Old Aug 07, 2010, 07:38 PM
Jab69 is offline
Find More Posts by Jab69
Jab69's Avatar
South Africa, GP, Alberton
Joined Sep 2009
Biulding with isoboard
HI
Anyone around building planes from isoboard?Is there any diferance between this and depron? I am using polystirene glue instead of UHU POR. Any tips available?
Jab69 is offline Find More Posts by Jab69
Old Aug 08, 2010, 12:20 AM
rebell is offline
Find More Posts by rebell
JustFlying
rebell's Avatar
Joined Dec 2005
You can use Isoboard the same way as polystyrene or cut it to thin sheets like depron. You can also use epoxy or white wood glue very effective.
rebell is offline Find More Posts by rebell
Old Aug 08, 2010, 02:48 PM
MegaTesla is offline
Find More Posts by MegaTesla
Team30 Micro EDF
MegaTesla's Avatar
Stellenbosch, South Africa
Joined Apr 2004
Isoboard is way more flexible than Depron of the same thickness. Use a stiff carbon spar in your wing.
POR is the best glue by far. If you cannot get it where you live let me know then we can sort something out.
MegaTesla is offline Find More Posts by MegaTesla
Old Aug 12, 2010, 11:29 PM
Jab69 is offline
Jab69's Avatar
Joined Sep 2009
Hi
I've tested the polystirene glue an it works just as good as the UHU POR
Old Aug 15, 2010, 06:14 AM
snarf007 is offline
Find More Posts by snarf007
Canada, NS, Yarmouth
Hi Jab
I got Damian from Maiden-wings here in PE to cut me an isoboard wing for a small discus launch glider. I re-inforced it with a carbon spar and sheeted it with 1mm balsa.
I am no expert when it comes to foam, but isoboard seems very similar to the high desity foam, aka spider board.
By the looks of it, it should work as a substitute for depron and people are selling 5mm isoboard. The only thing that wories me is that the isoboard seems far more brittle than depron.
Would be nice to get some feedback from someone that has actually used isoboard as a depron substitute.
Snarf
snarf007 is offline Find More Posts by snarf007
Old Aug 15, 2010, 01:40 PM
Team30 Micro EDF
MegaTesla's Avatar
Joined Apr 2004
I've used both in 2mm and 3mm thicknesses for indoor planes. For that size isoboard is rather useless. I've had someone cnc cut me some slow-flyer undercambered wing cores that is about 8-10mm thick. I haven't used them yet but at that thickness they don't bend much, so should work okay.
Like snarf said it works great for cutting wing cores that will be covered. But then again you can just use high density EPS which should be much cheaper.
Jab, what plane are you building?
Old Aug 15, 2010, 02:31 PM
Jab69 is offline
Jab69's Avatar
Joined Sep 2009
Hi
Ive built a 80cm wingspan stick completely out of isoboard and it is flying perfect. I cut out the sticks wings with a hot wire and cut the isoboard into 7mm sheets. Cut the fuselage sides, top/bottom ,rudder and elevator all out of this.Glued it all together with epoxy. I took 4 icecream sticks and glued it to the inside from the nose till under the wing to reinforce it.I cut a 10mm piece of isoboard for the firewall onto which I glued a piece of plywood for the motor.
Old Sep 02, 2010, 04:39 PM
snarf007 is offline
Hi MegaTesla
It is a 1m DLG with an AG03 Airfoil and based on Fransbal's Mimi. Have look in the DLG forums. The only problem is that the AUW should be around 140g, but my wing alone weighs in at 90g, but there are Mimi's flying that weighs in at 200g.
Snarf
Old Jun 24, 2012, 08:09 AM
Edwin00 is offline
Find More Posts by Edwin00
Joined Jan 2011
The stick you cut, flys like a bat out of hell. Thanks Jab69.
Edwin00 is offline Find More Posts by Edwin00
Old Oct 06, 2012, 08:49 PM
OneLastweedle is offline
Find More Posts by OneLastweedle
Joined Jun 2010
great stuff
OneLastweedle is offline Find More Posts by OneLastweedle
Question Any tips on biulding a 1/6 scale piper cub kit? bouncy-boy Scale Kit/Scratch Built 3 Apr 11, 2007 02:51 PM
Biulding Estarter need conversion chart radcast2 Electric Plane Talk 6 Oct 28, 2004 06:33 AM
corona biulding questions derway Electric Heli Talk 27 Oct 13, 2003 08:12 PM
Biulding my new Zagi larryb Foamies (Kits) 1 Aug 02, 2001 12:56 AM
