Old Aug 05, 2010, 01:01 PM
Nathan Schmoekel is offline
Find More Posts by Nathan Schmoekel
ground penetration specialist
Nathan Schmoekel's Avatar
USA, MI, Grand Rapids
Joined Apr 2007
Aurora 9 slider center detent ?
Just got my radio, and am frustrated that the sliders don't line up mechanically and electronically. When I slide the sliders there is a physical detent, which does NOT line up with the electronic graph center of the function I'm setting up.....the beep that tells where the center is is alligned with the graphic/electronic center, but it's pretty hard to stop on a beep!
Is this a known issue? Perhaps on the fix-it list?
Nathan Schmoekel is offline Find More Posts by Nathan Schmoekel
Old Aug 05, 2010, 04:52 PM
BRENDAN LUGO is offline
Find More Posts by BRENDAN LUGO
Hitec service
BRENDAN LUGO's Avatar
San Diego
Joined Nov 2004
This is a calibration issue. It's been discussed in the past in the Aurora thread in the general section. To get the beep/detent/graph lined up correctly we would need to recalibrate the channels.
BRENDAN LUGO is offline Find More Posts by BRENDAN LUGO
Old Aug 05, 2010, 07:55 PM
Joined Apr 2007
When I had the radio open to re-locate the momentary switch I saw that there was a metal strap on the sliders....it looked kind of like the tension/ratchet adjustment on the throttle stick. However I did not pay it more attention.
Before I open up the radio again I will ask....is it be possible to reverse, flip or otherwise modify the metal strap to eliminate the detent without making the slider floppy? Given a choice, I think I would prefer a smooth movement to a "false" detent.
Thanks again......this Hi-Tec forum is AWESOME!!
Old Aug 10, 2010, 09:14 AM
Hitec service
San Diego
Joined Nov 2004
There is no adjustment but you may be able to slide a small piece of fuel tubing or heat shrink over the leg that contacts the detents in the slider to soften their feel. If you remove the clip or bend the leg then the slider will just flop around so some tension is needed on it.
Old Dec 04, 2012, 11:28 PM
amstel78 is offline
Find More Posts by amstel78
Joined Nov 2012
I realize that this thread is extremely old, however I've just noticed that my A9 also suffers from the miscalibrated slide switch detent issue. Can I calibrate the radio on my own or must it go back to Hitec? I tried searching for more information on this issue here but was not successful so apologies for the zombie thread.
amstel78 is offline Find More Posts by amstel78
Old Dec 05, 2012, 01:28 AM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Recalibration is within the service menu, entering which is not recommended as in RC GRoups Post #17527
and highlighted on my webpage where several service menu for old Tx are listed under sub section:
"Transmitter - FAQ - Additions, Adjustments, Mode Change, Clonepacs & Repairs." quote
"Service Menu - CAUTION: Unauthorised Entry and/or TX alterations Invalidate Warranty & Rights/Remedies under
Consumer Guarantees Act at least in NZ, irrespective of brand & may cause soft/firmware conflicts or "brick" your TX.."
Having highlighted above, at least one user has tried and published relative information online:
Calibrate Sliders - Post #17537 also with the very clear caution
"You know you can brick your radio with this.... "
If you must experiment, back up models first and try at your own risk, as could be an expensive exercise.
Recommend contact your service centre direct by email:
Hitec Warranty & Service - homepage.
Note: Hitec USA only services North/South America and Canada.
"Hitec USA customer service department is available Monday through Friday*
from 7am- 4:30 pm Pacific time. Reach us at 858.748.8440 or
service@hitecrcd.com any time you have a question"
If you are from a country that is outside North and South America, please contact the
Hitec distributor in your country for service.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old Dec 05, 2012, 10:55 AM
amstel78 is offline
Joined Nov 2012
Thank you for the links Alan. They were most helpful. I followed the instructions to recalibrate the sliders by entering the gimbals menu and all seems to be OK now.
Question Aurora 9- Heli- Swash mix function JoeR Hitec/Multiplex USA 5 Sep 24, 2010 03:12 PM
For Sale HItec Aurora 9 Radio System 3DTRYER Aircraft - General - Radio Equipment (FS/W) 0 Aug 02, 2010 09:45 AM
Question Aurora 9 programing mach1latus Radios 1 Aug 01, 2010 12:47 AM
Question Aurora 9 davew478 Hitec/Multiplex USA 12 Jul 30, 2010 07:49 PM
Question Dual Elevator setup Aurora 9 supersy Hitec/Multiplex USA 2 Jul 27, 2010 01:50 AM
