Old Mar 19, 2013, 12:12 PM
aspeed is online now
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
For a combat plane, I think the best would be a modern F2D plane. They work good with a .15 or .25 motor. Check the F2D FAI sites for plans. No really uses plans any more because the planes are so cheap in the RTF form. $50 or so. They are pretty tough in a crash too, although they don't usually escape from midairs. Someone will maybe chime in on them.
aspeed is online now Find More Posts by aspeed
Old Mar 20, 2013, 03:44 AM
Otech66 is offline
Find More Posts by Otech66
Australia, TAS, Launceston
Joined Mar 2013
Here is a copy of a late model combat wing(armageddon 2004). I have one I built. Its easy to fly flat and level if you are used to something fairly fast, when you pull on the up or down they turn like something awesome. Great fun with two in the circle.
I run a Parra 2.5 engine in mine. There are more on the hippocket site.
Regards Otech66
Otech66 is offline Find More Posts by Otech66
Old Mar 20, 2013, 04:43 AM
greggles47 is offline
Find More Posts by greggles47
Greggles47
greggles47's Avatar
Sydney OZ
Joined May 2007
Originally Posted by JohnAV8R View Post
Are there any plans posted here for the modern combat wings?
I'm from the Flight Streak Fox .35 era.
I'm badly out of touch with CL and would like to get back in.
I'm presently building a Peace Maker to get back into U/C.
John
John,
Plenty of combat models of all ages on Hip Pocket.
Greg
greggles47 is offline Find More Posts by greggles47
Old Mar 20, 2013, 09:40 AM
Bob Mears is offline
Find More Posts by Bob Mears
F2D Pilot/Mechanic
Bob Mears's Avatar
United States, TX, Lubbock
Joined Dec 2011
John
John, Barry Baxter has all the plans you would ever want for combat planes
http://www.controllineplans.com/index.htm
Many of mine were built from his plans
http://www.rcgroups.com/forums/member.php?u=387956
Bob Mears is offline Find More Posts by Bob Mears
Old Mar 20, 2013, 05:22 PM
JohnAV8R is online now
Find More Posts by JohnAV8R
Canada, ON, Hamilton
Joined Oct 2005
Thank you gentlemen.
More than enough to get me started.
I have a Cox Conquest and Parra 2.5 and just got a roll of Doculam.
My Peace Maker, empty is coming in around 12 oz, maybe too heavy for a .15?
I think I better take it easy for the first few flights, like perhaps my old Flight Streak and Fox .35 on 60 ft lines. Really looking forward to a change with U/C.
Thanks again.
John
JohnAV8R is online now Find More Posts by JohnAV8R
Old Mar 21, 2013, 06:02 AM
Greggles47
greggles47's Avatar
Sydney OZ
Joined May 2007
Sounds good John,
12 oz of Peacemaker presumably 6oz oz engine & fuel = 18oz
Should give very spritely performance.
Greg
Old Mar 29, 2013, 09:22 AM
keeferm is offline
Find More Posts by keeferm
Joined Jan 2007
Combat Flite Streak
I tried the tutorials in Outerzone - Didn't take too long to turn a really ugly old, well-tanned plan into a properly scaled version.
keeferm is offline Find More Posts by keeferm
Old Apr 03, 2013, 03:40 PM
flyinglog is offline
Find More Posts by flyinglog
1234567
flyinglog's Avatar
Deutschland, Berlin
Joined Aug 2011
Hegi 40
Hello everyone !
I have a question: do someone have a kit for a HEGI 40 and could scan the Parts ?
Because the plan is just how to get it together, and no parts drawn.
here is a pic of an old catalogue :
http://www.rc-network.de/forum/attac...0&d=1343763178
it is the one in the lower left corner
Best regards, Sebastian
flyinglog is offline Find More Posts by flyinglog
Old Apr 04, 2013, 09:06 AM
Joined Oct 2005
Thanks Keeferm.
I built one of those years ago and flew it with an Enya .29.
Old Apr 04, 2013, 11:44 AM
perttime is online now
Find More Posts by perttime
perttime's Avatar
Finland
Joined Nov 2004
I don't think the Modelhob MiG-3 has been posted here before.
I reduced file size a bit from the copy that was on HPA.
(the picture is a small preview)
perttime is online now Find More Posts by perttime
Old Apr 18, 2013, 08:56 PM
raglafart is offline
Find More Posts by raglafart
Australia, NSW, Bowral
Joined Jul 2008
Here's a Shoestring for 09's and 23" span.
raglafart is offline Find More Posts by raglafart
Old Apr 21, 2013, 10:30 AM
Vrated is offline
Find More Posts by Vrated
Vrated's Avatar
United States, UT, Marysvale
Joined Aug 2004
The Combat Streak was my first .35 sized control liner. Was fun for a 14 year old boy with a new 6 dollar McCoy .35. A quart of K&B fuel was a buck and a half !Plus a buck and a quarter for a 1-1/2 old dry cell. My paper route had no problems sponsoring me for this great hobby back then.
Vrated is offline Find More Posts by Vrated
Old May 04, 2013, 11:55 AM
perttime's Avatar
Finland
Joined Nov 2004
Napier-Heston Racer
Also known as Heston Type 5 Racer or Heston High Speed Aircraft J.5 (and probably a few other designations)
This plan seems to be John Emmett's design originally published in Aeromodeller, August 1989. I'm not sure if it is just a scan or if someone has worked on the plan after scanning.
21" span
Designed for electric power over the lines. "540-550" motor, 6x3 prop at 18000rpm, 7 to 12 meter lines.
Old May 05, 2013, 01:02 PM
gghisleri is online now
Find More Posts by gghisleri
gghisleri's Avatar
Joined Apr 2004
I-Baga 14
This is an absolutely original model, both in construction method and aerodinamic.
Note the engine offset, it was designed to fly slow but precise.
This model placed 10th at World Champs in 1966 and 68.
I have 23 A4 pdf files that joined together should give the full size plan.
The zip file is worth 13 Mb.
Should someone be interested send your e mail.
gghisleri is online now Find More Posts by gghisleri
Old May 05, 2013, 10:54 PM
ama353 is offline
Find More Posts by ama353
ama353's Avatar
United States, MN, New Prague
Joined Apr 2011
Combat Plans
John
Barry is a good source; I also have several, with more coming:
http://stores.ebay.com/airclassix
Dennis
ama353 is offline Find More Posts by ama353
Help! Control line plans from vintage model magazines kenny e Control Line 18 Sep 23, 2011 04:09 AM
Discussion Control line world phill98765 Control Line 1 Jul 24, 2010 03:46 PM
Help! Avro Lancaster and HP Halifax Control Line plans Z1007 Control Line 6 Sep 22, 2009 08:12 AM
Help! Avro Lancaster and HP Halifax Control Line plans Z1007 Scale Fuel Planes 0 Sep 15, 2009 07:19 AM
Wanted Plans for Fairchild Packet (Flying Boxcar)twin engined control line control l mchandrayan Aircraft - Fuel - Airplanes (FS/W) 3 Oct 10, 2005 08:44 PM
