Old Aug 27, 2010, 01:41 AM
Oblivion is offline
Find More Posts by Oblivion
Air, Land & Sea RC's.
Oblivion's Avatar
Australia, SA, Adelaide
Joined Nov 2008
spookie, have you fitted the EDF70 yet? flown it?
im hoping to maiden this weekend. sunday looks nice but i just have so much on i have to try get out in the morning or it wont happen
Oblivion is offline Find More Posts by Oblivion
Old Aug 27, 2010, 02:58 AM
SpookiePower is offline
Find More Posts by SpookiePower
Denmark, Capital Region of Denmark, Brøndbyvester
Joined Jun 2009
No not yet. I still need a 4s Lipo and I'm still not sure if my 60amp ESC can handle that much power. But I hope to in a few weeks, to get the time to add the 70mm fan to my F18.
I was thinking about using my 70mm fan, with my 3s Lipo and 60amp ESC, but not sure if I then will get less power than I got right now.
I hope you get airborne soon, cause I'm pretty curious to hear about the power from the new fan
SpookiePower is offline Find More Posts by SpookiePower
Old Aug 27, 2010, 04:44 AM
Oblivion is offline
Oblivion's Avatar
Joined Nov 2008
well my 681w reading was with a 3s 2200 lipo (30c discharge)
not 4s
Old Aug 27, 2010, 06:25 AM
Joined Jun 2009
wauu - Imagine what kind of power a 4s Lipo would give
Old Aug 28, 2010, 02:16 AM
Oblivion is offline
Oblivion's Avatar
Joined Nov 2008
i maidened it today, with the edf70 and 3s 2200 (60a plush esc)
the wingtip things are a waste of time. repaired them 4 times before it ever got there (tiny bump snaps it every time)
lost one in flight, the other broke on long grass landing (with gear on)
take off is smooth but the steering servo (nosewheel) needs trimming real bad.
i could gently throttle up and it was airborne pretty quick with a good climb rate.
roll rate is terrible for rolls with clevis in centre hole @ the control surface. will need to go to the inner hole @ the clevis to get better roll rate but aileron feel is pretty good for general flight. (very easy control with no expo and 100% travel)
the edf70 has the most awesome air rush sound coming out the back of it even at 30-40% cruising speed, almost has that jet like sound. (i did say almost)
landing approach at 20% throttle gave very slow controlled gliding decent but needed less than 20% thr for a proper landing decent. (over 20% it seems to glide forever)
flight times are approx 3.30-4min most cruising with little burst. landing with about 11.6v.
30c pack lightly warm.
60a plush speedie cold as a rock when in stock esc location (fully exposed to air)
i used a reversing Y harness to solve the split ele.
Old Aug 28, 2010, 05:57 AM
cx2nut is offline
Find More Posts by cx2nut
Joined Mar 2008
Has anyone had much luck getting it to do much in the way of loops? The stock COG setup and the useless elevator servo controls rendered mine almost untable to loop at all.
Even with the 4800kv, extensive intake/exhaust porting + elevon setup I am now running it still has great difficulty doing loops.
cx2nut is offline Find More Posts by cx2nut
Old Aug 28, 2010, 06:14 AM
Oblivion is offline
Oblivion's Avatar
Joined Nov 2008
im in the middle hole on the ele clevis, i thought the control was nice but i didnt try any loops.
im going to try get max controls on everything (in at the clevis, out at the servo) and see what loops or rolls it can do next time out.
Old Aug 28, 2010, 06:25 AM
Doushiyou12 is online now
Find More Posts by Doushiyou12
Doushiyou12's Avatar
Joined Feb 2010
first crash was in Jan. sat fixed for a couple of months collecting dust. flew for the first time after the overhaul last week. Crashed it again, time to fix her up again. lol. no rush.
Doushiyou12 is online now Find More Posts by Doushiyou12
Old Aug 28, 2010, 08:07 AM
Turbs is offline
Find More Posts by Turbs
Foam bounces...
Turbs's Avatar
SA, Australia
Joined Aug 2007
'bliv's maiden photos:
Turbs is offline Find More Posts by Turbs
Old Aug 28, 2010, 08:31 AM
Oblivion is offline
Oblivion's Avatar
Joined Nov 2008
thanks for the pics turbs.
its a pity it was overcast, its black in the photo's and when i was flying it
have you posted the pics of your stinny?
Old Aug 28, 2010, 08:34 AM
Turbs is offline
Foam bounces...
Turbs's Avatar
SA, Australia
Joined Aug 2007
Yeah, check the Stinson thread in the scale aircraft forum.
Old Aug 28, 2010, 03:32 PM
Joined Jun 2009
I'm using the same motor (4800kv) and have no problems doing loops. It gets a little slow on top of the loop, but it completes the loop. I'm using the stock fan, but maybe using the 70mm fan would give more power and a more perfect loop.
Old Sep 09, 2010, 05:52 PM
not.likely is offline
Find More Posts by not.likely
England
Joined Apr 2008
Got mine finished today, with the following mods
larger battery with new hatch behind cockpit.
all L/G removed and steering servo.
tailplane halfs mounted "upside down" for top control rods - straight pushrods on each elevator and mixed with spare channel for easy split servo operation
hot 64 mm cyclone fan 4300 kv - 3s 2300ma lipo 34A 370 watts
4s 50A 704 watts
80A ESC
5mm cf rods inserted into each wing panel from root to tip
1.75" balsa wingtip extensions - no rocket rails.
nosecone filled with expanding foam
cheater holes enlarged - all ducting cleaned up a bit.
AUW (3s) 786Gram ( 1lb 11 oz )
No maiden yet, but wondered on the following:
1) Anyone had a wing break in flight - especially at root ?
2) Hows that AUW sounding?
not.likely is offline Find More Posts by not.likely
Old Sep 09, 2010, 11:24 PM
Oblivion is offline
Oblivion's Avatar
Joined Nov 2008
not.likely:
it sounds like a good setup.
my 70mm fan is chewing 65a /681watt on a 3s, weighing in at i think it was about 814g a page or three back?
ive been wanting to strengthen the wings too but i wanted to fit one length across the entire wingspan... doesnt seem possible as it has to penetrate the ducting a bit in front of the fan.
might have to follow your lead and just do the wings up to the fuse
Old Sep 15, 2010, 05:52 AM
England
Joined Apr 2008
Cog
There seems to be several suggested cog points varying from 550 right up to 650 mm back from nose tip - where IS the COG guys??
Yet Another Fanfold Thread: F/A 18 Hornet Mr. Boogie Foamies (Kits) 273 May 14, 2012 05:00 PM
Discussion f/A 18 hornet by hobbyking?? mahmoodmusaddi Foamy EDFs 7 Dec 14, 2009 06:11 AM
Sold Blitzwork F-18 Hornet Pilot44 Aircraft - Electric - Jets (FS/W) 14 Sep 28, 2009 09:23 AM
Discussion BananaHobby 70mm F-18 Hornet Blitz R/C like Exceed. vigilante-rc Electric Ducted Fan Jet Talk 0 Sep 11, 2009 06:30 PM
Question Hobby Lobby F 18 Hornet C of G please! redtail Foamy EDFs 2 Aug 24, 2009 04:07 PM
