Old Aug 07, 2010, 06:01 PM
bradleyK is offline
Find More Posts by bradleyK
Joined Jun 2010
Question
home made indoor, roll vs yaw
hi,
i am planning on making an indoor plane, but i need to choose between yaw and roll,
i will be making it to unlimited vertical and nearly hover so the flaps will be in the prop wash,
bit should i have a v-tail, x-tail ,t-tail or Tailerons
v-tail has roll
x-tail has yaw
t-tail has yaw
Tailerons has roll
bradleyK is offline Find More Posts by bradleyK
Last edited by bradleyK; Aug 09, 2010 at 03:17 AM. Reason: Tailerons not elevators
Old Aug 07, 2010, 07:43 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
A 3D plane needs all functions, roll (ailerons) pitch (elevator) and yaw (rudder)
Almost all 3D foamies use X or cross tail, due to the "shockie" style of construction.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Aug 07, 2010, 07:59 PM
bradleyK is offline
Joined Jun 2010
sorry i meant vertical flight
3d as in xyz
Old Aug 08, 2010, 08:02 AM
Aio_1 is offline
Find More Posts by Aio_1
Aio_1's Avatar
Ireland, Kildare, Leixlip
Joined May 2002
I'm a little confused by your first post but hopefully the following will be useful.
Tee, Vee and conventional cruciform tail configurations can all provide pitch and yaw control. In theory they can all be set-up to provide some roll control too but that's not likely to work well for most aircraft and is usually only done on planes with a small span and large all moving tails like say an F-16 type configuration.
Both conventional cruciform tails and Tee tails are almost always fitted with an elevator or all moving tailplane and a rudder is fitted whenever yaw control is needed. Almost all precision aerobatic planes will have a conventional cruciform tail with a rudder. The main considerations for a Tee tail are that the tail is likely to be heavier, give less symmetrical handling and lower drag. So Tee tail can be good for speed or efficiency but not great for aerobatics.
A vee tail provides the same controls as the other two configurations but because the control surfaces are not in the vertical and horizontal planes it's necessary to mix the movements of the two surfaces to get the appropriate proportions of pitch and yaw control. So the surfaces will move in the same or opposite directions depending on whether pitch or yaw is required and a combination of the two controls involves a mix of the control surface movements. The yaw control from a Vee tail does also produce roll but not effectively and it's not treated as a roll control so much as a yaw control with coupling.
The vee tail is typically lighter than a Tee tail, produces low drag but will tend to to give assymetrical handling.
Roll control is dealt with by ailerons on the main wings for the vast majority of aircraft.
Aidan
Aio_1 is offline Find More Posts by Aio_1
Old Aug 08, 2010, 09:46 AM
pmackenzie's Avatar
Joined Dec 2002
Perhaps he want to make a "tail stander"?
http://www.rcgroups.com/forums/showt...ight=vtol+foam
I think they use 4 control surfaces, with mixing. A local guy has made a few of these, but I never looked too closely at them.
Pat MacKenzie
Old Aug 09, 2010, 01:47 AM
bradleyK is offline
Joined Jun 2010
Aidan
thanks
i meant Tailerons not elevators
Old Aug 09, 2010, 10:14 AM
Aio_1 is offline
Aio_1's Avatar
Joined May 2002
Originally Posted by bradleyK View Post
thanks
I think you need to tell us more about your project. I would assume, given this is the F3P forum, that we're talking about a precision aerobatic plane but that seems unlikely if you're talking about tailerons.
Can you tell us what style of plane you have in mind and how you want it to perform?
Old Aug 09, 2010, 05:23 PM
bradleyK is offline
Joined Jun 2010
i want to make a sort of Concorde
but i only have 2 servos and a 3 ch receiver
Old Aug 09, 2010, 05:49 PM
aerolite is offline
Find More Posts by aerolite
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
BradleyK,
I think you might have much better response to your question in the foamy scratch build thread: The folks over there will be much more familiar with the construction and mix techniques needed for your type of build.
http://www.rcgroups.com/foamies-scratchbuilt-428/
This thread deals with indoor competition pattern and freestyle planes. Hope this helps, and good luck with your build.
aerolite
aerolite is offline Find More Posts by aerolite
Old Aug 10, 2010, 01:28 AM
Aio_1 is offline
Aio_1's Avatar
Joined May 2002
In that case you need to use elevons on the wing trailing edge, mixing pitch and roll control. Yaw cannot replace roll unless you've got significant dihedral which wouldn't really be appropriate for that type of plane.
As aerolite said this belongs in another forum. Also you need to tell people exactly what it is you're trying to find out and give sufficient information to answer your questions. Otherwise those trying to help you will end up wasting their time answering the wrong question.
Old Aug 11, 2010, 08:48 AM
bradleyK is offline
Joined Jun 2010
thank you very much
Discussion home made indoor, roll vs yaw bradleyK Scratchbuilt Indoor and Micro Models 2 Aug 07, 2010 01:53 PM
Discussion Roll, Pitch and Yaw & The Wright Brothers Wilbur/Orville Vintage & Old-Timer Designs 4 Jul 23, 2010 05:36 PM
Discussion INDOOR: Roll Call & poll for Indoor Flying this week: Wed 7:30? or 8p? or Thurs 5:30? Rob-ATL Atlanta Area RC 3 Mar 02, 2010 10:07 PM
Pitch, Roll, and Yaw - March 2002 dave_lilley Sport Planes 0 Mar 14, 2002 07:27 AM
Pitch, Roll, and Yaw - March 2002 dave_lilley Site Chat 0 Mar 14, 2002 07:27 AM
