Old Aug 07, 2010, 01:46 PM
dkfuji is offline
Find More Posts by dkfuji
RC Helis: My Healthy Obsession
The OC, California
Joined Feb 2007
Walkera V120D02 - Pics & Flight Review **REVISED**
I have decided to revise my initial review since there have been improvments made to this heli and some people might get the wrong idea by just reading the first page of this thread. The latest version of this heli is really good. Walkera has fixed the throttle problems and the self stabilization issues apparent in the first version I got to test. The little mix arms are still a problem. But there are now upgrades/mods available to eliminate those arms altogether which is the best solution I have found.
Paired with the new 915 motor on 14t, this heli is a rocket. Fully 3D capable and a blast to fly. Here is a vid of my V120D02 being flown by Manny to show what she can do.
Walkera V120D02 with Turbo Ace 915 motor from www.WowHobbies.com (2 min 50 sec)
dkfuji is offline Find More Posts by dkfuji
Old Aug 07, 2010, 02:02 PM
robZulu is offline
Find More Posts by robZulu
inventor of flames decals.
robZulu's Avatar
Hamburg, Germany
Joined Dec 2008
thanks for the review Darryl.
Little mechanical issues, ok.... but the RX thing doesnt sound good. Also the phasing issues is not really cool...
Did you try to change the gyro pot settings on the RX?
robZulu is offline Find More Posts by robZulu
Old Aug 07, 2010, 02:30 PM
KABAL99 is offline
Find More Posts by KABAL99
FRANCE
Joined Dec 2004
hummm
it's a pity
we will see what others think about that
thx DK
KABAL99 is offline Find More Posts by KABAL99
Old Aug 07, 2010, 04:57 PM
johnIn2SonAZ is offline
Find More Posts by johnIn2SonAZ
Tucson,AZ
Joined Dec 2007
Yeah Walkera Went for the Beginner with this one.
But all is not lost.
-JohnW
johnIn2SonAZ is offline Find More Posts by johnIn2SonAZ
Site Sponsor
Old Aug 07, 2010, 04:59 PM
jgupton is offline
Find More Posts by jgupton
Addicted - seeking help!
Huntington Beach, CA USA
Joined Feb 2009
So I've been holding off on upgrading my g6 to a g6s in hopes that this new receiver would be better (at least with 2801 mode). If I'm following correctly Darryl, it sounds like the programming in it is a step backwards.
jgupton is offline Find More Posts by jgupton
Old Aug 07, 2010, 05:51 PM
jasonjetski is offline
Find More Posts by jasonjetski
Micro-Heli-Concepts
jasonjetski's Avatar
Australia, NSW, Blacktown
Joined Dec 2006
Bummer,Ihave one on its way.
jasonjetski is offline Find More Posts by jasonjetski
Old Aug 07, 2010, 06:08 PM
dkfuji is offline
The OC, California
Joined Feb 2007
Originally Posted by robZulu View Post
thanks for the revies Darryl.
Hey Rob. Nice work on the canopies BTW. Anyway, I have already tried every combination of gyro pots and delay all the way from + to - and still there are issues. The more delay you add, the more it moves after your stick input. Whoa. The less Ail, Pit and Ele gain you put in the harder it becomes to fly. Also it picks up a bigger TB effect than it already has. I tried all combos of each and I have it just about as good as its going to get it appears. And still, there is a mild TBE outdoors (there is none indoors nor when the HS is @ 4000rpm or less) and a feeling of "flying on the edge of crashing" with right banked turns. I just don't know about this one. I may try using shorter links on the grips to get the swash and mains more in sync and that might solve the right turn issue. But I think that might add to the TBE.
After looking at the correction action of the Rx, I noticed that the throw of the swash is significantly greater than the 2610S Rx. It may be that the firmware has turned up the stabilization so much that no it cannot get out of its own way.
Oh well, the work continues to find a solution for some of this stuff.
Old Aug 07, 2010, 06:29 PM
robZulu is offline
robZulu's Avatar
Hamburg, Germany
Joined Dec 2008
shorter links on the bladegrips is what I thought too. change the geometry and get along with smaller servo throws for the same pitch, might also take care of the swash binding. The mechanical stuff is nothing that cant be fixed...
