Old Aug 04, 2010, 10:02 PM
Hoverup is offline
Find More Posts by Hoverup
2013 GRAND SPORT CORVETTE
Hoverup's Avatar
Golden Gulf Coast
Joined Jul 2002
New Product
600/700mm scale rotor blades from SmartModel
A USPS Express mail package arrived today. Opened the box and found four 700mm swept tip scale main rotor blades and also a set four 600mm swept tip blades. These are test articles sent direct from the SmartModel factory in China. The 700's will be put to work on my SmartModel USCG HH-60J Jayhawk and the 600's on my 600 size AH-64A IAF Apache.
The blades appear to be injection moulded resin with a high carbon content and are very tough.
Step one was to get out the Ohaus triple beam scale out and weigh all 8 blades with the following results:
Blade 1 (700mm) = 207.4g
Blade 2 (700mm) = 207.5g
Blade 3 (700mm) = 207.5g
Blade 4 (700mm) = 207.6g
Blade 1 (600mm) = 225.2g
Blade 2 (600mm) = 225.5g
Blade 3 (600mm) = 225.6g
Blade 4 (600mm) = 225.6g
The weight variances are minimal and some of the best I have seen. I will wait until the blades are painted before using clear coat to balance them. Once installed and rotor head with blades is balanced, the blades will be numbered as will the grip in which they are mounted.
The 700mm blades measured 47mm at the chord, 6.6mm at the thickest part of the symmetrical airfoil and 14mm thick at the root with 4mm I.D. mounting bolt hole.
The 600mm blades measured 47mm at the chord 6.6mm at the thickest part of the symmetrical airfoil and 12mm thick at the root with 4.8mm I.D. mounting bolt hole.
The symmetrical airfoil allows installation that supports both CW and CCW main rotor rotation so that the modeler can accurately mimic the 1:1 heli that's being modeled. In my case both the Jayhawk and .Apache have CCW rotation.
If the heat wave ever breaks here along the coast (108-110 deg F heat index), we'll get these strapped on the two chassis that have had power trains upgraded for 10s and 12s Lipos with low kV motors for these two very sweet scale fuselages from TFModel/SmartModel. Now all we need is the four blade cascade T/R for the Apache and all will be right in my hangar. We'll be back with flight reports including a complete description of the mechanical and electrical/electronics set ups for both chassis. Both are based on the Align TRex 600e kits.
Thanks to Kin and Willis for these test samples. They are beautiful and will really make the Hawk and the Apache "POP".
Cheers - Boyd
AMA 80393
IRCHA 3355
LSF 853
Major USAF
Retired
Hoverup is offline Find More Posts by Hoverup
Old Aug 05, 2010, 05:36 AM
Zimm is offline
Find More Posts by Zimm
Joined Jul 2004
Hoverup, i look forward to your tests of these blades, good luck and i hope they work out for the 700 series heli's.
cherries
zim
you may have the weights of blades, around the wrong way
Zimm is offline Find More Posts by Zimm
Old Aug 05, 2010, 08:36 AM
Hoverup is offline
Hoverup's Avatar
Golden Gulf Coast
Joined Jul 2002
cherries
zim
Good catch zim Post edited.
Cheers - Boyd
Old Aug 05, 2010, 10:33 AM
Hoverup is offline
Hoverup's Avatar
Golden Gulf Coast
Joined Jul 2002
Rounded tip blades are also available for EuroCopter applications and many others. I believe these will be available in both 600 and 700mm spans.
Cheers - Boyd
Old Aug 05, 2010, 10:35 AM
Minibichus is offline
Find More Posts by Minibichus
MB-Commander
Minibichus's Avatar
Joined Feb 2008
WOW, 200 grams of weight, per blade? I think that for as much as I like these I am going to pass on them.
G.
Minibichus is offline Find More Posts by Minibichus
Old Aug 05, 2010, 10:42 AM
SidewaysLS4 is offline
Find More Posts by SidewaysLS4
Redjestird Youser
SidewaysLS4's Avatar
Joined Jan 2009
Hey, whats wrong with that? You can fly...and trim the hedges at the same time
SidewaysLS4 is offline Find More Posts by SidewaysLS4
Old Aug 05, 2010, 10:43 AM
Hoverup is offline
Hoverup's Avatar
Golden Gulf Coast
Joined Jul 2002
They are stout.
