Old Aug 05, 2010, 01:41 PM
zach_dad is offline
Find More Posts by zach_dad
TEXAS
Joined Sep 2005
Any reason why a fan unit is not mounted all the way back?
If room and design allows why is the fan unit not mounted all they way back with using the fake ehxuast covers to cover and channel air. Or has any one tried using the MKII 400 pusher and the cone it has fo the exhaust tip? Trying to use some highber mAh battheris and out of room still tail heavy...
zach_dad is offline Find More Posts by zach_dad
Old Aug 05, 2010, 03:04 PM
ameimen is offline
Find More Posts by ameimen
Taos, NM
Joined Oct 2008
I don't think there's any reason why the fan jet motors are mounted midsection instead of way back in the tail other than the obvious balancing concerns. If you put it way back there, then you could end up with a very tail heavy condition, and most planes end up tail heavy anyway. So why put all that ballast in the nose if you can mount the motor midships and avoid all that? I think that's probably the main reason.
ameimen is offline Find More Posts by ameimen
Old Aug 05, 2010, 03:13 PM
unknown flyer is offline
Find More Posts by unknown flyer
unknown flyer's Avatar
Fairbanks Alaska
Joined May 2010
Most fans don't do well with really long intakes either which you would have if the fan was all the way back.
unknown flyer is offline Find More Posts by unknown flyer
Old Aug 05, 2010, 04:47 PM
jdlilfan is online now
Find More Posts by jdlilfan
jdlilfan's Avatar
United States, IN, Indianapolis
Joined Mar 2010
Also keep in mind the length of the wires and the gauge needed which adds weight and sometimes strain the planes electrical system. That is in regards to motor/fan placement.
jdlilfan is online now Find More Posts by jdlilfan
Old Aug 05, 2010, 05:25 PM
tomme21 is offline
Find More Posts by tomme21
tom
tomme21's Avatar
USA, LA, Natchitoches
Joined Apr 2004
http://www.rcgroups.com/forums/showthread.php?t=1184716
tomme21 is offline Find More Posts by tomme21
Old Aug 05, 2010, 05:42 PM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
Like jdlilfan said; you can loss what you gain by putting the battery so far away from the ESC. Max length on wires is 20cm either side. You can go more but your performance goes down or needs larger battery and ESC to push it. You can up the gauge which increases the weight also.
Not that it can't be done but talk to Claus. He's shown diagrams etc placing the EDF somewhere in the middle.
Maxthrottle is offline Find More Posts by Maxthrottle
Old Aug 05, 2010, 07:41 PM
bmiller is offline
Find More Posts by bmiller
SoCal, Year Round Flying!
bmiller's Avatar
Newport Beach, CA
Joined May 2002
CoG and wire lengths concerns aside, You can mount it where you like but an (optimal) exit length of 3-4 inches allows you to squeeze the exit smaller (typically 90%)and increase the efflux speed. Just like sticking your thumb over the end of a waterhose to increase its velocity.
bmiller is offline Find More Posts by bmiller
Old Aug 05, 2010, 08:20 PM
320pilot is offline
Find More Posts by 320pilot
320pilot's Avatar
Joined Mar 2009
Here is a picture of the tail cone of an F-35 being sold by Nitro planes. looks like the brushless motor/fan are at the very rear of the tailpipe.
http://www.nitroplanes.com/93a35-f35...o-rtf-24g.html
C of G must be tricky.
320pilot is offline Find More Posts by 320pilot
Old Aug 06, 2010, 01:10 PM
High Orbit.....
Joined Jun 2009
Has this understanding changed much? http://www.rcgroups.com/forums/showt...6#post10837456
He reps the Velocity fan so h may be able to help you with optimal.
Old Aug 06, 2010, 02:03 PM
zach_dad is offline
TEXAS
Joined Sep 2005
I was thinking furgther back to accomidate heavier batteries,
On the test stands if you use a cone to channel the exhuast 10 or 20% do you see a loss in thrust and a gain in velocity?
If this is a true statement then and I wanted plane that could do the alfa or cobra manuever I woild give up some speed but have a lot of tbhrust to achieve the beter than 1 to 1 ratio, plus if I got introuble I would. Have the extra thrust to save my azz easier. So I probably would do no chaneling?
Old Aug 06, 2010, 07:05 PM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
Naw man! 95mm from wing joint. I added a pound to mine and it flys well and really fast
ApexAero is offline Find More Posts by ApexAero
Old Aug 07, 2010, 02:19 AM
Turbs is offline
Find More Posts by Turbs
Foam bounces...
Turbs's Avatar
SA, Australia
Joined Aug 2007
The shorter the discharge side of the fan, the more turbulent the air leaving the plane.
Turbs is offline Find More Posts by Turbs
Discussion I love my blade MSR - any reason why I need CP? Wiskey Beginner Training Area (Heli-Electric) 34 Jul 30, 2010 02:04 AM
Discussion Thinking about getting an iCharger. Any reason not to? Bmr4life Batteries and Chargers 5 May 26, 2010 12:31 PM
Discussion cold weather is on the way, why not an indoor pylon racing event brn-grose Alabama's Rocket City Renegades 2 Oct 30, 2009 10:55 AM
Question Design ? Any reason why not many all-flying V-Tails? fnnwizard Sailplane Talk 8 Dec 27, 2008 07:22 PM
Warp 4 on a Trex? Any reason why I should not get it? tomi Mini Helis 11 Feb 04, 2005 12:26 PM
