Old Aug 06, 2010, 02:00 AM
joy4u is offline
Find More Posts by joy4u
joy4u's Avatar
India
Joined Feb 2006
How to compare brushless with the glow engine power..??
I am more into glow planes....
I want to convert some of my planes to the electric....
How do I compare a motor power with the engine I am using in that plane and match for conversion...??
Like I am using a OS .40 engine on my highwinger 40 size plane...What motor will I need to use to convert it to electric flight...???
More over I have some motors and how do I come to know what size plane can I make to power it with that motor...???
joy4u is offline Find More Posts by joy4u
Old Aug 06, 2010, 02:40 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Some manufacturers -- Eflite comes to mind -- describe their motors by equivalent glow engine size http://www.e-fliterc.com/PowerSystem...Brushless.aspx, which makes life easy.
With others, all you really need to know is that 746watts = 1 horsepower. Watts = volts x amps, so you can calculate a motor's power (if it's not given in the spec) by multiplying recommended voltage by recommended maximum amps. This works fine so long as you choose motors which also have a kv rating (rpm per volt) of about 1000 or less. If they have higher kv they're going to spin very small props very fast, or they're going to need a gearbox to get the speed down so they can use a prop that's roughly the size you would expect on the equivalent glow engine.
As a rule of thumb, you need between about 75 watts and 200 watts for every pound of model weight (incl. battery, ready to fly), depending on the model type and your flying style.
abenn is offline Find More Posts by abenn
Old Aug 06, 2010, 08:25 AM
Thrawn150 is offline
Find More Posts by Thrawn150
Thrawn150's Avatar
USA, IL, Oak Lawn
Joined Apr 2007
I go by watts per pound. I have converted a H9 p-47 and installed a power 90 on 7S getting 139 watts per pound. It flys great.
Thrawn150 is offline Find More Posts by Thrawn150
Old Aug 06, 2010, 03:08 PM
Ken Myers is offline
Find More Posts by Ken Myers
Ken Myers's Avatar
Commerce Township, MI
Joined Aug 2001
OP,
You might find the article "Comparing Glow Engine to Electric Power - Again"
in the August 2010 issue of the Ampeer helpful. Found here:
http://homepage.mac.com/kmyersefo/ampaug10/ampaug10.htm
Ken Myers is offline Find More Posts by Ken Myers
Old Aug 11, 2010, 12:13 AM
TTRotary is online now
Find More Posts by TTRotary
Rangers Lead the Way
Joined Mar 2010
E-Flite makes it easy and others will give you comparison. I would say though that a Power 60 is probably ultimately more powerful than a 60-size slimer because the outrunner motor has more torque and can spin a bigger or multiblade prop for scale. Basically, an electric motor will extract whatever amps it needs to achieve a certain speed - like a carb that automatically jets up. As an example, for the 1/7 Sea Fury, a Power 110 has no problem swinging a 5-blade 16x8 Zinger prop, and an 18x8 is also possible at somewhat lower speeds. You would probably need a 150 4-stroke minimum to achieve this and there is no way a 110 2S can do this.
My Power 15 Super Sportster flies with noticeably more authority than my flying buddy's .25 nitro equipped Sportster despite approx the same AUW.
TTRotary is online now Find More Posts by TTRotary
Discussion DIY onboard glow: how to slow the current with simple on/off switch? depronair Engines 13 Apr 08, 2015 09:33 PM
Discussion os 46AX compare with OS 55AX engine simonzns Fuel Plane Talk 3 May 31, 2010 06:14 PM
Discussion os 46AX compare with OS 55AX engine simonzns Engines 10 May 20, 2010 12:50 AM
Discussion How dows a 50cc radio control engine compare to a 50cc motorcycle engine? midrian Engines 4 Feb 08, 2008 03:49 PM
How to compare a standard motor with brushless RookieOne Electric Plane Talk 2 Apr 08, 2002 06:56 PM
