Do not ask me how I know? ![]() ![]() ![]() Sorry also.I recall doing similar (motor starting and fighting to pull LiPo out) with the old cheaper TX's but whether it has been luck or the Futaba 9C is better, even when the throttle stick is the wrong way around, the prop has not started when not expected lately. But the question is where did you find nylon longer bolts or are they metal and where did you get them, if nylon. I got longer 4mm metal bolts but the idea of nylon is they are suppose to pull out in a hard landing (crash) and do less damage compared to the metal ones. |
Kev
Roll ? ugly Ill bet
Latest blog entry: For motor builders
I always have a worry the nylon ones will pull out when putting pressure on the wings when flying seeing there is only two of them. That is another reason to use metal. I found the 4mm metal hex headed bolts just hanging on the rack at the local hobby shop. |
Yea- I'm one of THOSE guys for which the safety feature of most good radios was invented. That is, you have to have throttle off for at least one second before it will work at all.
Just makes sense I guess. Otherwise it's kinda like having a gun that will automatically fire when you put a bullet in it unless you put the trigger back in neutral. As for bolts, yes, go with brass, they are available at most good hardware stores. I used steel tee nuts, hopefully they won't sheild too much signal from the Tx. We'll see. Now I just gotta find a decent motor. |
I was lucky enought to get the Futaba TX with the 2.4ghz Futaba and Spektrum modules. The only reason I got these is the receivers are very cheap now. The $29 Futaba 2.4ghz receivers are brilliant and I just tried an $8 plus postage Spectrum receiver. It seemed all right from the one flight so far on a small foam plane. I have read what everyone has done on motor replacements but have put it off as long as I could. Let us know if you come up with something good and easy to put in. |
"I have read what everyone has done on motor replacements but have put it off as long as I could. Let us know if you come up with something good and easy to put in. "
Replacing the motor is no big deal you need to drill three new holes ![]() olmod well its not an aerobatic glider like a Salto , but it is not bad ![]() Ian |
El Cheapo Tx/Rx kit
I fly with an "el cheapo" from Flysky ($23.00 for 6Ch Tx and $9.00 for 6Ch Rx). If you connect the battery with the throttle stick up all it does is beep at you to tell you that you are an idiot. As an additional safety you can also set switch A as "throttle cut". Not bad for a $30.00 kit. Upon reflection I wonder if it is not the $14.00 30A ESC that has all the brains rather than the Tx. |
| Thread Tools | |
| Discussion A330 70mm fans 2metre span | Glong-flyer | Electric Ducted Fan Jet Talk | 4 | Dec 20, 2010 10:43 PM |
| Discussion Hobbyking PnP 33 in wingspan F4U Corsair | Lilbanks96 | Electric Warbirds | 10 | Dec 12, 2010 01:10 PM |
| New Product 3.9m WINGSPAN COMPOSITE UAV AIRPLANE READY FOR SALE | FPVistanbul | UAV - Unmanned Aerial Vehicles | 20 | Dec 04, 2010 08:58 PM |
| Wanted 2metre sailplane with everything | KeithP | Aircraft - Sailplanes (FS/W) | 11 | Mar 01, 2008 04:58 PM |
| Discussion Cyclone Elite 10 2metre Electric Glider | Pants | Electric Sailplanes | 4 | Feb 27, 2006 07:45 AM |
