Old Aug 24, 2010, 01:31 PM
emo23 is offline
Find More Posts by emo23
emo23's Avatar
Bodrum-TURKEY
Joined Feb 2008
Hello All
I have been flying with Easy Fly RTF Glider EPO - http://hobbyking.com/hobbyking/store...idProduct=7895
Easy Fly RTF Glider - HobbyCity.com (7 min 28 sec)
I was satisfied with it. Unfortunately It is broken last week and not easy to glue it together.
Now I m planning to do FPV. I was planning to buy Easy Fly again since noticed this topic.
For the FPV flying which one would you reccomend ?
Spec.
Length: 1210mm
WingSpan: 1960mm
Wing Area: 38.40dm2
Flying Weight: 960g
Wing Load : 25g/dm2
Power system : Brushless outrunner motor
Flying Speed : 12m/
or
Minimoa 2mtr R/C Glider EPO
http://hobbyking.com/hobbyking/store...dProduct=12885
Spec.
Wing span: 2000mm/78.7in
Length: 980mm/38.6in
Weight: 720g/25.4 oz
Motor: 1200kv brushless outrunner
ESC: 20A
Battery: 11.1V 2200mAh 3S Lipo
Servo: 9gx4
emo23 is offline Find More Posts by emo23
Old Aug 24, 2010, 03:01 PM
DougKierc is offline
Find More Posts by DougKierc
Joined Jan 2004
Anyone throw a watt meter on this power system with the stock prop yet? I pulled my motor out and it is reads "C2830-21-A Prop 8" 11.1v" My plane came with a 11" prop, pitch unknown. Seems to me the motor shouldn't last long running on three cells on the stock setup. Plane does look good though. Maybe later this week I'll fire it up and check what this motor is pulling.
DougKierc is offline Find More Posts by DougKierc
Old Aug 24, 2010, 07:18 PM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
Motor specs' http://www.art-tech.cn/english/Artic...?ArticleID=125
olmod is offline Find More Posts by olmod
Old Aug 24, 2010, 07:27 PM
ChuckTseeker is offline
Find More Posts by ChuckTseeker
ChuckTseeker's Avatar
Adelaide Plains Australia
Joined Dec 2007
Originally Posted by olmod View Post
hmm that link bought up a virus/worm warning on my puters Avast Scanner?? it was only the photo, as when i clicked "Abort" only the photo didn't load, info was still there??
cheers chuck
ChuckTseeker is offline Find More Posts by ChuckTseeker
Old Aug 24, 2010, 09:50 PM
old_dude is offline
Find More Posts by old_dude
Groundloop World Champion
old_dude's Avatar
USA, AZ, Glendale
Joined Jan 2002
cheers chuck
Ditto a Trojan Horse ............. no thanks ! Microsoft Security Essentials spotted and removed it.
old_dude is offline Find More Posts by old_dude
Old Aug 25, 2010, 07:39 AM
Galand is offline
Find More Posts by Galand
Galand's Avatar
Long Island, NY
Joined May 2010
Yep, indeed MSE spotted :
Trojan:Win32/Jpgiframe.A (?)
Galand is offline Find More Posts by Galand
Old Aug 25, 2010, 11:08 AM
hobie14 is offline
Find More Posts by hobie14
hobie14's Avatar
Western Europe 52.7 N 8.9 W
Joined Jul 2007
could you just post the specs here for us to read .....
