Old Aug 04, 2010, 02:25 AM
John Kim is offline
Find More Posts by John Kim
Panorama City, CA
Joined Sep 2004
Help!
high voltage 7.4V servo
Anybody know of high voltage small Chinese servos which operate at 7.4V, 2 cell LiPo, and Chinese dealers which stock them?
John Kim is offline Find More Posts by John Kim
Reply With Quote  (Disabled)
Old Aug 04, 2010, 06:13 AM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
The necessary specification for a 2s LiPo is 8.4v, the initial voltage, not 7.4.
Daedalus66 is offline Find More Posts by Daedalus66
Old Aug 04, 2010, 08:09 AM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
3.7 * 2 = 7.4
NiCad/NiMh servos use the nominal voltage of the batteries and not the peak hot off the charger. I think it would be less confusing to rate LiPo servos the same way, especially since a 2-cell LiPo is labeled 7.4v.
RC Man is offline Find More Posts by RC Man
Old Aug 04, 2010, 08:25 AM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Maybe, but the point is that if you are looking at servo specifications you need one that can take 8.4v as the LiPo declines only slowly from that level.
Presumably "6v servos" already have a suitable margin built in for 5-cell use, but once you go to higher voltages it's not at all clear that there is anything called 7.4v servo that's good for 8.4.
All quite confusing and unfortunately the specifications are often not clear.
Old Aug 04, 2010, 10:31 AM
RC Man is offline
United States
Joined Feb 2001
It would be best if the servo specks just said 2s LiPo and there would be no confusion.
Old Aug 04, 2010, 10:43 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
here are some high voltage rated servos here:
http://hobbycity.com/hobbyking/store..._.033sec_/_79g
http://hobbycity.com/hobbyking/store...kg/79g/.118sec
this one is good up to 3 cells or 12v too:
http://hobbycity.com/hobbyking/store..._.030sec_/_79g
http://hobbycity.com/hobbyking/store..._.118sec_/_78g
http://hobbycity.com/hobbyking/store..._.033sec_/_67g
earlwb is offline Find More Posts by earlwb
Old Aug 04, 2010, 02:26 PM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
The component that usually determines the maximum voltage a device can handle is the electrolytic capacitor. Check the markings on them and see what the voltage rating is. It is best to only stress them to about 80% of their rating, less if there is a high ripple on the voltage they are filtering.
Rodney is offline Find More Posts by Rodney
Old Aug 04, 2010, 02:45 PM
RC Man is offline
United States
Joined Feb 2001
Thatís a very strange statement. I always thought that it was the motor windings.
Old Aug 04, 2010, 08:37 PM
John Kim is offline
Panorama City, CA
Joined Sep 2004
Thanks for info, but these expensive servos for giant planes are not what I have in mind.
Do you know of any micro or mini servos?
Old Aug 05, 2010, 05:21 AM
Kentucky is offline
Find More Posts by Kentucky
Registered Abuser
Kentucky's Avatar
Melbourne, Australia
Joined Apr 2004
Dymond D47, D60
http://www.rc-dymond.com/index3.php?categoryID=17
Kentucky is offline Find More Posts by Kentucky
Old Aug 05, 2010, 09:47 AM
Rodney is offline
Florida
Joined Aug 2004
True, that is also an important consideration but; if you are not overloading the motor you will not burn it out. However, if you are exceeding the voltage rating of the capacitors, they are very apt to fail. I have spent many years in failure analysis of electronics and by far, the electrolytic capacitor is the most prone to failure if you exceed voltage specifications. Now, capacitor size is probably the biggest factor in building physically small servos and so is usually the item that the designer has the most trouble in size limitations. Since a smaller voltage Capacitor is smaller than a similar capacitance with a high voltage rating, you can guess which decision is usually made in the selection of components.
Old Aug 05, 2010, 10:53 AM
RC Man is offline
United States
Joined Feb 2001
Has anyone used a 6.6v battery with a 6v servo?
According to the instructions you can run a standard servo without a regulator.
http://www3.towerhobbies.com/cgi-bin...&I=LXYAS9&P=ML
Old Aug 05, 2010, 12:04 PM
John Kim is offline
Panorama City, CA
Joined Sep 2004
Originally Posted by Kentucky View Post
Thanks. That fills my needs. D47, 4.8 - 9V, is what I was looking for.
Old Sep 05, 2010, 01:51 AM
splinters is offline
Find More Posts by splinters
Joined Jul 2007
I totally agree with RC Man. The upper voltage limit for servos is determined by the motor specs, not the capacitors. If you don't believe me, go hook up a standard servo to a 2S Lipo and watch what happens. The motor windings (or MOSFET drivers) will fail because of excess heat generation long before the dielectric properties of capacitors fail. Capacitors used in servo electronics are typically rated at 12V, far above the maximum operating voltage of the servo motor.
Also, to clear up any confusion about whether a 7.4V servo can be used with a 2S Lipo, the answer is Yes. These servos are specifically designed to be used with 2S Lipos and are rated at the nominal voltage of such cells, meaning they can handle the peak charged voltage of a 2S Lipo. Go check the Hitec HV range of servos as examples.
splinters is offline Find More Posts by splinters
Old Sep 05, 2010, 09:48 AM
carlsoti is offline
Find More Posts by carlsoti
hass-alfed and bass-ackwards
carlsoti's Avatar
United States, AZ, Chandler
Joined Jun 2008
I run dymond 47 and 60's in my blaster II on 2S lipo just fine. People have reported the D47's to work @ 1S voltage, as well.
carlsoti is offline Find More Posts by carlsoti
For Sale Hirobo 7.4v Charger (stock) + 1 lipo 7.4v 480mah glhelinski Aircraft - Electric - Helis (FS/W) 3 Nov 02, 2010 03:59 PM
Sold Hirobo 7.4v Charger (stock) + 1 lipo 7.4v 480mah glhelinski Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jun 17, 2010 04:20 PM
Discussion 7.2V , 7.4V, 8.4V and 15-20 Ah battery pls marcolisi Batteries and Chargers 27 Jun 03, 2010 11:51 PM
Discussion Voltage regulator 7.4V lipo and wiring. How are you wiring it up? wwang Hand Launch 14 Feb 22, 2010 05:40 PM
Found 7.4V-14.4V Lipo Low Voltage Alarm hongrn Aircraft - General - Miscellaneous (FS/W) 1 Nov 28, 2009 02:09 PM
