I have not used it or the CC ubecs as yet. I have a good balsa Yak54 my daughter bought me and have flown it just with a Turnigy 60amp Plush ESC (3amp BEC) but I think it might be all right (hopefully) with the 5 servos. Guess I should put this CC UBEC in with the 60amp ESC. |
Do not buy this one as they are rubbish: http://www.hobbyking.com/hobbyking/s...for_Lipo_.html Here is more info on BECs unless it is what you included in your links: http://www.rcgroups.com/forums/showthread.php?t=1277428 |
yorkshire UK
Joined Oct 2007
the trouble with swtching ubecs is that they need some sort of over currnet protection built in other wise if too much current is drawn due to a s/c the swtching transistor simply destroys itself, this was the case when I was fixing tvs back in the days when switched mode supplies were a new invention and we all had to go on a 3 day course to find out how they worked and how to go about fixing them, where as a really good 5v reg with a supply resistor would generally survive or maybe just burn out the resistor.
Also the process of switching the transistor many many times per second and controlling the pulse width is a complicated one and as we all know the more complicated something is the more likely it is to go wrong, not what I want in the the main 5v supply to my rx. So I personally would prefer a high rated bec over a ubec any day. |
I'd be using the Castle Creations but they must have good current protection built in. I understand the blokes with the big expensive planes use them.
The built in BECs are only border line for some planes so that is why I'll use these. A decent 5amp one would do but I'll use the 10amp one as it is only small. I guess I am only just getting away with it in my balsa Yak54 with 5 servos and a Turnigy Plush 60amp ESC which has only a 3amp BEC. I dug this up elsewhere if it is of any interest: "A BEC (battery eliminator circuit) is typically built into the ESC (electronic speed control) and by modifying the voltage from your flight battery (typically 2s -7.4v or 3s 11.1v) delivers power for your Rx and servos at ~5v (but usually no more than 2A-3A). (PROBLEM) If you go to 4s (14.4v) or more, and have more than 3-4 servos, the usual linear BEC in the ESC cannot cope with reducing the high voltage down to the ~5v the Rx and servos need, nor can it deliver enough current to power many, especially digital, servos. Then you need a stand alone UBEC (Universal BEC) which is typically a switch mode unit which is capable of reducing the voltage from 4s+ packs to the required ~5v, and can deliver as much as 10A to power many, big, digital servos and your Rx. That ESC you link to is an Opto, so it has no built-in BEC... you will have to use a UBEC or carry an additional battery pack (4.8v-6v) as a power source for your Rx and servos. " Quote:
yorkshire UK
Joined Oct 2007
I f you are flying a big plane with more which can carry a bit more weight a separate rx battery is the way to go, either nimh, a 2 cell life type battery, a 2 cell a123 pack 1100mah weigh 40g per cell, 2300mah weigh 70 g per cell and you wont need any bec, or a 2 cell lipo with a 5v bec rated for the amps you need.
But getting back to this plane the supplied esc is only just enough for this plane and best replaced with a 30amp or more with a 3amp bec or more, or a quality ubec. Hobby king sell some life cell rx batteries that are quite small and light and might be ok as a separate supply bu tof course you must then charge up your rx battery too or your gonna crash when that runs out lol! |
Guess that would take all the worry out of it and I have a good Eneloop rechargeable pack. I think the Minimoa ESC is right for 99.99% of the time but you do not know when the .01% will come up and lock on a servo. So with .01% some people will never experience the problem but you never know. |
UBEC? You Bet!