hobie14 is offline Find More Posts by hobie14
Old Aug 25, 2010, 12:16 PM
Toppers is offline
Find More Posts by Toppers
Toppers's Avatar
Canada, ON, Oakville
Joined May 2008
I also got the virus scanner alert. Here are the details:
Motor model: C2830-21 (Old Product NO: 301302A)
Dimensions (mm) 3028 Maximum sustained current (A) 15
Shaft diameter (mm) 3 No load current (A) 1.5
Weight (g/oz) 48/1.7 Internal resistance (mΩ) 124
Output Power (W) 80 Thrust (oz) 14/16
No load KV (rpm/V) 1500 Suitable propeller 8060/1047
Batteries 2 cell Li-Po Use for model Coota
Toppers is offline Find More Posts by Toppers
Old Aug 25, 2010, 06:26 PM
Joined Jan 2004
Thanks Topper
HK advertises it as a 1200KV motor. Either way, a 11 inch prop is probably too much for a 3 cell Lipo
Old Aug 25, 2010, 08:09 PM
llcoolg is offline
Find More Posts by llcoolg
Joined May 2007
Minimoa Motor Mount Melted
Maidened the Minimoa today and she looked great in the air until I heard a grinding sound when I throttled up. The motor got so hot that it melted the plastic mount. This is with minimal throttle use. I was gliding and searching for thermals 90% of the time. It's too bad, the Minimoa is a great flying plane.
llcoolg is offline Find More Posts by llcoolg
Old Aug 25, 2010, 08:31 PM
olmod is offline
olmod's Avatar
Joined Apr 2004
Goes to show that this is the wrong size prop, for some time now it has been common knowledge that bell type motor were not the most efficient,
subject to overheating and high current draw = heat.
I have cut 3/4'' off the diameter but ill weather prevents me from a full test.
the vented spinner and exhaust holes will help mentioned in earlier posts.
now as the mounting legs are wrecked you could try to fit a cheap 900Kv 400 size motor with some downthrust .
Old Aug 25, 2010, 08:37 PM
Capt.RJM is offline
Find More Posts by Capt.RJM
Ohio
Joined May 2009
Minimoa 10 days to the door
Got home tonight and the box was sitting on the porch. The box was in bad shape, mashed on the ends and pressed in on the sides. Not what I really wanted to see.
But the plane was in great shape with no damage. All the parts were wraped in bubble wrap and the spaces were filled with air plastic bags.
Going to keep the unit stock with the mods mentioned in the earlier post. Drill out some vent holes for the motor and prop. Will also check all the grubs screws and add lock-tight for all the bolts.
All in all very happy with the purchase, the classic lines and gull shape wings sure look sharp.
Thanks for all the info....
Capt RJM
Capt.RJM is offline Find More Posts by Capt.RJM
Old Aug 25, 2010, 09:12 PM
MAX FISCHER is offline
Find More Posts by MAX FISCHER
Sic transit gloria
Rushmore Academy
Joined Sep 2008
OK to achieve the recomended CG 54mm, I need to add roughly 160g?! What do I have the lightest batteries in the world? My 2200mah is roughly 170g.
So what is small and heavy that you can pick up at a hardware store?
MAX FISCHER is offline Find More Posts by MAX FISCHER
Old Aug 25, 2010, 09:15 PM
Joined Dec 2007
fishing sinkers!
cheers chuck
Old Aug 25, 2010, 09:49 PM
Galand is offline
Galand's Avatar
Long Island, NY
Joined May 2010
"So what is small and heavy that you can pick up at a hardware store?"
On a Badius I used heavy guage soldering wire. Easy to shape and mold, even melt.
@ Olmod,
Thanks for the tip on removing the spinner
Discussion A330 70mm fans 2metre span Glong-flyer Electric Ducted Fan Jet Talk 4 Dec 20, 2010 10:43 PM
Discussion Hobbyking PnP 33 in wingspan F4U Corsair Lilbanks96 Electric Warbirds 10 Dec 12, 2010 01:10 PM
New Product 3.9m WINGSPAN COMPOSITE UAV AIRPLANE READY FOR SALE FPVistanbul UAV - Unmanned Aerial Vehicles 20 Dec 04, 2010 08:58 PM
Wanted 2metre sailplane with everything KeithP Aircraft - Sailplanes (FS/W) 11 Mar 01, 2008 04:58 PM
Discussion Cyclone Elite 10 2metre Electric Glider Pants Electric Sailplanes 4 Feb 27, 2006 07:45 AM
