This thread is privately moderated by hoppy, who may elect to delete unwanted replies.
Old Feb 13, 2013, 09:38 PM View Post
mannjulie2010
A moderator felt this post violated the following rule: Off Topic Advertisement. Show it to me anyway.
Old Feb 14, 2013, 08:18 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Post mistakenly deleted. Sorry.
Originally Posted by v00d0o
Ok, I guess it is a lot about trial and error.. I was only hovering.
I've got to fly around a bit, and put my full gopro load on it to see my true flight times.
Thanks for now
hoppy is offline Find More Posts by hoppy
Old Feb 14, 2013, 08:22 AM
v00d0o is offline
Find More Posts by v00d0o
v00d0o's Avatar
United States, VA, Fairfax
Joined Dec 2012
hoppy I think you deleted the wrong comment.
anyway... So this is basically all trial and error? I don't want to go under 3.7 no load. I'll have to do some testing to see what my voltage is during load when it is @3.7v
Edit.
Thanks hoppy
v00d0o is offline Find More Posts by v00d0o
Old Feb 14, 2013, 04:39 PM
gulio is offline
Find More Posts by gulio
That's a funny word
NE Ohio
Joined Apr 2003
Here's another idea if you have the equipment. Toggle between the loaded and unloaded currents while watching the voltage. A CBA will do this on "duty cycle" tests easily allowing one to fairly accurately determine the relationship between the specific voltages. It can range a LOT and can also range because of temp.
gulio is offline Find More Posts by gulio
Old Feb 14, 2013, 05:35 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Edit.
Thanks hoppy
Test and evaluate, that's the procedure. Using the chart, you can estimate after one timed run about how long it will take to get to 80%. For instance, if you fly for 5 min and the pack is 50% depleted, than another 2 1/2 minutes would put it around 75%.
Old Feb 14, 2013, 05:52 PM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
I've got my battery here. I'm not sure if its faulty or not.
I charge it balanced so a total of 12.6v - 4.20v per cell
But after I leave it couple minutes.. it goes to around 12.5v - 4.17 to 4.19 per cell..
is this normal?
Old Feb 14, 2013, 06:41 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Perfectly normal.
Old Feb 14, 2013, 09:15 PM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
Originally Posted by hoppy View Post
Perfectly normal.
Right on!
I may end up getting an OSD to see what I need to see on the screen... That way I'll know when to land. No guessing!
Old Feb 14, 2013, 09:46 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
That is what the timer in your TX is for.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Feb 20, 2013, 07:17 AM
cubflyingdave is offline
Find More Posts by cubflyingdave
Joined Feb 2013
Albeit I am a newbie at rc flying, I forget to flick the timer switch. A nice bright egg timer ticking is easy to see, set and get used to rather than a setting in the thrid page of the TX computer and a flick-switch on the top... Also for beginners with something like a DX5 the egg timer always works
cubflyingdave is offline Find More Posts by cubflyingdave
Old Mar 22, 2013, 12:08 PM
joe_crash is offline
Find More Posts by joe_crash
Pelagicide
joe_crash's Avatar
United States, MD, Gaithersburg
Joined Oct 2010
Any hope of resurrection?
Ah, I totally goofed and let my attention wander, and over discharged a brand new Turnigy Nano Tech 3s 1600mah 25-50C lipo - down to a voltage level of 8.2 v ... yes, I know - I'm an idiot. There is no puffing on the battery at all - is there any way to resurrect this battery? When I put in on my charger, I get a msg. saying the voltage is too low.
Is it destined for the lipo afterlife, and simultaneously teaching me a very expensive lesson to take my ADD meds and pay attention, or can it possibly be salvaged?
Thanks - feeling stupid - Joe
joe_crash is offline Find More Posts by joe_crash
Old Mar 22, 2013, 12:22 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Hi Joe, check out the Sticky, http://www.rcgroups.com/forums/showthread.php?t=1074181
I'd do the charge outside or in a firesafe place. Probably no problems but it pays to play safe.
Some reading on battery problems. http://www.mpoweruk.com/lithium_failures.htm
Old Mar 22, 2013, 09:48 PM
Pelagicide
joe_crash's Avatar
Joined Oct 2010
Thanks for the hope
I was just sitting here working on my quad, with my (dead) brand new nano-tech battery - then saw your post - thanks ! There's a glimmer of hope! I really was not wanting to cut the leads off of it and re-use the XT60 in a wiring harness - that would be one expensive wiring harness! I'll give it a try tomorrow and post back ... crossing my fingers.
Old Mar 24, 2013, 09:48 PM
Turner2 is offline
Find More Posts by Turner2
Tallahassee, FL
Joined Sep 2009
The sooner the better. The more time spent below safe minimum the more potential for permanent damage.
Turner2 is offline Find More Posts by Turner2
Old Mar 25, 2013, 08:02 AM
kerwin50 is online now
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
I had a tx lipo that I left on. It went dead. I did a no no and took it out side where I shocked it with a 12 volt car battery. I didn't do it very long, maybe 10 seconds at a time for 3 times.
After that I charged it at 300 ma.
That was last year and so far it seems to of held.
I know I should be discharging my Tx batt to between usage but I havn't done that either.
Are the lipo Tx batteries any different.
kerwin50 is online now Find More Posts by kerwin50