Old Aug 05, 2010, 10:59 AM
cap231ex is offline
Find More Posts by cap231ex
Track clear , smoke on !
cap231ex's Avatar
3 miles from AMA HQ Muncie, IN.
Joined Jan 2009
I would like to see a flight test video, any chance?
cap231ex is offline Find More Posts by cap231ex
Old Aug 05, 2010, 11:07 AM
sidneyw is offline
Find More Posts by sidneyw
United States, NC, Huntersville
2-blade test vid ...
TF BLADES TEST 1.MP4 (1 min 7 sec)
TF Blade 3-D test 2.MP4 (4 min 3 sec)
sidneyw is offline Find More Posts by sidneyw
Site Sponsor
Old Aug 05, 2010, 12:54 PM
MB-Commander
Minibichus's Avatar
Joined Feb 2008
Exactly, LOL! what was I thinking!
G.
Old Aug 05, 2010, 01:31 PM
cap231ex is offline
cap231ex's Avatar
Joined Jan 2009
That's nice Sidney but I would like to see something with a fuselage and scale head(3-5 blades) just seems like a lot of rotating mass. Regular FG 600mm blades are around 138-145grs. times 4 = 552-580grs. 207 X 4 = 828grs a whopping 278-248grs that's a lot of extra weight spinning around a 10mm shaft.
Old Aug 05, 2010, 01:53 PM
Hoverup is offline
Hoverup's Avatar
Golden Gulf Coast
Joined Jul 2002
Points well taken. The swept tip blades will only show up in four blade setups as that's the way the 1:1 helis with these blades are configured. Hawks and Apaches are the swept tip helis that I'm aware of. We'll see how they fly at a relatively low headspeed. Be back in a few days with initial impressions test flying the mechanics. Meeting your request will take a little longer as the work involved in mounting the machinery in the fuselage is a little more involved than an ARF.
Cheers - Boyd
Old Aug 05, 2010, 01:55 PM
sidneyw is offline
I've seen 600 and 700mm blades weighing >200g each. I guess most will run 8, 10 or 12S, the fuselage is heavy too in this class. Agree on the weight when you have 4 or 5 of them.
http://www.helidirect.com/curtis-you...des-p-6413.hdx
Site Sponsor
Old Aug 05, 2010, 02:05 PM
MB-Commander
Minibichus's Avatar
Joined Feb 2008
mine are 98 grams a piece, I won't settle for double the weight at the rotorhead. Thats another 500 grams of crap to move around. Not rotate around, that shouldn't matter a bit, well, be prepared to see blades grips shooting out of the threads eventually... but other than that they look cool.
G.
Old Aug 05, 2010, 02:10 PM
MB-Commander
Minibichus's Avatar
Joined Feb 2008
Cheers - Boyd
Yeah, I would advise to fly these at real scale headspeeds, like 900 RPM, I wouldn't feel safe spinning those 220 gram blades at 1600 RPM, especially when I know for a fact that those blades won't snap, break nor shatter, instead, those 5 machetes spinning at 1600 RPM are ready to chunk anything or anybody at a moment's notice.
G.
Discussion Smartmodel 600/700/800 size scale blades? Minibichus Scale Helicopters 22 May 14, 2010 12:28 PM
Discussion Smartmodel scale rotor blades for 450 size ! kin Scale Helicopters 172 Apr 13, 2010 02:17 PM
Discussion Apache 600 scale rotor head and tail rotor head and main blades kin Scale Helicopters 4 Jan 10, 2010 03:07 PM
Discussion PRO-3D Blades from smartmodel kin Scale Helicopters 3 Jun 19, 2009 04:06 PM
Build Log 4-bladed CNC rotor head from Smartmodel sidneyw Scale Helicopters 82 Apr 15, 2009 08:49 AM
