seadog, i have the eagletree elogger,gps ,osd & powerpanel on my naza controlled nl650 rig. since the eagletree stuff can,t do auto pilot on quads yet , i can,t see any reason to connect the esc or servo outputs. mine does great at datalogging & the osd is real nice but without the guardian as well i see no reason for the extra connections. anyone feel free to correct me if my thinking is flawed as mine aren,t connected & all works well!...rob m
Seadog. |
Joined Jul 2012
Leave the four ESC of your quad as they are. You only need to connect the ESC if you have an airplane with a single motor. I fly a Naza Hexa and in the process of installing my FPV gear and ET OSD and eLogger. Still figuring out the wiring also. Javier |
United States, NC, Mooresville
Joined Aug 2012
After printing out and going over all the posted diagrams, I still have 3 unanswered questions:
1 - UBEC getting power between Battery and eLogger or between eLogger and ESC? (I know this is still up for debate, but no one has objectively answered if the mAH useage of the Rx and servos will still be recorded even if the UBEC is before the eLogger) 2 - When using a UBEC to power the Receiver and servos: Do you remove power AND ground between the ESC and the Throttle output of the OSD Pro? (so only signal is going from OSD to ESC) or can you leave the ground there as well? 3 - When using a UBEC, do you tie into the battery's power AND ground like the manuals for the UBEC state? (Some have recommended ONLY connecting the UBEC to the power side of the battery and the power pinout to the receiver. Clarification would be greatly appreciated, thank you. |
United States, UT
Joined Feb 2012
not sure if it answers your questions. |
Joined Aug 2012
Ya, i've read that post before but it does not address if the mAH useage of the Rx and servos will be recorded by the eLogger or not. I guess I can just run a 15K ohm resisted line to that battery to have the voltage on the OSD and go off of that instead of mAH used.
Joined Jul 2012
Wiring diagram
Here is my wiring diagram. It has not been tested and it is my first attempt. I have tried to understand the previous diagrams in this thread. Please point out if there is some mistake or some way in which I can improve it. I will be really scared when I plug in the power. I have tried to eliminate ground loops but there are a few things I am a little unsure about.
1. Should I connect the ground from my 450mAh Lipo to the ground of the video TX/OSD audio out/OSD audio in the way I have in the wiring diagram? (Or does this create a giant ground loop since all grounds in the OSD is connected?) 2. Would it be better to connect the power and ground from the 450 mAh Lipo directly to the Camera and Mic, cutting those wires before they enter the OSD? 3. Any mistakes that need to be corrected or suggestions for improvements? |
| Thread Tools | |
| Discussion Please post your brushless motor pole count here | billpa | Eagle Tree Systems | 67 | May 06, 2013 07:49 AM |
| Discussion Please post photos of your sensor installations here! | billpa | Eagle Tree Systems | 8 | Jul 09, 2011 05:21 AM |
| Discussion Post your small flying field video here! | Lafayette | Aerial Photography | 38 | Sep 05, 2010 01:46 AM |
| Help! Noob needs help wiring elogger-v3/OSD Pro | Mykro | Eagle Tree Systems | 7 | Jun 25, 2010 12:59 AM |
| PLEASE post pics of your Tiger Moths here!! | JREEVES | Parkflyers | 3 | Oct 26, 2001 09:51 PM |
