Old Aug 07, 2010, 02:54 PM
linerfanatic is offline
Find More Posts by linerfanatic
linerfanatic's Avatar
Fort Wayne IN
Joined Aug 2007
Bluefish Maiden Voyage
Just back from the pond with my Dumas Bluefish intact. I had always hesitated to tackle this product due to its troubled reputation. But I found this build to be one of the easiest and quickest. (I do have thin fingers though).
The secret may have been with my choice of glue. I used a two part product called "Plastic Welder" from Devcon (I believe). This stuff really does "weld" plastic together.
As for the run today....
Good news - It floats, it resurfaced, and it stayed dry inside.
Bad news - Radio range with my 27 Mhz Futaba was only about 12 feet. Also some minor condensation inside.
I will need to remove some ballast as it was a tad heavy in the stern. That may explain why it loved to dive and go deep in a hurry.
If you don't recognize the silhouette, this model was built to resemble my Great Uncle's command, the pre-war V-7, USS Dolphin SS-169. He was in command of this sub when it was docked in Pearl Harbor for major work during the month of December 1941.
For the hatch, I used square nuts encased in styrene under the compartment top to mate with 6/32 screws coming down through a clear plastic cover.. The clear styrene cover uses a rubber shelf liner to create the seal. The ESC is a Viper which is a waterproof design.
Any thoughts on how to improve the radio range?
linerfanatic is offline Find More Posts by linerfanatic
Old Aug 12, 2010, 10:26 AM
Kcal is offline
Find More Posts by Kcal
Joined Jul 2008
Liner,
Nice build you have an awesome model there, as far as your range question I would suggest talking to the sub guys as I am sure they have come across this before.
Kcal is offline Find More Posts by Kcal
Old Aug 12, 2010, 11:46 AM
rcshirt is offline
Find More Posts by rcshirt
miniture aircraft pilot
rcshirt's Avatar
United States, FL, Tampa
Joined Oct 2007
from all i heard about this sub , i was always hesitant to pull the trigger, till i saw your post, so i will have that to assemble soon also.
rcshirt is offline Find More Posts by rcshirt
Old Nov 14, 2010, 08:49 AM
ravemaster99 is offline
Find More Posts by ravemaster99
ravemaster99's Avatar
Chicago
Joined Jul 2010
I'm hoping to build one soon. Is yours setup to be static or dynamic diving?
ravemaster99 is offline Find More Posts by ravemaster99
Old Nov 14, 2010, 05:34 PM
Fort Wayne IN
Joined Aug 2007
Dynamic. For me, the hull was simply too small to accommodate the equipment needed for static diving. Though the running season is now over in the Midwest, I have logged four successful voyages now. I solved the radio range problem with fresh transmitter batteries. I cannot emphasize enough how the proper choice of glue made the difference between a struggle and a success. Good luck!
Yippee! My maiden voyage bsingin64 Beginner Training Area (Fuel) 9 Nov 03, 2009 05:15 PM
Video Calypso's maiden voyage 15 september 2009 dan.lord Dock Talk 4 Sep 20, 2009 08:24 AM
Help! F4 Maiden Voyage Motor Blew up f355 Banana Hobby 16 Sep 17, 2009 01:35 AM
Video YAPT Yet Another PT 109 Maiden Voyage daemuon Dock Talk 5 Sep 16, 2009 03:34 PM
Discussion Disney Nautilus has her Maiden Voyage! Nemo Submarines 16 Sep 11, 2009 11:45 AM
