Old Mar 06, 2013, 08:37 AM
gghisleri is online now
Find More Posts by gghisleri
gghisleri's Avatar
Joined Apr 2004
Originally Posted by electrotor View Post
Yes I can do those too if you want, but you must send me the high quality scans. I have already sent you a PM with my email address. The images which appear on the pages here are reduced to fit the file size parameters of the Forum. Once I have the scans I will make pdfs or whatever anybody wants and post them here or send them via email if the file type is too large for this site or not the right type. Back to you gghisleri.
BTW the best scan format for me is TIF but any other normally used type will suffice. File conversion is quick and easy. File cleaning up (despeckling) can take an age but I have sometimes had to do this on a really poor image showing rips, tears and pieces of sticky tape. Most images are recoverable but sometimes the effort required is enormous. Apart from the shading and distortion on the scans of the Zephyr, which are easily solvable if you remove the page from the magasine, your images look OK to convert with little extra work.
Perttime has already received high resolutions scan of the Zephyr and told me that they are worth working on, I also sent the scan of the central part with no shadows or distortions.
I'll send high resolutions jpgs as soon as I reiceve your e-mail.
I have other plans...............
gghisleri is online now Find More Posts by gghisleri
Old Mar 06, 2013, 02:33 PM
perttime is offline
Find More Posts by perttime
perttime's Avatar
Finland
Joined Nov 2004
By the time I got the Zephyr down to a size that I can post here, I was losing some of the detail...
I THINK the plan is to a correct size. Piecing the plan from three parts, I had some difficulties making the parts match. It isn't perfect...
Someone else might do better.
perttime is offline Find More Posts by perttime
Old Mar 06, 2013, 04:16 PM
electrotor is offline
Find More Posts by electrotor
Bonnie Scotland
Joined Jun 2004
I sent a PM yesterday with my email address. Please check your messages inbox on this Forum.
electrotor is offline Find More Posts by electrotor
Old Mar 07, 2013, 12:50 AM
alf.g is offline
Find More Posts by alf.g
NOT SCREWED UP
alf.g's Avatar
Australia, VIC, Melbourne
Joined Jun 2011
great Job perttime. This one is on my build list.
alf.g is offline Find More Posts by alf.g
Old Mar 07, 2013, 10:28 AM
perttime is offline
perttime's Avatar
Finland
Joined Nov 2004
plans by the many times European Champion Luciano Compostella.
I like the style of the Jose Carioca. I'm pretty sure a modernized version of the Kamacc (for 4 stroke engine etc.) is somewhere in this thread (I'm sure it can be found at HPA and Outerzone)
I'm not quite happy with it. Do check dimensions and alignments before committing...
Old Mar 07, 2013, 11:06 AM
perttime is offline
perttime's Avatar
Finland
Joined Nov 2004
... Speaking of Outerzone... One of the latest plans is Graupner's Ultra Stunter:
Old Mar 07, 2013, 03:04 PM
gghisleri's Avatar
Joined Apr 2004
Mc202
Would someone work on this drawing?
Compostella's design.
Old Mar 08, 2013, 04:49 PM
Bonnie Scotland
Joined Jun 2004
gghisleri here they are as pdf files from the scan you sent me. I have split the scan into two files to reduce individual file size, straightened the frame and tried to clean up as best I can. There was a lot of bleed through from whatever image was on the other side of the paper and I cannot sharpen the image any more because the original image is not at a high enough resolution. Perhaps this is because it was a plan reduced in size to fit the page of a magasine. I normally use 300dpi if I have the full sized plan but sometimes go up to 500dpi for reduced plans printed in magazines.
I will send you the jpg and tif versions via email because they are too large to post on RC Groups.
Old Mar 09, 2013, 02:47 AM
perttime is offline
perttime's Avatar
Finland
Joined Nov 2004
gghisleri,
do you have dates or years for the Jose Carioca and Kamazz?
Also, I don't see a size reference in the plans, except for wheel and wood sizes. Span, or some other large measurement would be good for confirming correct scaling.
The Jose Carioca plan seems to say that the outer wing is 5cm shorter.
Old Mar 09, 2013, 04:07 AM
Bonnie Scotland
Joined Jun 2004
There were no control dimensions for me to work with so I could not scale the plan.
Old Mar 09, 2013, 05:06 AM
gghisleri's Avatar
Joined Apr 2004
I have this plan also for Camach, can't say nothing about Josè Carioca even if I built it when I was 17, 51 years ago.
The original jpg is worth 5 Mb.
Yes, the outer wing is 5 cm shorter.
The caption on this drawing says that Luciano and Camach were Italian Champion in 1961.
Old Mar 10, 2013, 08:27 AM
perttime is offline
perttime's Avatar
Finland
Joined Nov 2004
Kevin Wright of Australia has just produced CAD plans for a pretty famous design:
Stanislav Cec's 1983 European Championship winning UNO F2B stunter.
http://controlline.org.uk/phpBB2/vie...=8115&start=15
Some time ago I started on a set of CAD plans for Stanislav Cec's UNO F2B stunter. Many thanks to those who sent me drawings.
I've been sidetracked for a while but have now completed the plans to
my satisfaction and commenced constuction.
Note I have Stanislav Cec's approval to make these plans available.
If I interpret the plan correctly, it is done with a detachable wing.
Old Mar 12, 2013, 08:30 PM
keven64 is offline
Find More Posts by keven64
Model Designer
keven64's Avatar
United Kingdom, England, Burnley
Joined Apr 2001
Ciao gghisleri !
I played a little with your small scan of the semi-scale Macchi Folgore fighter plans...
...and produced the .pdf file added below.
Overall wingspan is stated as being 1450mm - which should be exactly 57" as near as makes no difference.
(about 8/100ths of an inch)
That's what I have it at - 57" wingspan.
Even with that image as it is - there is quite some work needed to add to it the detail required to construct a model from it
Keven.
keven64 is offline Find More Posts by keven64
Old Mar 13, 2013, 03:16 AM
gghisleri's Avatar
Joined Apr 2004
Thanks Keven64
One more, as usual I can send high resolution jpg if you send your e mail.
Victor Typhoon, 90 vintage, by A.Nencioni.
Old Mar 19, 2013, 11:41 AM
JohnAV8R is offline
Find More Posts by JohnAV8R
Canada, ON, Hamilton
Joined Oct 2005
Are there any plans posted here for the modern combat wings?
I'm from the Flight Streak Fox .35 era.
I'm badly out of touch with CL and would like to get back in.
I'm presently building a Peace Maker to get back into U/C.
John
JohnAV8R is offline Find More Posts by JohnAV8R
Help! Control line plans from vintage model magazines kenny e Control Line 18 Sep 23, 2011 04:09 AM
Discussion Control line world phill98765 Control Line 1 Jul 24, 2010 03:46 PM
Help! Avro Lancaster and HP Halifax Control Line plans Z1007 Control Line 6 Sep 22, 2009 08:12 AM
Help! Avro Lancaster and HP Halifax Control Line plans Z1007 Scale Fuel Planes 0 Sep 15, 2009 07:19 AM
Wanted Plans for Fairchild Packet (Flying Boxcar)twin engined control line control l mchandrayan Aircraft - Fuel - Airplanes (FS/W) 3 Oct 10, 2005 08:44 PM
