Old Aug 09, 2010, 08:35 AM
gupi is offline
Find More Posts by gupi
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
Build Log
Peter Rake's Fokker F.II - 30" Prototype Build
Peter Rake kindly lets me build a prototype of his 30" Fokker F.II.
Currently i'm studying the plan and will probably visit my local modeling shop for laser cutting the parts later this week.
From Wikipedia:
The Fokker F.II was the first of a long series of commercial aircraft from the Fokker Aircraft Company, flying in 1919. In a biplane age, it presented a distinct clean, high wing monoplane style that sold successfully across Europe and North America during the development of commercial passenger-carrying aviation
General characteristics
Crew: One pilot
Capacity: 5 passengers
Length: 11.65 m (38 ft 3 in)
Wingspan: 16.10 m (52 ft 10 in)
Height: 3.66 m (12 ft 0 in)
Wing area: 38.2 m² (411 ft²)
Empty weight: 1,200 kg (2,650 lb)
Gross weight: 1,900 kg (4,190 lb)
Powerplant: 1 × Armstrong Siddeley Puma, 180 kW (240 hp) each
Performance
Maximum speed: 150 km/h (93 mph)
Cruising speed: 120 km/h (75 mph)
Range: 1,200 km (750 miles)
gupi is offline Find More Posts by gupi
Last edited by gupi; Aug 10, 2010 at 11:53 AM. Reason: Added data of the original Fokker F.II
Old Aug 09, 2010, 08:37 AM
gupi is offline
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
Pete,
I noticed two issues while looking at the plan:
1. On the plan it seems that rib R7 is marked twice, while R8 is missing.
2. On the sheet with the parts to cut, TE1 is missing.
gupi
Old Aug 09, 2010, 08:57 AM
PETERRAKE is offline
Find More Posts by PETERRAKE
Norfolk, England
Joined Sep 2001
Oops. The ribs themselves were correct, both on plan and cut file, I just labelled two the same. The missing trailing edge piece is now added and I've sent you the revised file.
Pete
PETERRAKE is offline Find More Posts by PETERRAKE
Old Aug 10, 2010, 12:02 PM
gupi is offline
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
Thanks, Pete.
I'm thinking to use the classic KLM color scheme. They were Fokker's first customer.
gupi
Old Aug 13, 2010, 12:11 PM
gupi is offline
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
Finally it's getting serious. I visited my model shop today and printed out the plan two times: one for building on it and one to hang on the wall for reference.
I ordered the laser cut pieces, too. If everything works out, i might get the parts tomorrow already.
Pete,
Living in a country with metric units I can't get imperial sized wood. So my build will be a little off in weight i guess - and i might have to sand the spars a bit to make them fit into the ribs.
gupi
Old Aug 13, 2010, 03:50 PM
Norfolk, England
Joined Sep 2001
gupi,
Yes, if you use 2.5 mm sheet. It's only 0.1 mm though, so depends on the accuracy of the cutting - and the accuracy of the wood thickness.
That's pretty quick service you get there.
Pete
Old Aug 14, 2010, 04:40 PM
gupi is offline
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
My favorite model shop delivered!
I've got all laser cut parts ready and verified on the plan. The ribs fit nicely on the spars. Everything looks very good now.
Old Aug 14, 2010, 04:43 PM
gupi is offline
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
Pete,
I noticed that wire part A is printed as 16 swg on the plan, but in the shopping list it says 18 swg.
gupi
Old Aug 14, 2010, 04:59 PM
gupi is offline
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
Dry fitting the left halve of the wing. I bravely resist the urge to start glueing and go to bed for today. It's better to start a build well rested.
Old Aug 14, 2010, 06:39 PM
Norfolk, England
Joined Sep 2001
Thanks mate. It's now corrected on the plan and should, of course, have said 18 swg.
Those laser cut parts look rather nice. It's no bad thing that they appear to fit well too.
Pete
Old Aug 15, 2010, 11:31 AM
Norfolk, England
Joined Sep 2001
The lighting isn't really working on those photos. The ones you took of the wing assembly are much sharper and more crisp. Remember that without good photos, I have nothing to publish. Therefore, I hope you're saving the uncompressed images for me.
That said, the model seems to be progressing nicely. Interesting technique of gluing the parts to the film.
Pete
Old Aug 15, 2010, 01:19 PM
Deuce is offline
Find More Posts by Deuce
Übung macht den Meister..
Deuce's Avatar
United States, OR, Fairview
Joined Jul 2006
Pete
Indeed! I took note of that as well. I admit having observed how the film still "sticks" to the structure a bit when removing the parts from the board, but I'd never thought to actually utilize that effect! Sehr klug, gupi!
James
Deuce is offline Find More Posts by Deuce
Old Aug 15, 2010, 04:10 PM
gupi is offline
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
Pete,
I feared that the light might not be enough. I'm very sorry about that. The other photos were taken on the kitchen table (vs. my regular building table, which is much smaller by the way). I'll take the photos on the kitchen table again until i manage to get better lighting for the building table. Sure I keep the originals, the ones I'm posting here have to be downsized otherwise i can't post.
Pete, James,
Thanks for the praise for the technique. I've read a build log some time ago where someone used CA to glue his build to a glass table with the plan taped underneath and thought: this might work with clear film, too. It allows for very quick builds.
gupi
Build Log Peter Rake Sopwith Tabloid (Late) Prototype Build. MerlinV Scale Kit/Scratch Built 153 Nov 22, 2013 05:28 AM
Build Log Peter Rake 48" DH-6 prototype build Dan Parson Scale Kit/Scratch Built 222 Mar 11, 2012 02:18 PM
Build Log "The Rooster" Peter Rake's Samolot Kogutek | Prototype Build hoffboy Scale Kit/Scratch Built 91 Nov 21, 2011 02:10 AM
Build Log Peter Rake's Macchi M16 - prototype build Redbaron25 Scale Kit/Scratch Built 82 Jan 25, 2011 05:27 AM
Build Log Peter Rake IPS Pfalz EIII Prototype Build Dan Parson Scale Kit/Scratch Built 158 Sep 19, 2010 04:28 AM
