Old Oct 26, 2010, 12:00 AM
Berkie is online now
Find More Posts by Berkie
Great Southern Land
Berkie's Avatar
Australia
Joined Feb 2007
Originally Posted by olmod View Post
Mine is now ballanced on the rear edge of the red stripe on the bottom of the wing back from the leading edge and flying stable in winds 10~15 mph a big improvement over the origonal position quoted in the art-tech manual.
Gadzooks! That's only 35mm in from leading edge instead of the 54mm
How can there be such a difference?
Kev
Berkie is online now Find More Posts by Berkie
Old Oct 26, 2010, 12:11 AM
Great Southern Land
Berkie's Avatar
Australia
Joined Feb 2007
Olmod,
OK, I've read a little further and can see you have had to come forward to allow for your heavier motor mount, but what is it one has to do to find the new CG after this weight is added?
Kev
Old Oct 26, 2010, 01:10 AM
bleary is offline
Find More Posts by bleary
Cookie Monster
Australia, QLD, Diddillibah
Joined Aug 2005
Kev
Wondering this myself.Do you have a report Olmod?
bleary is offline Find More Posts by bleary
Old Oct 26, 2010, 01:32 AM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
Its got nothing to do with the new engine mount its more to do with the wing area X moment arm x tailplane area and the longtitudal dihedral ,
but I have added about 4 layers of thin sheet lead about the same size as the 2200 lipo to get the cg at 31mm from the leading edge and it flies much better, try it and I'm sure you will agree that when you hit some wind (thermal) it climbs instead of stalling (porposing) and is a much happier ol girl.
cheers Lez.
olmod is offline Find More Posts by olmod
Old Oct 26, 2010, 01:42 AM
christianka6cr is offline
Find More Posts by christianka6cr
christianka6cr's Avatar
Germany (Black Forest, Alps, Vosges)
Joined Dec 2009
Hello,
I canīt believe it. Now, more than 2 months after receiving the dead Moa, there is an answer of the HK-service! "Once we get the replacement parts of the Minimoa, we will send it to you as soon as possible." pah, "once we get..." which year? I hope, iīm not dead than...
Good service? Not from the HK!
Greets Christian
christianka6cr is offline Find More Posts by christianka6cr
Old Oct 26, 2010, 01:43 AM
Great Southern Land
Berkie's Avatar
Australia
Joined Feb 2007
So, if I may ask, what is the weight of the lead and where didja stuff it
Kev
Old Oct 26, 2010, 04:00 AM
Great Southern Land
Berkie's Avatar
Australia
Joined Feb 2007
Originally Posted by christianka6cr View Post
Hello,
Greets Christian
I agree. Very poor.
Kev
Old Oct 26, 2010, 05:35 AM
olmod is offline
olmod's Avatar
Joined Apr 2004
Kev
approx 4 to 6 oz under the lipo pack glued with vise to the floor up front
next time I unpack the vehicle I will weigh the lot for you . not that it means much to the way she flies does some nice gracefull stuff including loops ,I have started to throw it around a bit and building up the speed but I know one day I will get the dreaded flutter if I get too cocky .
Old Oct 26, 2010, 07:13 AM
hobie14 is offline
Find More Posts by hobie14
hobie14's Avatar
Western Europe 52.7° N 8.9° W
Joined Jul 2007
In your fingers or your legs .....
hobie14 is offline Find More Posts by hobie14
Old Oct 26, 2010, 07:37 AM
olmod is offline
olmod's Avatar
Joined Apr 2004
I only get that when my blood sugar is low a few jelly beans and all is ok.
Old Oct 26, 2010, 07:38 AM
hobie14 is offline
hobie14's Avatar
Joined Jul 2007
Well finally I got to test my new prop setup on Sunday ......
Tgy 2409-18 1200kv ....... 9 x 5 Graupner Cam folding prop (fits the Minimoa spinner) .....
15A and 165 watts
rem I also tried the 8 x 4.5 version of the Graupner ..... 13A and 150 watts ..... I could live with it if I had to although penetration into the wind not so good ....
the power levels are perfect for the motor spec. and after two 30 minute flights I think it really is the ideal setup (no wind so some power on all the time) ...... no signs of any excess heat (rem I do have some cooling vents) ..... it still climbs like $$$ at WOT but a little elevator control looks after that ..... good penetration into the wind .......
The motor spec. seems identical to the Stock Minimoa Motor so it seems to me that a 9 x 5 prop would go a long way to resolving the stock over-heating problems (I would still do the cooling vent mods though) ......
No video this time but I did take a photo of the slope .....
it can be tough flying off the slopes .....
but not always ......
Old Oct 26, 2010, 02:43 PM
NL_Expatriate is online now
Find More Posts by NL_Expatriate
Joined Oct 2009
For cooling I've cut out the bottom of the landing wheel compartment to allow for flow through.
I also cut away a bit away from the front of the skid plate to open up the engine compartment from the bottom. Seemed a natural mod.
I also melted a hole from the batt compartment up into the false cockpit with a couple of small holes drilled in the back of the plastic cockpit to allow for batt/ESc/eng compartment flow through.
New motor as well as a flow through allum spinner to add weight and cooling through motor.
http://www.hobbyking.com/hobbyking/s...idproduct=6357
Not sure if this motor will work but it does draw 13 amps static with original prop 11x5 I'm guessing? It's what I had laying around and I wasn't expecting to burn out a motor in only 2 test flights.
http://www.hobbyking.com/hobbyking/s...idProduct=6664
NL_Expatriate is online now Find More Posts by NL_Expatriate
Old Oct 27, 2010, 12:53 AM
Great Southern Land
Berkie's Avatar
Australia
Joined Feb 2007
Thanks mate.
So you add weight as you say then you support both wings on your finger tips starting at the LE, then keep moving your fingers back until she balances. This is then the new COG. Right?
Kev
Old Oct 27, 2010, 12:57 AM
Great Southern Land
Berkie's Avatar
Australia
Joined Feb 2007
15A and 165 watts
Heyyyyyyyyy! Looks like Scotland!
Just beautiful. Where is that?
Kev
Old Oct 27, 2010, 01:03 AM
Great Southern Land
Berkie's Avatar
Australia
Joined Feb 2007
Yeah, the 2409-12 is what others here including myself have been ordering, but I haven't received mine yet.
Most though seem to be getting the 2409-18 which comes with a mount, but I don't know if the mount is usable.
Kev
Discussion A330 70mm fans 2metre span Glong-flyer Electric Ducted Fan Jet Talk 4 Dec 20, 2010 11:43 PM
Discussion Hobbyking PnP 33 in wingspan F4U Corsair Lilbanks96 Electric Warbirds 10 Dec 12, 2010 02:10 PM
New Product 3.9m WINGSPAN COMPOSITE UAV AIRPLANE READY FOR SALE FPVistanbul UAV - Unmanned Aerial Vehicles 20 Dec 04, 2010 09:58 PM
Wanted 2metre sailplane with everything KeithP Aircraft - Sailplanes (FS/W) 11 Mar 01, 2008 05:58 PM
Discussion Cyclone Elite 10 2metre Electric Glider Pants Electric Sailplanes 4 Feb 27, 2006 08:45 AM
