Old Dec 29, 2012, 02:01 PM
rmorhan is online now
Find More Posts by rmorhan
rmorhan's Avatar
wasaga beach ont canada
Joined Jan 2004
randy, the eagltree osd pro works great on a quad. the only thing it won,t do presently is the rth function. i just ordered a second system for a new hex.(my forth et system) the eagletree works great on my quad with a naza controller. it will work just fine on your kk2 quad. if you really want the rth function consider the naza controller but at $400 with gps you,ll still need the et osd for flight logging & all that osd info et displays.my et locks satellites better than the naza. even the $1100 dji wookong controller won,t do everything we want for fpv. the et stuff is well worth the coin imho...rob m
rmorhan is online now Find More Posts by rmorhan
Old Dec 29, 2012, 02:50 PM
romans1015 is offline
Find More Posts by romans1015
Winter Sucks!!
romans1015's Avatar
United States, WI, New Berlin
Joined Aug 2002
HI Rob,
I'm ok if I don't have RTH......I just want to know like you said that everything else
is useable.
I I bought everything from Ready Made in Spring but haven't used it!
The OSD Pro the Elogger, Gps, Gaurdian Stabilization, Eagle Eyes FPV Station.
Will I be able to use the tracking on the Quad also......I bought the Pan & Tilt set up for that too
romans1015 is offline Find More Posts by romans1015
Old Dec 29, 2012, 03:01 PM
rmorhan's Avatar
Joined Jan 2004
randy, the only thing that won,t help on your setup is the guardian stabilizer. i have never used one before but did just order one for a bixler fpv plane i,m putting together. i,ve been using the et stuff for years & couldn,t be happier with the quality...rob m
Old Dec 29, 2012, 03:39 PM
Winter Sucks!!
romans1015's Avatar
Joined Aug 2002
That's good to hear Rob, thanks
Old Dec 29, 2012, 03:56 PM
seadog1967 is offline
Find More Posts by seadog1967
Waiting for my Medication
seadog1967's Avatar
USA, MA, West Springfield
Joined Nov 2010
Running ET on my hexa with no issues. No stabilizer module though since Naza is good.
seadog1967 is offline Find More Posts by seadog1967
Old Jan 18, 2013, 02:28 PM
jleehumed is offline
Find More Posts by jleehumed
Joined Jul 2012
How to connect the V4 eLogger?
I recently purchased the V4 elogger / wire ends by Eagle Tree and after connecting the battery lead to the battery and the ESC lead to the ESC everything was done. I also connected the Y harness supplied with the Elogger to the Throttle on the AR600 Receiver. Much to my dismay it did not work. After removing everything and connecting everything back without the elogger the receiver wouldn't say a word!!!!! Please help with proper connection. (3S 2200mah batter / trial on T28 - checking RPMs)
thanks!
jleehumed is offline Find More Posts by jleehumed
Old Jan 31, 2013, 05:36 PM
buzz kill is offline
Find More Posts by buzz kill
Dawsonville, Georgia
Joined Dec 2010
OSD Voltage
Gentlemen,
I am having issues installing OSD Pro with Dragon Link Receiver. The Dragon link is only rated to 9V which I power with a castle BEC set at 6v. The OSD Pro appears to be powered by the Elogger V4 by my 14.8V pack. The Receiver and my servos cannot handle this voltage. My question is does the OSD Pro channel in and outs get power from the Elogger at 14.8 or does the regluated 6v from my dragon link power the servos through the OSD without a voltage jump?
Any assistance would be greatly appreciated.
Buzz
buzz kill is offline Find More Posts by buzz kill
Old Feb 01, 2013, 02:19 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi Buzz,
The OSD Pro does not provide any power to the receiver or servos. It does pass through the power from your receiver/BEC to the servos, however. The OSD Pro does get 5V power from the eLogger.
billpa is offline Find More Posts by billpa
Site Sponsor
Old Feb 17, 2013, 04:15 AM
3rdidvet is offline
Find More Posts by 3rdidvet
Joined Feb 2013
Wow!