Do you have the Hobby King 1280mm Yak 54? If so, I have the same plane. I love the way it looks and handles, but the landing gear is too weak. I have a 120mm carbon fiber gear replacement coming from HK. BTW, I have a separate UBEC in the Yak along with a 60 amp Emax ESC, plus an Orange 6ch RX and satellite RX antenna. My TX is a Spektrum DX8, which I really enjoy. I have had good luck with the Orange Rx's as long as I have used UBECs for high-load scenarios (i.e. many servos), especially with 4S batteries. The HK Yak is powered by a G25 brushless 870 kv outrunner and really tears up the sky. I replaced the ESC in the Minimoa with a 32 amp PowerUp ESC. This ESC just gets warm with steady use of my 165 watt motor/prop combo. The built-in 2 amp BEC seems to to handle the load of 4 servos without problem on a 3S 2200 mAh battery. Cheers, Jackson
Saw your Blog
Hi Firepower,
I checked your blog and realize your Yak is not the same as mine, although very similar. You can see mine in the photo under my name on the left. It is also at http://www.hobbyking.com/hobbyking/s...80mm_ARF_.html I see you have a very impressive collection of planes, gliders and flying wings. Lots of "firepower" in the event of aerial attack by rogue RC drones. Haha! Best regards, Jackson |
The design of the steerable tail wheel, bolts to hold it together etc etc were a hold up. My mate got a Katana at the same time and everything was made much better. Hope yours was good. I was lucky and started with blokes with Futabas and ended up with a second hand Futaba 9C. You probably saw this I put up recently which mainly means make sure you do things right with the receiver voltage.. http://www.rcmodelreviews.com/dsm2flaw.shtml http://www.rcmodelreviews.com/spreadspectrum01.shtml Now I know this is for DX6i is DSM2 but yours is a DX8 so is that a DSM2. I guess if it is you have to keep your RX/BEC voltage up. You say your new ESC in the Minimoa is 32amp with a 2amp BEC. It is good you increased it to 32amps but I think the problem is the 2amp BEC. The old standard ESC had a 2amp BEC and that was the problem so have you really improved your ESC with that one. I am trying to concentrate on FPV and have recently had some good flights after working at it for over two years. The recent gear is much better than two years ago. I have the FY21 and Eagle Tree stuff that brings the plane back when you get lost but it all takes time to get that going. But after buying this stuff and two FY20s which I have got going perfectly, really found out they are not necessary to start FPV flying. I thought I need the FY20s with gyros to help me keep it in the air but have flown FPV recently without them with no problems. So my Minimoa is on the back burner at the moment. Good one on the Firepower comment. I guess no one can see what the avatar photo is. It is a photo of the back glass of my Firepower 2 pinball machine. It is nice artwork of delta winged jets but you can not really see them. Col |
I just received a new Minimoa from HobbyKing. I had read about halfway through this thread when I ordered it with a couple of 2S, 3300mAh LiPos to address heat/power issues with the originally supplied 11x7 props. Now come to find later in the thread that the Minimoa is now shipping with 9x5 props, though mine actually measure about 9.75" (4.125" blades and 1.5" between the spinner pivots). So... do I go back to 3S batteries or order the original 11x7 blades (or maybe swap with someone here who has virgin 11x7s they're not using)? Like Mr. Stone, I will be flying at 6000+ feet here in Colorado, and I know the power will be marginal, but I'm still inclined to go with my original plan of running 2S with the larger prop. What say you all, and where can I most easily get the 11x7 blades if that's the verdict? Thanks, Dave P.S. I'm a noob flyer, and will not be flying the Minimoa for some time yet. I'm still practicing with the HZ Champ (54 flights with no crashes - knock on wood ), and then will probably be getting some instruction on the Airfield Skytrainer 182 I'm building now. I just couldn't resist the Minimoa's good looks, and had to get one. ![]() P.P.S. The Skytrainer runs on 3S, 2200mAh LiPos, so I could potentially use those in the MiniMoa with the smaller prop and some venting/exhausting. In any case, I'd like to make the stock motor/ESC work as reliably and effectively as possible for the time being with minimal mods. |
