This thread is privately moderated by hoppy, who may elect to delete unwanted replies.
Old Jul 22, 2012, 04:19 AM
Martyn McKinney is offline
Find More Posts by Martyn McKinney
Toronto Canada
Joined Dec 2002
http://www.rcgroups.com/forums/showp...30&postcount=9
Originally Posted by GreenAce92_v2 View Post
Know of anyone who fixes batteries?
Martyn McKinney is offline Find More Posts by Martyn McKinney
Old Jul 24, 2012, 08:48 AM
SleepySean is offline
Find More Posts by SleepySean
PEMAC
SleepySean's Avatar
Australia, New South Wales, Penrith
Joined Jul 2007
Originally Posted by REVOJohn View Post
yes true but definitly the pack life expectancy would be exponentially decayed
Although I agree this is likely the case, and charge at 1C myself, I haven't been able to find any definitive tests that show it does reduce battery life. I went to parallel charging just to be on the safe side.
SleepySean is offline Find More Posts by SleepySean
Old Jul 25, 2012, 07:58 AM
REVOJohn is online now
Find More Posts by REVOJohn
REVOJohn's Avatar
Singapore, Singapore
Joined Apr 2012
Hey Sean. No need to look for evidence on the internet.
That's what I do for a living, battery design and qualification for large OEMS.
Faster you charge, faster they die.
We've just designed a battery for 10C charger, 20C discharge at 10,000 cycles...took us 4 years to do it but its done in both LiFEPO4 and LiCobolt.
Although you can charge fast....the charging paramaters again must change in order to compensate for the extra heat
REVOJohn is online now Find More Posts by REVOJohn
Site Sponsor
Old Jul 29, 2012, 06:56 AM
GreenAce92_v2 is offline
Find More Posts by GreenAce92_v2
Euphoric flights
GreenAce92_v2's Avatar
United States, NY, Buffalo
Joined Aug 2011
Hello.
I'd like to convert the balancer plug on my brand new Thunder Power battery.
Attached is a picture below. Can anyone tell me with confidence which wire will go where? Color to color / color to number of wire from left to right.
I am comfortable with proper soldering and insulating without touching / shorting the cells. I am however uncomfortable with being certain which wire is correct as I recall the balance plugs are backwards in some way or another.
Any help would be appreciated.
GreenAce92_v2 is offline Find More Posts by GreenAce92_v2
Old Jul 29, 2012, 07:02 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Hello.
See post #2 The Hows and Whys of Pack Balancing:
One of the references gives all the different balance connector wiring.
hoppy is offline Find More Posts by hoppy
Old Jul 29, 2012, 07:21 AM
Euphoric flights
Joined Aug 2011
Dear God they really need to make that more user friendly.
I appreciate the information but it seems to be just "thrown" there.
It's like the difference between an Apple and Android product
Isn't it not as easy as a ground, 3.7v, 7.4v, 11.1v ?
So if I follow the same for the other adapter then I would be alright?
Here's an image for clarification on my assumption without testing voltage. The T-pro data I found on the balancer page.
Maybe the whole reversed issue is simply the plug being "flipped over" in relation to other plug. I would assume that the pins follow a standard "ground to last wire" = " lowest to highest voltage" right?
Old Jul 29, 2012, 10:48 AM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
The JST -XT plug is backwards.
Should be Positive, 3.7, 7.4, 11.1V bottom to top in you drawing.
The TP plug is correct.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Jul 29, 2012, 01:51 PM
Euphoric flights
Joined Aug 2011
I see, I couldn't test it, you are sure that that is the way? I created the physical plug based on the male plug itself though I guessed at the voltage placement.
However I did cut the outer ends to run my Vtx's which require 12V's to operate ( around there )
How can it be what you describe? ( not disagreeing ) curious is all.
Thanks for your time.
Old Jul 29, 2012, 02:04 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
The JST plug is correct as shown in Greenaces figure.. All my HK/GensAce'Billowy packs use this connector.
With the prongs up as shown...
Black = ground
#2 (white)
#3 (blue)
#4 11.1V (red)
I assume you are going to charge these with a non-TP charger.
Old Jul 29, 2012, 07:06 PM
RC Helicopter Pilot
Joined Mar 2010
I guess what we all describe is the same thing.
It all depends where you measure voltage from, the ground stationary and move the red lead or leave the red lead stationary and move the ground.
Old Jul 29, 2012, 11:46 PM
Euphoric flights
Joined Aug 2011
Yeah it's that whole backwards thing. Electrons flow from the negative terminal haha weird right?
Thanks for the clarification, figured it's about time I start taking care of my batteries, specially the more expensive 65C + batteries.
Old Aug 02, 2012, 05:54 PM
theaveng is offline
Find More Posts by theaveng
Joined Jul 2012
Originally Posted by hoppy View Post
4.23V is over the recommended max charge voltage for lipo cells. If that voltage is correct, I would replace that charger.
4.2V and lower is OK. Lower full charge voltages giver longer cycle lives.
Charging to 4.1V/cell substantially increases cycle life.
How was the value 4.2V arrived at? Is that the nominal voltage of a Li-Ion battery.
theaveng is offline Find More Posts by theaveng
Old Aug 02, 2012, 06:17 PM
REVOJohn's Avatar
Joined Apr 2012
No: Nominal is 3.7 by the basic electrochemistry
4.2 is max charging voltage the cell can hangle before things start to go wrong.
Site Sponsor
Old Aug 02, 2012, 06:28 PM
theaveng is offline
Joined Jul 2012
In that case I wouldn't charge my battery higher than slightly above nominal. Say 3.9 or 4.0. No reason to stress the chemistry. I guess chargers are adjustable?
Old Aug 02, 2012, 06:58 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Most chargers are not adjustable.
3.9V is only filled to 63% of capacity and 4V is 84% of capacity.
4.1 - 4.15V is a good number for a full charge.
If your charger has a "Fast Charge" option that will fill it to ~4.15V+/-
