Old Aug 08, 2010, 01:19 PM
bob.titus is offline
Find More Posts by bob.titus
Flying at Sochi 2014 Olympics
bob.titus's Avatar
France, IDF, Paris
Joined May 2009
FAQ
How to turn your + mode quad into X
If there is no native "X" mode by software on you quad, to transform it from "+" mode to "X" mode, you just need to use "delta mix" (or "elevons" on Futaba) on your radio, or a delta mixer such as this one if your radio doesn't have delta mix.
It is as simple as that, that's all you need to do, no change at all has to be made on the quad, everything stays the same as for + (flight controller orientation and so on).
Of course, having delta mixed X mode requires that your quad was tested and flying in + mode prior to switching to X mode
Hope this helps,
Bob
bob.titus is offline Find More Posts by bob.titus
Old Aug 08, 2010, 06:16 PM
JET MAN TWO is offline
Find More Posts by JET MAN TWO
United States, PA, Erie
Joined Dec 2006
Hope this helps,
Bob
I fly both of my quads with the "X" configuration, just as Bob suggested, and it works flawlessly for me. give it a try!
Jettman
JET MAN TWO is offline Find More Posts by JET MAN TWO
Old Aug 08, 2010, 11:24 PM
5artist5 is offline
Find More Posts by 5artist5
Joined Jun 2010
What are the pros and cons of X mode vs + mode?
is one more stable or maneuverable?
5artist5 is offline Find More Posts by 5artist5
Old Aug 09, 2010, 01:55 AM
bradleyK is offline
Find More Posts by bradleyK
Joined Jun 2010
+ has prop in center view
X has parts of prob on the sides
bradleyK is offline Find More Posts by bradleyK
Old Aug 09, 2010, 05:26 AM
bob.titus's Avatar
France, IDF, Paris
Joined May 2009
+ has a leg "dragging" in the way, X doesn't.
X flies more like an aircraft I feel, I find it smoother and sharper at the same time, but that's merely my own feeling.
I personally went to X one day last year and never went back to +
Now, the best way is to try for yourself, don't you think?
Bob
Old Aug 09, 2010, 07:18 AM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Bob, would you have a diagram of the wiring?
Thank you.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Aug 09, 2010, 08:04 AM
bob.titus's Avatar
France, IDF, Paris
Joined May 2009
Thank you.
what wiring? Nothing changes on the quad.
Then, if you're talking about the delta mix module, you just connect ail to ail and ele to ele from flight controler to module and from module to RX.
The module is in fact just between the RX and FC and mixes the signal 50/50 like the radio mix would do, that's all.
Bob
Old Aug 09, 2010, 08:09 AM
Joined Aug 2009
Hmmm, Interesting.
Thank you.
Old Aug 09, 2010, 05:35 PM
culexus is offline
Find More Posts by culexus
Norway Haugesund
Joined Jun 2010
Okey
As always I got my questions hihi!
Im going to fly in "x" mode and wondering what direction will be the front?
I made a picture from some info I found on the fist side of this forum.
Could some one just tell me out from my picture what color dot that will face the front of the quad in "x" mode?
I hope the picture is right and easy to understand And maby help others
culexus is offline Find More Posts by culexus
Old Aug 09, 2010, 05:38 PM
culexus is offline
Norway Haugesund
Joined Jun 2010
Sorry, I forgot the picture
Old Aug 09, 2010, 05:43 PM
ddrake is offline
Find More Posts by ddrake
ddrake's Avatar
Milan
Joined Mar 2007
How to turn your + mode quad into X?
I just hold the transmitter rotated 45 clockwise.
Sorry, just couldn't resit :P
Isn't the delta mix a problem if the board expects some specific positions for calibration, engines start / stop etc?
regards
ddrake is offline Find More Posts by ddrake
Old Aug 09, 2010, 06:32 PM
bob.titus's Avatar
France, IDF, Paris
Joined May 2009
front is red, between front arm and right arm.
Always do a test holding the quad over your head before flying every tiume you experiment something new, it doesn't hurt to make sure all is fine before getting airborne.
Pre-check is something you must do anyway, don't forget
Bob
Old Aug 09, 2010, 06:38 PM
bob.titus's Avatar
France, IDF, Paris
Joined May 2009
regards
no, no change at all, unless you need cyclic for calibration (MK?), then it could be a problem.
But since MK has software X mode, just use it
Bob
Old Aug 10, 2010, 08:48 PM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
Since Bob gave such simple and clear instructions I just had to give x mode a try. Just for the record my + mode quad rotated 45 degrees CW and made the green dot quadrant the forward without doing anything but turning on elevon mix on spektrum tx .
^not the same flight controller as pic'd above^
pug398 is offline Find More Posts by pug398
Old Aug 11, 2010, 04:16 AM
bob.titus's Avatar
France, IDF, Paris
Joined May 2009
Would you have a QuadPowered by any chance?
I'm asking this question because from what I recall, George being left handed has done sone 'unconventionnal' things with the code.
But this could be the Spektrum as well...
Please feedback so I can update the instructions here.
Bob
Help! Can't get AR6110e into bind mode? marhar Beginner Training Area (Aircraft-Electric) 7 Jul 27, 2010 11:30 PM
Discussion X mode quad using standard hobby gyros? RCvertt Multirotor Talk 12 Jun 19, 2010 08:46 PM
Discussion Turn your Kia into a supercar:D speedy_1 Australia 43 Feb 22, 2010 06:20 AM
Discussion How to turn your illegitimate planes into legit ones. HappyKillmore Electric Plane Talk 54 Nov 26, 2008 03:40 PM