I really like the design of the new head, looks like its very strong compared to the flybared one - almost no more bend heads I guess.
but the rx and its firmware is crucial... walkera never showed the actuall rolling/fliping in the promo vids for the V120D02 from what I saw... I though this was odd...
Old Aug 07, 2010, 07:20 PM
NaterPin is offline
Find More Posts by NaterPin
Joined Dec 2009
So if the is a beginners CP. How would it compare to the, 4g6, 4g6s, or the dk 4G6s fbl, 4f200 or Blade SR for being stable and easy to fly. 3D is not for me at this time I want a indoor CP trainer for the Canadian winters.
NaterPin is offline Find More Posts by NaterPin
Old Aug 07, 2010, 07:27 PM
helicraze is offline
Find More Posts by helicraze
Joined Mar 2010
That sucks, this was meant to be the one, why do they keep doing this sorta stuff? Walkera all you need to do is change a few things and you would have an even bigger market.
helicraze is offline Find More Posts by helicraze
Old Aug 07, 2010, 07:53 PM
Ampdraw is offline
Find More Posts by Ampdraw
Australia...we live inverted.
Joined May 2008
My you have been busy Darryl,
That's alot of testing! Sweet job even if the results were not what we were hoping.
How much larger are the new tail blades? They are reportedly larger than the 4G6, 4g6s etc.
Any chance of a comparison pic?
I had to reduce the pitch of my 2s just a fraction as full limit on the gyro (2100T) with suitable ball distance (3mm) hold better this way. Motor can sustain more pitch without bogging but the tail currently has maybe 10% margin. Thinking laregr tail blades may help.
The geometry on the 4g6 tail is not that flash. Decent, but not all it could be.
Amp
Ampdraw is offline Find More Posts by Ampdraw
Old Aug 07, 2010, 08:02 PM
Z06 Tony is online now
Find More Posts by Z06 Tony
Z06 Tony's Avatar
United States, NY, Rochester
Joined Sep 2008
How about using the 4G6S RX? I bet the 2610s would fix everything.
Z06 Tony is online now Find More Posts by Z06 Tony
Site Sponsor
Old Aug 07, 2010, 08:17 PM
TravisBean is offline
Find More Posts by TravisBean
Have Guitar Will Travel
TravisBean's Avatar
The Digital Domain
Joined Nov 2008
Please excuse the dumb-a@@ newbie question, but does this reflect badly on the V120D01 also??
TravisBean is offline Find More Posts by TravisBean
Old Aug 07, 2010, 09:47 PM
Dan203 is offline
Find More Posts by Dan203
Dan203's Avatar
Joined Mar 2007
I only have my personal experience, and the posts of others on this forum, to reference, but the V120D01 is a great heli. I have 6 Walkera helis and it is by far my favorite to fly. So I wouldn't take the bad review of the V120D02 as any reflection on the V120D01.
Dan
Dan203 is offline Find More Posts by Dan203
Old Aug 07, 2010, 09:52 PM
ado1974 is offline
Find More Posts by ado1974
ado1974's Avatar
melbourne, australia
Joined Jun 2009
thanks for the review dk
but it sounds like they dropped the ball again
will be interesting to see what mods are possible with the new parts?
and possibly combining them with existing setups
cheers
a
ado1974 is offline Find More Posts by ado1974
Mini-Review Walkera V200D01 - Mini Review JHawk19 Micro Helis 2340 Apr 06, 2016 11:45 AM
New Product Walkera Lama 3 - Flight Video & Review dkfuji Coaxial Helicopters 1811 Jan 15, 2012 08:56 AM
Discussion Walkera V120D02 WowHobbies.com review wowhobbies Micro Helis 107 Jan 24, 2011 02:50 PM
Discussion Walkera V100D01 NOW SHIPPING at www.WowHobbies.com wowhobbies Micro Helis 91 Sep 13, 2010 02:32 AM
Discussion DIY V7 Ultimate 140 Blade for Walkera 4G6(S), V120D02, and 4G3, released! Timewerx Micro Helis 23 Sep 07, 2010 10:43 PM