This is getting complex FAST! So much for plug 'n' play! I am using a setup similar to what "Crumpled" has. AR600 Rx and OSD V4, eLogger V4, GPS V4.
My issue is that I am running two motors on a twin engined aircraft. I am not sure what the BEC does in the diagram, and I am not sure if I need it, or what type of BEC to get. Additionally, will only one BEC do the trick, or will the multiple motors cause me to add another BEC.
Being that the ESC's both require signal, how should they be integrated into the system? I would imagine that one doesn't need to send power back to the Rx.
Also, Crumpled, if you see this, I see in your diags, several numbered items that appear to be notes. Are those notes available so I can get a better understanding of how you completed your wiring?
Also, will be running TWO 11.1V 3S Lipo's in parallel so that I can get a longer duration of flight.
Forgive me if my questions seem lame. I'm a bit new to this!
3rdidvet is offline Find More Posts by 3rdidvet
Old Feb 17, 2013, 11:36 AM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
The BEC supplies power to your receiver.
Usually the ESC (speed controller)
has a BEC (battery elimination circuit) builtin.
but if your esc is of a questionable qualtiy, and you don't fully trust
it enough to use the built in bec,
or if your built in bec, only supplies up to a very low amperage,
then you would want to use an external bec.
So one should do...
Oh, and if you are running two esc's then you want to pull the power coming from one of the bec's.
and if you are running an external bec then you want to pull the power on both of your esc's with the builtin bec.
basically you only want to supply power from one source...
m_beeson is offline Find More Posts by m_beeson
Old Feb 17, 2013, 07:03 PM
3rdidvet is offline
Joined Feb 2013
Ok, Mike... I am going to drag this entire post over to the other conversation that we started so I can try to keep it all in one place. Thank you thank you thank you!!!
So one should do...
Old Feb 17, 2013, 07:07 PM
3rdidvet is offline
Joined Feb 2013
Essentially I am trying to follow this WD, but, of course need to show the other motor. One of the other fellows on here posted it, and it seems to fit me best. Trying to find a program to edit this pic and add / modify it to fit my setup.
Old Feb 18, 2013, 06:55 PM
secretspy711 is online now
Find More Posts by secretspy711
Assault the sky
secretspy711's Avatar
United States, CO, Denver
Joined Aug 2004
My video IN and video OUT pins are BOTH connected to the camera AND transmitter -- in other words, you could swap the video-in and video-out plugs and nothing would change (I did this so that if the OSDpro completely fails, I'd still have video, but no OSD overlay.)
I noticed that the text is not as bright as in my friend's installation. Is this the reason?
secretspy711 is online now Find More Posts by secretspy711
Old Feb 20, 2013, 06:17 PM
TZZDC1241 is offline
Find More Posts by TZZDC1241
United States, CO, Breckenridge
Joined Feb 2012
Has anyone done a diagram using the TBS core, TBS lawmate 2.4Ghz and TBS69 camera?
I'm trying to get away from using the crap infested ezOSD (TBS ezOSD) system since this is the second current sensor that's gone out on me, the unit wont connect via USB nor will the GPS work.
TZZDC1241 is offline Find More Posts by TZZDC1241
Old Feb 20, 2013, 11:06 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
I'm not sure exactly what the core does.
The tbs 69 and the lawmate would all be just like any other diagram
I haven't spent much time looking at the core, so I'm not sure how you would incorporate it, other than if it is a Voltage regulator and / or a BEC, then you would insert its' capabilities instead of using a different device.
It should be pretty straight forward...
Discussion Please post your brushless motor pole count here billpa Eagle Tree Systems 91 May 05, 2015 01:31 AM
Discussion Please post photos of your sensor installations here! billpa Eagle Tree Systems 8 Jul 09, 2011 06:21 AM
Discussion Post your small flying field video here! Lafayette Aerial Photography 38 Sep 05, 2010 02:46 AM
Help! Noob needs help wiring elogger-v3/OSD Pro Mykro Eagle Tree Systems 7 Jun 25, 2010 01:59 AM
PLEASE post pics of your Tiger Moths here!! JREEVES Parkflyers 3 Oct 26, 2001 10:51 PM
