This thread is privately moderated by hoppy, who may elect to delete unwanted replies.
Old Jan 18, 2012, 10:54 AM
YellowJacketsRC is offline
Find More Posts by YellowJacketsRC
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
I am sorry if this question has been asked over and over, but I have done a search and can not find an answer.
How do I determine the amp rate at which I can discharge a particular lipo using my Icharger so as to put the lipo in storage?
For example: I have a Gens Ace 3300 Mah, 6s, 25C lipo. Obviously it can theoretically discharge in the air at 72.5 amps. I am correct on that right?
But what rate should I use to discharge it for storage?
YellowJacketsRC is offline Find More Posts by YellowJacketsRC
Old Jan 18, 2012, 11:25 AM
Turner2 is offline
Find More Posts by Turner2
Tallahassee, FL
Joined Sep 2009
The discharge rate you use will be limited by the charger, not the battery, unless you are using regenerative discharge. You don't say which icharger you have but if you look at the specs you will see the maximum discharge rate.
Turner2 is offline Find More Posts by Turner2
Old Jan 18, 2012, 12:13 PM
They Call him Dead!
Joined Jul 2003
Thanks for the reply. I understand that the charger has a limit to the discharge rate. But I want to make sure that I do not discharge too fast and damage the lipo. So I am trying to find a formula that tells me how fast (as in how many amps) I can discharge a particular lipo safely.
Now that you mention the specs, I own an Icharger 206B. Here are the pertinent specs:
Maximum discharge power capacity: 20W
Maximum regenerative discharge power capacity: 300W
Maximum extern discharge power capacity: 500W @ 25V/20A
What is "regenerative discharging" ?
What is meant by "extern dishcarge"?
Old Jan 18, 2012, 12:41 PM
Turner2 is offline
Tallahassee, FL
Joined Sep 2009
Discharging at the maximum internal rate of 20 watts will not harm your 6 cell pack. With a fully charged pack the rate will be less than 1 amp.
Regenerative discharge takes power from your pack and uses it to charge a lead acid battery.
External discharge uses some external load like resistors or bulbs to absorb the power being taken from the pack.
Old Jan 18, 2012, 02:49 PM
They Call him Dead!
Joined Jul 2003
Great info!
Oh I see on the discharge even though it allows me to set the amps in the discharge screen to higher than one amp, when I actually hit "go" it is only going to be able to pull of less than 1 amp
Old Jan 18, 2012, 03:04 PM
Turner2 is offline
Tallahassee, FL
Joined Sep 2009
That's right. The amperage will depend on voltage but will always be limited to 20 watts. So divide 20 watts by the voltage to get approximate maximum amps that the chargers internal circuits can tolerate.
Old Jan 18, 2012, 03:09 PM
They Call him Dead!
Joined Jul 2003
Thanks Again!!!!!!!
Old Apr 07, 2012, 01:59 PM
tbnil is offline
Find More Posts by tbnil
Joined Dec 2011
hi I have been using genace 3cell 2200 mah 30c batteries, no problems 7 mos old and doing well. BUT THE GENSACE BATTERIES ARE NOW IMPOSSIBLE TO GET, ALWAYS BACK ORDERED. DOES ANYONE KNOW IF THE NANO TECH OR THE BLUE LIPO , OR WHAT BRAND LIPO IS A GOOD REPLACEMENT ANY INFO WILL BE APPRECIATED TOM
tbnil is offline Find More Posts by tbnil
Old Apr 07, 2012, 02:05 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Try HiCountry Hobbies - Billowy Power packs
hoppy is offline Find More Posts by hoppy
Old Apr 07, 2012, 02:06 PM
They Call him Dead!
Joined Jul 2003
sky lipo is as good or better
Old Apr 07, 2012, 05:44 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Please provide the discharge graphs for these packs that show that.
Old Apr 07, 2012, 06:55 PM
They Call him Dead!
Joined Jul 2003
I can provide no scientific proof. Also I was reffering to Gens Ace. I did not see your post about Billowy packs. I do not know those. My comparison of Sky Lipos and Gens Ace is based on subjective opinions....
Old Apr 07, 2012, 07:49 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Got it...
Old Apr 27, 2012, 07:13 PM
sammyc is offline
Find More Posts by sammyc
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
Hi, what do you guys think of storing Lipos in my shed, where temperatures get to below freezing regularly on frosty mornings?
I understand fridge is good to store at, and some people even put them in freezer, but I am worried of the temperature fluctuating daily whether it will have a bad effect.
Other annoying thing with storing in those conditions is if I want to charge batteries in the morning I spose have to wait for battery to warm up before charging.
sammyc is offline Find More Posts by sammyc
Old Apr 27, 2012, 09:52 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Lipos can operate down to -20C so your storage area location should not be a problem.
They should be warmed before charging. I think the magic number is 50F but you should check that.