G'day Firepower
First of all I recognize you in your article/website from the YouTube videos that you posted on how to build a Floater Jet. I watched the videos carefully before building one around Christmas time and found them incredibly useful. I built the Floater Jet for a friend of mine. Thanks for that good piece of work; I popped $25 into your paypal as my token of appreciation. Second, I hear that you think my 2 amp ESC is a problem waiting to happen. I happen to have a 3 amp UBEC sitting on my desk. Do you think I should pop it in? Would be easy to do. Third, I do love the way the Yak flies. So fast, maneuverable and powerful. It really keeps me on my toes! Last, I am thinking of venturing into FPV this year myself and have a friend who is pretty bright with all that stuff who is acting as a pathfinder from me. One thing I did get out of your article is that I should avoid using a 2.4 ghz video tx because of its massive frequency footprint over my 2.4 ghz Spektrum Tx signal. Thanks for the indepth response, and appreciating my humor on the Firepower remark. Cheers, Jackson |
Nice to hear from a fellow Coloradoan! My first thought is just test your existing system with the 2S batteries and see how many watts you are drawing. My system draws 165 watts and provides ample power for flying the Minimoa at 6,400 feet. If yours draws less than 150 watts, it might be a good idea to step up to the larger blades. Unless someone responds to your request a good place to get blades is Headsuprc.com . Good luck with your flying. If you would like to get together and fly the Minimoas in formation let me know. Cheers, Jackson |
yorkshire UK
Joined Oct 2007
I have used the 3 cell 9*5 set up and found esc and motor to get so hot that I can not hold them after just 1 flight using 3:20 mins of full power in total and a flight of about 18 mins. Now I use 3 a123 cells which are closer to 2 cell lipo at around 8.4v under load and a 10*6 folder and esc and motor just get slightly warm but barely any warmer then b4 I flew, this set up is very close the nimh batts that this plane was designed for originally. |
As you will see right through the Minimoa forum the 2amp BEC in the old ESCs are not high enough. But sometimes a 3amp UBEC can be worse than what you have. Do you have a make and model of it? Everyone will tell you something different as everyone have their favourites but for the cheaper planes I use Turnigy Plush ESCs. But I just looked at the 30amp Turnigy Plush and it only has a 2amp BEC which is no good: http://www.hobbyking.com/hobbyking/s...ontroller.html So if weight is not a problem I would use this one: http://www.hobbyking.com/hobbyking/s...ontroller.html Like I said others have their favorites and maybe they can recommend a 30amp ESC with a 3amp BEC but I would put a 40amp Turnigy Plush in which I have. I did not know anything about the UBECs when I put it on and my UBEC is about just under 10% better than the Turnigy BEC. Before you buy any FPV stuff you could PM me and I can let you know exactly what to buy. I also understand your frequencies that you use over there are different to here. I have been lucky and have been frying with mates with all the good gear including UAV stuff. One day one of them threw his wing and it disappeared over a massive shopping complex and he put the TX on the ground. When it got the fixed distance it turned around and flew over 16 way points and then circled above. I have spent a lot of money on FPV over the years but if starting now it is very cheap. All the best. Col |
| Thread Tools | |
| Discussion A330 70mm fans 2metre span | Glong-flyer | Electric Ducted Fan Jet Talk | 4 | Dec 20, 2010 10:43 PM |
| Discussion Hobbyking PnP 33 in wingspan F4U Corsair | Lilbanks96 | Electric Warbirds | 10 | Dec 12, 2010 01:10 PM |
| New Product 3.9m WINGSPAN COMPOSITE UAV AIRPLANE READY FOR SALE | FPVistanbul | UAV - Unmanned Aerial Vehicles | 20 | Dec 04, 2010 08:58 PM |
| Wanted 2metre sailplane with everything | KeithP | Aircraft - Sailplanes (FS/W) | 11 | Mar 01, 2008 04:58 PM |
| Discussion Cyclone Elite 10 2metre Electric Glider | Pants | Electric Sailplanes | 4 | Feb 27, 2006 07:45 AM |
