Old Jan 03, 2013, 03:49 AM
greggles47 is offline
Find More Posts by greggles47
Greggles47
greggles47's Avatar
Sydney OZ
Joined May 2007
Originally Posted by locktite401 View Post
The VTRSIG Thunder Thrush is a very attractive 1/2A Vintage Team racer (1.5cc diesels) with everything in the right place except the CG. I've seen two built to the plan, both light and straight, and both were on the verge of being uncontrollable.
I'd suggest mounting the engine another 1/2" further forward.
I do have a high resolution pdf scan of the plan somewhere.
Ray
Ray,
I built one to the plan and it flew beautifully. Motor was a PAW plain bearing CT.
so with a TBR a 1/4 to 1/2 would work well. Or move the wing back.
Greg
greggles47 is offline Find More Posts by greggles47
Old Jan 03, 2013, 04:24 AM
locktite401 is offline
Find More Posts by locktite401
Joined Nov 2008
Originally Posted by greggles47 View Post
Ray,
Greg
Ah Greg, I'd forgotten about yours.
The two I mentioned were Dave's and Brent's both with OTC.
Unusually the PAW plain bearing bushed blue headed 1.5cc diesel is considerably heavier than either it's twin ball bearing brother or the Oliver Cub.
That might explain your contrary result.
I do have a hi res scan of the plan (1.1 Meg). It just needs rescaling.
Ray
locktite401 is offline Find More Posts by locktite401
Old Jan 03, 2013, 06:05 AM
LIVEFIBRE is offline
Find More Posts by LIVEFIBRE
REDCLIFFE AUSTRALIA
Joined Apr 2007
Description:
Description:
Description:
Description:
Description:
Description:
Description:
LIVEFIBRE is offline Find More Posts by LIVEFIBRE
Old Jan 03, 2013, 10:16 AM
perttime is online now
Find More Posts by perttime
perttime's Avatar
Finland
Joined Nov 2004
I thought the Thunder Thrush might have been posted in the Control Line Team Racer plans and pictures thread ... but apparently not.
http://www.rcgroups.com/forums/showthread.php?t=1530258
perttime is online now Find More Posts by perttime
Old Jan 03, 2013, 05:20 PM
Joined Nov 2008
I'll sort out the proper scale for my copy, turn it into a pdf and post it in the next few days.
I've also found the VTRSIG plan for the 1/2A Nurk. We had one of these in the late 90's and it was spot on. I suspect that John Nolan had a good'in as well.
I'll get it scanned the next time round.
Ray
Old Jan 03, 2013, 09:11 PM
Mooney_Driver is offline
Find More Posts by Mooney_Driver
Mooney_Driver's Avatar
USA, WA, Ellensburg
Joined Mar 2004
There is also a short thread about the Thunder Thrush here:
http://www.nclra.org/WayneTrivin/ThunderTrush.html
with a small plan of it.
Mooney_Driver is offline Find More Posts by Mooney_Driver
Old Jan 04, 2013, 12:06 AM
Joined Nov 2008
That's a nice little model but I'm sure that isn't the 6x6 Graupner the Poms use.
I'd guess that the right one would be the 6x6 Graupner "Grey". I tried those electric props and they were far too flimsy.
Pity about the MVVS as well. They're well within the rice pudding skin pulling power curve.
I'll do the plan tonight.
Ray
Old Jan 04, 2013, 02:56 AM
Greggles47
greggles47's Avatar
Sydney OZ
Joined May 2007
Wayne Trivin was a first class modeller, his pages have been kept by the NCLRA as a tribute to his skill as a modeller.
http://www.nclra.org/WayneTrivin/Actualindex.html
Old Jan 04, 2013, 04:42 AM
REDCLIFFE AUSTRALIA
Joined Apr 2007
Description:
Old Jan 04, 2013, 05:03 AM
Joined Nov 2008
Ok,
here's the pdf of the Thunder Thrush Vintage 1/2A team racer for 1.5cc diesel engines. I've scaled it to a span of 19" as it's the largest dimension on the plan. Otherwise the wing chord and the wheel size are slightly smaller in actuality c/w their dimensions. I suspect that the paper plan from which this was scanned was a photo copy of a photo copy ... etc.
There's a nice bit of British Pythonese humor in the name "Thunder Thrush". It's a scaled down Mercury B class TR called a "Thunderbird".
If you pass the plan on can you include a note about the probable necessity to extend the nose 0.25 to 0.5" or to move the wing back the same distance if using a CS Oliver Cub clone or a real one.
I've submitted plan and pic to Hippocket.
Ray
Old Jan 07, 2013, 04:24 PM
aeromeddeler is offline
Find More Posts by aeromeddeler
Soulles Normandy France
Joined Feb 2011
Lieutenant 48" span C/L stunt
Sure Fun 37" span C/L ( J Roberts flight control system ) sport
Thunderbolt 28" Span C/L Scale P47N Thunderbolt
aeromeddeler is offline Find More Posts by aeromeddeler
Old Jan 08, 2013, 05:59 PM
Joined Feb 2011
Model Airplane News January 1959
Supermarine S6B 29.5" span C/L scale
Old Jan 09, 2013, 04:50 PM
Joined Feb 2011
From Aeromodeller January 1972
Beagle Basset 45" Span 1/12 scale C/L twin
Old Jan 10, 2013, 08:58 AM
flyinglog is offline
Find More Posts by flyinglog
1234567
flyinglog's Avatar
Deutschland, Berlin
Joined Aug 2011
I always liked the "Von Lopez" Designs
Here is the 1/2A Samurai
Anyone knows if he is still flying ?
Regards,Sebastian
flyinglog is offline Find More Posts by flyinglog
Old Jan 10, 2013, 04:33 PM
Joined Feb 2011
motto look before you leap
why
see next post
Help! Control line plans from vintage model magazines kenny e Control Line 18 Sep 23, 2011 04:09 AM
Discussion Control line world phill98765 Control Line 1 Jul 24, 2010 03:46 PM
Help! Avro Lancaster and HP Halifax Control Line plans Z1007 Control Line 6 Sep 22, 2009 08:12 AM
Help! Avro Lancaster and HP Halifax Control Line plans Z1007 Scale Fuel Planes 0 Sep 15, 2009 07:19 AM
Wanted Plans for Fairchild Packet (Flying Boxcar)twin engined control line control l mchandrayan Aircraft - Fuel - Airplanes (FS/W) 3 Oct 10, 2005 08:44 PM
