Old Aug 04, 2010, 10:43 AM
mikes68charger is offline
Find More Posts by mikes68charger
Why kamikaze pilot wear helmet
mikes68charger's Avatar
United States, IL, Rock Island
Joined Jul 2010
Can you use Futaba Servos with A Spektrum Reciver?
Ok, Im still pretty new to this hobby and its odditys.
My wife got a me a sweet Edge 540T with 65in wing span
Anyways it has Nice larg Futaba Servo's on this plane, but I am useing the Spektrum radio 2.4g that came with my Parkzone corsair.
The hobby store sold me a AR6200 Spectrum Reciver, told me that this is the best reciver for my plane becouse it come with 2 recivers connected.
So I go to connect it up last night and I realize the taps are diffrent.
Anyone know what it takes to connect the Futaba servos to spekturm set up?
Thanks Guys.
mikes68charger is offline Find More Posts by mikes68charger
Old Aug 04, 2010, 10:54 AM
Zeeb is offline
Find More Posts by Zeeb
Zeeb's Avatar
United States, UT, Highland
Joined Jun 2006
Yup I and lots of others know, but we're not 'tellin.....
Seriously tho, just shave the little tabs off the male connectors and with the Spektrum/JR rx's, you MIGHT have to trim opposite corners on those plugs as well to get 'em into the slots on the rx. Just take a close look at the servo slots on the rx and if it has the plastic "guide" on them you'll see that two corners are just slightly trimmed. Those tend to be a close fit and sometimes the Futaba connectors don't want to go into those slots with out trimming the corners as well as the tab off.
Zeeb is offline Find More Posts by Zeeb
Old Aug 04, 2010, 11:35 AM
freechip is offline
Find More Posts by freechip
freechip's Avatar
Joined Aug 2008
YES, you can use any 3wire servo, for futaba with spektrum/Jr. just trim the excess tab on the servo connector
freechip is offline Find More Posts by freechip
Old Aug 04, 2010, 12:02 PM
Joined Jul 2010
Thanks guys,
So the tabs on the servos is on the right side, so just trim this, but make sure it stay on the right side when I pug it in the Reciver? No swaping or installig backwards?
Old Aug 04, 2010, 12:27 PM
cryhavoc38 is offline
Find More Posts by cryhavoc38
Why didn't they run? A pass???
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
thats the beauty of three wire servo's and power.
you won't do any harm if you install the servo plug in wrong, or even power.
This is because the center plug is red, and that is the + side of the battery.
If you accidentally plug in the esc receiver wire upside down, you are doing nothing electrically to the component so no damage as the + is always in the center.
Of course the esc won't respond, nor would the receiver if the esc is supplying power to the receiver...
So in other words, for Futaba servo's, they have that little tab next to the "Signal" wire and this would need to be shaved off if going into non futaba hardware, servo extensions, etc..
cryhavoc38 is offline Find More Posts by cryhavoc38
freechip is offline
freechip's Avatar
Joined Aug 2008
Since most of todays 3 wire servo have the POS wire lead in the center, it wont hurt anything it just wont work.
The general rule is the NEG goes towards the outer edge of the case or away from the center or pointing downwards.
Dam yours got posted before mine.
Old Aug 04, 2010, 01:10 PM
Joined Jul 2010
Thanks guys,
Old Aug 04, 2010, 03:42 PM
cryhavoc38's Avatar
Joined Mar 2007
likeminded individuals.
Old Aug 05, 2010, 11:07 AM
roberted5 is offline
Find More Posts by roberted5
Joined Nov 2009
I've use Futaba analog servos in all my Spectrum recievers.
roberted5 is offline Find More Posts by roberted5
Old May 17, 2014, 10:20 PM
619SixFour is online now
Find More Posts by 619SixFour
Alpine Aero Sqdn.
619SixFour's Avatar
United States, CA, Jamul
Joined Mar 2012
This is a super old thread but thanks for the info. It just saved me an hour trip to my LHS.
619SixFour is online now Find More Posts by 619SixFour
Old Jun 03, 2014, 03:16 AM
fsa0033 is offline
Find More Posts by fsa0033
Capt K. Lee
Joined Feb 2014
Still helpful
Like to thank those who asked the question already. Those of us that are new need answers all the same. I have Futaba servos and an AR400 receiver so I have the same problem. Luckily I got the answer saving me a trip to my LHS. Lots of sanding now.
fsa0033 is offline Find More Posts by fsa0033
Old Jun 04, 2014, 02:37 PM
Zeeb is offline
Zeeb's Avatar
Joined Jun 2006
When I first ran into this tab issue I didn't have a Dremel tool so I usually used an Xacto knife to trim the things, now I use a Dremel with a drum sander tool...
Old May 10, 2015, 07:41 PM
scole is offline
Find More Posts by scole
Joined Feb 2014
so what servos fit the spectrum receivers, besides spektrum
scole is offline Find More Posts by scole
Old May 10, 2015, 08:40 PM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
Any modern servo can be used with any current radio system. Only the old style Airtronics (Sanwa) connectors from before around 1997 need to have the connectors rewired or changed out.
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old May 10, 2015, 10:51 PM
flypaper 2 is offline
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
JR servos is another popular brand.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Discussion Can you use a dx6i with 7 chan RX? ryokox3 Radios 2 May 10, 2010 04:51 PM
Discussion Can (should) you use micro servos in a 48" Wing kboz Slope 3 Jan 18, 2010 10:22 PM
Help! can you use a brushed or brushless motor on any reciver lightningzeus Beginner Training Area (Aircraft-Electric) 2 Nov 30, 2009 10:40 AM
Help! Can I use Spektrum Digi Servos w/Futaba Rx? Randy -- Radios 1 Apr 14, 2008 01:31 AM
