Leduc, AB, Canada
Joined Oct 2008
I have not used them in mine yet, but there is no reason why they should not work. The original retract mechanisms in the Seafire are identical to the ones in the Seagull Dewoitine which the 120 size E-Flites just "drop in" with no modifications. They also worked great in the Dewoitine up until I put the plane into the ground. Cheers, Peter |
if anyone does not want to use the oleos that come with the seafire these fit great.
http://www.rcskylite.com/products/40...1-Mustang.html they fit straight in with just a little sanding needed on the plastic stopper on the stock retracts.so they retract fully and lock up.well made,cheap and look great.much better metal than the stock legs.though i have not flown it yet and dont no how they hold up in flight.should not see a problem. |
Leduc, AB, Canada
Joined Oct 2008
Cheers, Peter |
I ended up emailing Himax to see if they could do a custom spinner but the answer was no. I will be keeping a close eye on this thread http://www.rcgroups.com/forums/showthread.php?t=1518987 to see what scatsob comes up with!
Can I ask how those electric people are accessing their batteries?
When I spoke to J Perkins (the UK distributor) they told me you had to remove the wing after every flight and it shouldn't be a problem. I'd like to cut a battery hatch around the canopy but I've never done this before and don't want to ruin the looks. Any feedback much appreciated. Andy |
One more question, has anybody built in any right / downthrust on the motor mount to counter the effects of torque roll?
Most larger models don't need it and it doesn't look like the manual suggests the addition of any so I'm inclined to fix the motor on straight. Was wondering what existing owners would recommend? |
| Thread Tools | |
| Build Log Supermarine 381 Seagull | hortid | Waterplanes | 13 | Jan 08, 2012 07:36 AM |
| For Sale seagull models 90 size yak 54 new in box | bret555 | Aircraft - Fuel - Airplanes (FS/W) | 0 | Oct 01, 2009 08:55 PM |
| For Sale Seagull Models Yak 54 $300 | Madbob9 | Aircraft - Electric - Airplanes (FS/W) | 5 | Sep 11, 2009 12:23 PM |
| Discussion Electric Supermarine Seagull 381 Amphibian Plus... | Airboatflyingshp | Scale Electric Planes | 46 | Jul 24, 2009 07:31 AM |
