Old Jun 26, 2003, 10:35 AM
bluespier is offline
Find More Posts by bluespier
Joined Jun 2003
How to get the best finish on a foam model
I have built a TwinStar (which is currently about 25 foot high stuck in a tree!!!) and now am thinking of building a Cargo. I would really like to get a nice smooth finish on these models. I was thinking of applying some paint (not sure which one??) mixed with some talcum powder (not sure what ratio??) - sand and repeat as often as is necessary to get a smooth finish. Then I want to paint the models gloss white with some gloss red markings (again not sure what paint to use here??). Has anybody got a magical recipe for this? If possible I would like the exact makes of the paints to use and where I can get it - I live in the UK.
Thanks a lot.
Let me now go and retrieve my broken TwinStar!!
bluespier is offline Find More Posts by bluespier
Old Jun 26, 2003, 10:52 AM
erashby is offline
Find More Posts by erashby
Flying Free
erashby's Avatar
Utah
Joined Aug 2001
For non-EPP foams, I have used lightweight spackling. It works great! It is a bit brittle, so I mix it 1:1 with foam beads. It fills in all the gaps and allows yu to sand to a smooth surface. Then a spray a couple of light coats of minwax polycrylic and fine sand again. Then you can put any paint on it without melting the foam. I usually use Krylon. I have used this on SkyScooter, Mini Sped wing, and Twinjet. I haven't tried it on EPP because I usually tape them for added strength. Also, EPP flexes so much that I think that it would just "pop" the filler out of the little defects.
What airframe are you doing this on?
erashby is offline Find More Posts by erashby
Old Jun 26, 2003, 11:00 AM
Joined Jun 2003
I am wanting to do it on my doomed TwinStar and a Multiplex Cargo. Do you know of a website where I can buy the products you refer to?
Old Jun 26, 2003, 05:15 PM
ryan d. is offline
Find More Posts by ryan d.
dallas,tx
Joined Feb 2002
any local home improvement store carries these products, just find where the wood stains are located, and the water based poly is located right there with them,
Then walk over to the wall spackle section, and look for the one that say light weight spackle, it's really cheap and pretty much the same as you buy at the hobby shop.
hope this helps
ryan d.
ryan d. is offline Find More Posts by ryan d.
Old Jun 26, 2003, 05:22 PM
ryan d. is offline
dallas,tx
Joined Feb 2002
http://www.lowes.com/lkn?action=prod...00000024-63333
You can get smaller quantities of this stuff, this price is for a gallon
http://www.acehardware.com/product/i...2&pageBucket=0
ryan d.
Old Jun 26, 2003, 08:36 PM
Ray Lowinski is offline
Find More Posts by Ray Lowinski
Ray Lowinski's Avatar
Napoleon, Ohio
Joined Dec 1996
erashby, is the Krylon you're using the new "plastic friendly" type or the original?
Ray Lowinski is offline Find More Posts by Ray Lowinski
Old Jun 26, 2003, 09:08 PM
erashby is offline
Flying Free
erashby's Avatar
Utah
Joined Aug 2001
I don't know of any foam friendly Krylon. Once I have an even coat of Minwax polycrylic the paint doesn;t attack the foam. I think that this would be the same for all foams, but I would do a test on a foam scrap first. I did have a model that when sanding down the polycrylic I sanded through it in some places and then the paint did attack the foam.
Old Jun 26, 2003, 11:50 PM
EMFB is offline
Find More Posts by EMFB
Joined Apr 2003
Foam safe Krylon
This works ...
Krylon Short Cuts
I just tried it on some scrap fan-fold foam yesterday with no problems.
EMFB is offline Find More Posts by EMFB
Old Jun 27, 2003, 09:56 AM
tekochip is offline
Find More Posts by tekochip
tekochip's Avatar
West Dundee, IL, USA
Joined Jul 2001
I found paint to be hit or miss, so to speak. One paint was good on one type of foam, and ate the heck out of another. Sometimes polycrylic helped, sometimes it still ate the plane.
For me, the best all around solution was to cover the model in low temp (I used Oracover) covering, or even clear covering that was painted.
tekochip is offline Find More Posts by tekochip
Old Jul 14, 2003, 08:25 AM
joeygoose is offline
Find More Posts by joeygoose
joeygoose's Avatar
Westborough, MA
Joined Apr 2003
I've safely used Minwax Polycrylic on both EPP and pink foam, it seems to protect the foam from just about every paint I've tried. On my last project, an JKA E-Plane, I even used Rustoleum (automotive primer) over a coat of poly to paint the canopy (with no issues).
I've also had some pretty good luck using the Polycrylic to laminate 10 gram carbon fiber veil directly to foam - after a few layers you have and extremely strong and light outer skin that may be lightly sanded to a reasonably smooth finish.
Just my two cents.
joeygoose is offline Find More Posts by joeygoose
Old Jul 14, 2003, 08:52 AM
Captain Ed is offline
Find More Posts by Captain Ed
Aging Busdriver
Captain Ed's Avatar
Florida Keys
Joined May 2003
I use Oracover also. A side benefit of covering is added stiffness and strength. The next time you whack a tree it might keep it from breaking into multiple pieces. Ed
Captain Ed is offline Find More Posts by Captain Ed
Old Jul 14, 2003, 01:06 PM
whichwazup? is offline
Find More Posts by whichwazup?
whichwazup?'s Avatar
Buckeyes Country
Joined Jun 2003
My $.02- I have used Krylon "Fusion" spray on EPP with fine results without any surface pre-treatment. The Krylon Tech guy didn't recommend it for EPP but it seemed like he wasn't too sure what EPP even was.
http://www.krylon.com/product/gp_pro....asp?sgID=GP07
whichwazup? is offline Find More Posts by whichwazup?
Old Jul 14, 2003, 04:11 PM
stitch13 is offline
Find More Posts by stitch13
What goes up, will CRASH!
Thompson Mb Canada
Joined May 2003
Finishing Foam
I don't know yet if this going to work, but I am going to try it and that is thinning light weight spackle with water and painting it on, that I know works. Then some light sanding. Then I am going to try mixing some poster paint pigments into both the spackle and into polycrylic and see what happens. I also have different dyes both liquid and powders that I use for finishing speakers. I am going to try mixing these with polycrylc. I have enough chunks of different types of foam that I should find out what it will work with and what it won't. If polycrylic will hold the pigments in solution it should work.
stitch13 is offline Find More Posts by stitch13
How to get a smooth finish on foam? Bonez Foamies (Kits) 3 Mar 28, 2005 03:23 PM
How to get consistent power on the bench? ClayH Power Systems 5 May 18, 2003 09:51 PM
How to get from a 3 view to a flying model? Ado Slope 4 Feb 19, 2003 05:36 PM
Smooth Finish on Foam? kepople Electric Plane Talk 6 Jan 16, 2002 01:59 AM
Getting smooth finish on Foam? kepople Scale Kit/Scratch Built 3 Jan 13, 2002 03:33 AM
