff
GeoffinIN is offline Find More Posts by GeoffinIN
Old Aug 10, 2010, 08:35 PM
stacker is online now
Find More Posts by stacker
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
Looks super John! Bet that fuse will scare away the birds also ;-)
Prop and power system are the same as the HE219 I've been building. Props are the ones used on the Parkzone ME109. Hope to have the 219 finished for Vegas so we can show them together as they are the same 1/11th scale.
If the Do335 works out there is a rumor of a ME410 down the road.
Keep hammering away J.
Cheers--Stacker
stacker is online now Find More Posts by stacker
Old Aug 10, 2010, 08:57 PM
jhspring is online now
Find More Posts by jhspring
Oh no, not again!
jhspring's Avatar
United States, LA, Carencro
Joined Dec 2005
Gawd, the two of you teamed up boggles the imagination. You're going to be cranking out planes like Willow Run before you're through. Love watching you guys work. This will be fun.
Jeff
jhspring is online now Find More Posts by jhspring
Old Aug 10, 2010, 09:27 PM
Old Man is offline
Find More Posts by Old Man
Master of the figure 9
Old Man's Avatar
United States, IN, Indianapolis
Joined May 2004
Subscribed
Old Man is offline Find More Posts by Old Man
Old Aug 10, 2010, 09:32 PM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Hey guys, thanks for the nice comments.
I found a few pics I had forgotten to post. The wing was cut in two sections for each wing. Much easier that way and we, the Mrs ( aka Mrs CNC) and me got really nice cuts. Then I glued the saddles and wing cores together.
I have also formed the rudders and stabs. I used two layer of 9mm Depron for them. I just finished installing the tips and sanding the airfoil shape into them today but didn't load that pic.
I also got the aileron position cut into the wing and the ail wire channel bored in. So they are now ready to cut the ailerons out of.
J
Old Aug 11, 2010, 08:48 AM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
The plug is ready and has three coats of wax. I think I will give it one more and then spray on a coat of PVA before glassing. Hopefully will be glassing tomorrow.
The rudders and stabs are shaped and spackled. They will be ready for glass soon. I inserted a piece of 1/2" balsa on the hinge lines. When I cut the control surfaces off this will give me a 1/4" LE for the control surface and 1/4" for the hinge surface.
I used my hi tech tools to cut the channel for the aileron wires. A sharpened section of old antenna aluminum and then a dowel with sanding paper to enlarge the hole.
Next up will be LE & TE on the wings before I can make the ailerons and flaps.
J
Old Aug 11, 2010, 11:27 AM
Waltjg is offline
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Man, looking good!!, and your so fast! Did you go to bed last night?????? Liked the idea about the 1/2" stock in the stabs and fin so when you cut the flying surfaces that will be already there! cool trick John! Well, gotta get at that darn grass out there, then I might be able to work on mine just abit... w.
Old Aug 11, 2010, 09:09 PM
mtflyr is offline
Find More Posts by mtflyr
Centreville,VA,USA
Joined Apr 2001
Very cool John Took me awhile to tell the fuselage was underside up
Great job on the hot wire fuselage sections.
Pete
mtflyr is offline Find More Posts by mtflyr
Old Aug 11, 2010, 11:35 PM
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
hey John if the fuse plug servives pulling the fiberglass skin off send me the plug and I will make a ral mold off it!..
Contest Scratch Build Off 3 - Dornier Do 335 Pfeil michaelghammer Scale Kit/Scratch Built 244 Jan 25, 2012 07:50 AM
For Sale Dornier DO-335 Arrow Custom ARF rcdude01 Aircraft - Electric - Airplanes (FS/W) 4 Aug 17, 2010 08:14 PM
Sold Dornier DO-335 Arrow Custom RTF rcdude01 Aircraft - Electric - Airplanes (FS/W) 4 May 31, 2010 09:41 PM
Sold Dornier DO-335 Arrow Custom RTF rcdude01 Aircraft - Electric - Airplanes (FS/W) 2 May 23, 2010 11:15 PM
Dornier Do-335 "Pfeil" Build jcarstan Slope 52 Jan 23, 2006 04:06 PM
